radio control switch - BMW Luxury Touring Community
post #1 of 5 Old Nov 26th, 2005, 12:49 pm Thread Starter
omurphy's Avatar
i'm having difficulty removing the radio remote switch from the clutch lever assembly. i'm attempting to get to the clutch switch for the cruise control. i believe the clutch switch is sticking as pushing out on the clutch lever would allow me to engage cruise although that won't work now. i have removed the two screws below the radio switch as well as the one in front of the switch. these are the screws shown in the repair manual. can anyone help me? any help at all is appreciated. thank you very much. omurphy
omurphy is offline
post #2 of 5 Old Nov 26th, 2005, 1:42 pm
Zeke's Avatar
switch trouble
I've had the same trouble. But as I remember you can loosen the small screws that hold the switch and move it slightly back to get the microswitch away from the lever. Mine does this twice in 3 yrs always works for me. You can also spray a very small amount of wd40 on it or what ever you have that will work with electric parts.
Zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #3 of 5 Old Nov 27th, 2005, 6:58 am Thread Starter
omurphy's Avatar
Question problem
the problem in part is that i don't know where any of the parts are located with in the clutch lever housing. can anyone tell me with respect to another part i can see where the cruise control clutch switch is located? say for example with respect to the two allen screws on the bottom of the radio remote control, is the switch located on the outboard side forward or aft? which way should i direct the contact cleaner or wd40 so that it will penetrate the cruise control switch? also wd40 will affect the rubber on the handle bar grip, it seems that contact cleaner would also affect it, is that so? is there a better way or back to my original question how do i get the radio remote switch on the handle bar off so that i can proceed to get at the clutch cruise control switch. it may be that the cruise switch is loose within the clutch lever assembly. i was able to get the cruise to come on briefly yesterday after i posted my question and i had to literally hold the clutch lever in the forward position.thanks omurphy
omurphy is offline
post #4 of 5 Old Nov 27th, 2005, 8:53 am
grifscoots's Avatar
look at #11
-=grif=-
Grok
grifscoots is offline
post #5 of 5 Old Nov 27th, 2005, 9:14 am
WD40 isn't the best choice as a lubricant or a cleaner. "WD" stands for water displacement. Use it to protect stuff like fishing reels, etc from moisture damage. People use is as a lube all the time, but it dries to a sticky film and attracts dirt.
I actually doubt that either WD40 or contact cleaner would do any harm to rubber.
I'd pick a spray of something designed to clean or lubricate, or both.
CriticalMass is offline
cruise control switch sheldan2 K1200LT 8 Jun 27th, 2011 10:23 am
Creative Jukebox Zen Micro: ice link type control hammick iPod/MP3 6 Mar 16th, 2008 11:11 am
Need to remove the radio control panel Harby K1200LT 4 Sep 3rd, 2007 7:29 am
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 4:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 10:38 am
