Central Locking Problem - BMW Luxury Touring Community
post #1 of 10 Old Oct 11th, 2007, 12:14 pm Thread Starter
While on the road over last weekend I, in all my brilliance, allowed the battery to drain almost to the point of extinction. Jumped the bike and got started, rode alot to charge (broke my heart) and had no further problems, except the central locking system is locked and will not open. The security system and everything else is back operational. Tried the fob in all directions and various button holding sequences and durations. Still no luck. Got into the bags with the 45 degree trick except for the odements box. Checked the owners manual....no info....tried searching the site but saw nothing quite like this....
Any help is appreciated!
Andy
tet68vet
'05 Lt Ocean Blue Metallic
'02 Nightrain Black "of course"
"For those who fought for it, freedom has a flavor the protected will never know." - POW-MIA
tet68vet is offline
post #2 of 10 Old Oct 11th, 2007, 12:43 pm
Try pressing down lightly on the latch for the oddiments box while cycling the central locking. This is a known issue that sometimes comes up.
post #3 of 10 Old Oct 11th, 2007, 2:09 pm
®win's Avatar
... the central locking is not working ...
Not much to cycle then, is there.
Is the battery completely charged now? If not, charge it and then try to unlock again.
Erwin
R1200GS Adventure LC 2018, Blackstorm/Schieferdunkel Matt/Achatgrau (Triple Black), in full options, BMW Navigator V
R1200GSA LC '18 <- R1200GSA LC '14 <- K1600GTL '12 <- R1200GS Adventure '09 <- K1200GT '07 <- K1200LT '05 <- K1200LT '99 <- K1100LT '95 <- K75RT '92
®win is offline
post #4 of 10 Old Oct 11th, 2007, 5:59 pm
If you hit the lock hard enough it will open. I used the rubber covered end of a hammer handle to open mine. I know, a real man could use his fist.
Big_E is offline
post #5 of 10 Old Oct 11th, 2007, 11:24 pm
Well if he is pressing the fob and the alarm is cycling and the central locking is not his alarm is toast as they are one and the same.
post #6 of 10 Old Oct 15th, 2007, 1:04 pm
birdman's Avatar
No quick fix
Had the same problem with my '06. In this case the whole central locking system went U.S and my bike was towed away by the dealer. Still under warranty they had to replace the entire C/L unit.
I would rather be riding my bike and thinking about God than sitting in Church thinking about my bike!
Regards
Allen
birdman is offline
post #7 of 10 Old Oct 16th, 2007, 12:37 pm
Wink Been there while at the dealership!
The team at MAX BMW in NH made a mistake which resulted in a similar problem on my 05LT. Their fix was simple given it happened in a nice warm, well lighted, comfortable garage with every possible tool available.
Given all of that, the tool of choice was a set of leads for an AC/DC tester and a couple of alligator clips. This really is a two person job (unless you have four hands that is).
Under the passenger seat (yes you have to remove it, carefully push a long rag wrapped screwdriver in between the seats to "pop" the release. Be extremely careful or you'll be riding to the dealership to buy a new seat). There is a small plug, about 1/2" wide and 2" long, right in front of the coupling for the rear audio. It has two wires in and two out. Take one lead connected to your battery positive post (use alligator clips for that end) and insert the end of the lead to the right side of plug connector. Do the same with a lead from the negative post. You should hear the central locking try to activate or deactivate. The other person will need to push down on any of the locks at the same time. If this does not work try reversing the leads at the plug end.
This whole thing took about 1 minute while I watched at the dealership. I tried it myself at home in the garage to see If I could repeat. It worked! The main issue is, the alarm can not be activated. This "hot wire" will only work on the central locking system not the immobilizer system. For that you must have the fob. Good luck!
2005 LT- Dream Girl
2003 Honda Shadow
LTBrown is offline
post #8 of 10 Old Oct 16th, 2007, 2:06 pm
Thanks for that but I don´t understand why, if they had a key at hand, they didn´t do the quarter turn trick to open the left hand side case to get at the knob that releases the seat.
simoncharles is offline
post #9 of 10 Old Oct 17th, 2007, 1:18 pm
My confused reading habit kicked in.
I thought you could not unlock the bags at all. Yes if you can "key" the lock of the left side you could just open the bag that way. But from there you can "trick" the locking system to reseting itself.
2005 LT- Dream Girl
2003 Honda Shadow
LTBrown is offline
post #10 of 10 Old Nov 5th, 2007, 4:46 am
Same thing just happened to me, but before I explain how I solved it, did you have the key and the fob with you at the time ?.
Central Locking System Buchnerb K1200LT 17 Apr 25th, 2007 6:01 pm
Central locking upgrade? Schweintechnik K1200LT 0 Dec 27th, 2006 3:54 pm
central locking question TonyS K1200LT 3 Aug 17th, 2006 8:59 am
Central Locking Question TonyS K1200LT 1 Aug 6th, 2006 5:21 pm
Central Locking... Stupid Newbie Question buddoggin K1200LT 3 Jun 9th, 2006 10:39 am
