What size torx drive do I need to remove tupperware? - BMW Luxury Touring Community
post #1 of 7 Old Nov 26th, 2005, 6:29 pm Thread Starter
KayGee's Avatar
I am not a do-it-yourselfer but I need to remove a bit of the plastic. If I only wanted to buy just one torx screwdriver, which size do I need?
2018 K1600GTL
2012 K1600GTL (retired)
2003 K1200LT (retired)
IBA # 35048
KayGee is offline
post #2 of 7 Old Nov 26th, 2005, 6:35 pm
Senior Member (ret.)
RaffyK's Avatar
Most are T-25. A few 3mm allen (hex) and some T-20 in the top case.
Raffy
RaffyK is offline
post #3 of 7 Old Nov 26th, 2005, 6:46 pm
tmgs's Avatar
I changed out my 3mm allen, they are the four screws on the belly of the bike, but isn't the tag mounting plate t-27?
BTW Raffy I havn't forgot about you, I've been busy back and forth between fl, I'll call ya during the week sometime
Tom
Tom
tmgs is offline
post #4 of 7 Old Nov 26th, 2005, 8:21 pm
neodoc's Avatar
I use this to remove almost all the screws. Attaching it to the drill makes it very quick. Tightening them up requires care and low torque on the drill so they don't crossthread and strip.
http://www.cyclegadgets.com/Products....asp?Item=BITS
Joe
05 Ocean Blue LT "Mein Byk"
14 Rolls Royce Ghost
16 GLE 63 S
99 CLK 320 Cabriolet
neodoc is offline
post #5 of 7 Old Nov 26th, 2005, 8:49 pm
Most newer cordless drills have a clutch...but I've noticed that few people seem to use them. The Tupperware screws are a great place to utilize this feature to prevent stripage.
I personally use an S&K thumbwheel ratchet for all these chores...but I didn't want to hijack the thread.
post #6 of 7 Old Nov 27th, 2005, 12:59 am
mneblett's Avatar
T25, too.
Mark Neblett
Fairfax, VA
mneblett is offline
post #7 of 7 Old Nov 27th, 2005, 1:20 am
mneblett's Avatar
Agreed -- even with my electric screwdriver clutch set at the lowest setting, I _never_ start an LT screw with the electric motor -- too easy to crossthread. A couple manual turns to ensure proper thread engagement, then hit the go button. And I do not hold the driver firmly -- a very loose three-finger grip lets the driver rotate backwards without resistance if the screw unexpectedly stops turning, avoiding excess torque.
Mark Neblett
Fairfax, VA
mneblett is offline
Final Drive murray K1200LT 22 Sep 28th, 2008 10:02 am
