now for something different: front fender failure - BMW Luxury Touring Community
post #1 of 19 Old Nov 25th, 2005, 8:53 am Thread Starter
docwagner's Avatar
Put 550 miles on the LT on Wednesday (day before turkey day), drove to Philadelphia, BTW saw only 3 other bikers I guess 40 degrees was too cold for most. Anyway got off I95 and heard something strange from the front and saw shadows in the headlight beam. Turns out my front fender is hanging off to the side, three of four bolts are missing and the fourth is loose and about to fall out. I unscrewed the last bolt, put the fender on the back seat and continued on wondering how that could of happened. Never touched a bolt on the fender before. I guess I'm wondering if the dealer, when replacing my front tire removed the front fender and didn't tighten the screws. The fender is damaged and most likely will need replacing. Does anyone know if these can be bought prepainted or just in primer?
Adversity builds character.
BMW MOA #: 115771
My rides: '01 K1200LT Black (of course)
'00 BMW 540i (also black)
'76 Toyota Landcruiser FJ40 (not black)
'06 Toyota Landcruiser (black again)
docwagner is offline
post #2 of 19 Old Nov 25th, 2005, 10:01 am
when i bought my bike the dealer told me to keep an eye on the fender bolts. so it's not an unknown issue.
KBandit is offline
post #3 of 19 Old Nov 25th, 2005, 10:27 am
All painted parts are listed by part number according to color. Dealer has to order them pre-painted.
When my favorite dealer was also a BMW car dealer, they were going to re-paint one of my mirrors that was scratched at delivery, but said if I did not mind waiting a couple weeks for one from Germany they would rather replace it, because even though their paint shop was really good, they were afraid it may not be a perfect match. I waited.
post #4 of 19 Old Nov 25th, 2005, 1:57 pm
rspyder's Avatar
I had the dealer put on new tires and they did not even come close to tightening the front fender bolts. They were just started.
Current
2016 Yamaha FJR1300A (Cobalt Blue)
1973 Honda CL350 (Red)
Previous
2001 K1200LT Pacific Blue
and a long list...
rspyder is offline
post #5 of 19 Old Nov 25th, 2005, 2:18 pm
Why would they remove the fender?
Big_E is offline
post #6 of 19 Old Nov 25th, 2005, 2:42 pm
rspyder's Avatar
That is the standard way of removing the front wheel. It is in the shop manual. Unless your front wheel is hanging high, that is the only way to get the wheel out.
Current
Previous
and a long list...
rspyder is offline
post #7 of 19 Old Nov 25th, 2005, 3:04 pm
EdBruce's Avatar
Peter...
I think this is the part number for your Fender 46 63 7 657 663
Price is somewhere between $190-$200 painted
Check the part number just to be sure though
Cheers
Ed
___________________________________________
Ed Bruce
EdBruce is offline
post #8 of 19 Old Nov 25th, 2005, 5:36 pm Thread Starter
docwagner's Avatar
Thanks guys, I'll add "check tightness of the front fender screws" to my pre-flight check list. One more expensive mistake.
I did look on the parts list from one of the dealers and found only primer gray listed. I will look again with this other part number.
Thanks again.
BMW MOA #: 115771
post #9 of 19 Old Nov 25th, 2005, 6:35 pm
I removed my front wheel twice so far, on the centerstand without removing the fender, never saw a need to. Maybe I did it wrong?
Big_E is offline
post #10 of 19 Old Nov 25th, 2005, 6:41 pm
I had a 01 LT and had problem with the front fender, however only 2 bolts were loose so I was able to notice it before it came loose. I think something was done in later models to prevent this.
Leon
Blue 05 LT
RideIt is offline
post #11 of 19 Old Nov 25th, 2005, 7:11 pm
Cool Why? . . . Why not?
With the front fender being held on by only 4 bolts . . . I think it's a no-brainer to simply get the thing out of the way. Makes for a much easier job in the long run.
post #12 of 19 Old Nov 25th, 2005, 7:26 pm
Special fender bolts
Be sure you get the correct bolts for the front fender. The correct bolts have a nylon locking patch. They are only good for a few uses before they should be replaced. Most dealers will not replace them unless told to.
Chuck Swenson,
Sioux City, IA
2010 R1200RT Low with ESA2!
2005 LT
iowalt is offline
post #13 of 19 Old Nov 25th, 2005, 11:52 pm Thread Starter
docwagner's Avatar
Thanks for that heads up. I looked on the web, but didn't see any locking patches. I will call my dealer when I get homw. In the meantine I have gone to Home Depot and have some parts that hopefully will get me home.
BMW MOA #: 115771
post #14 of 19 Old Nov 25th, 2005, 11:58 pm
I must be missing something, it was never in the way.
Big_E is offline
post #15 of 19 Old Nov 26th, 2005, 12:10 am
used finder
Look here http://www.beemerboneyard.com/newparts.html also goog price on oil filters and spark plugs
bigfoot.nolan is offline
post #16 of 19 Old Nov 26th, 2005, 1:35 am
how badly damaged is the front fender?
it might be able to be repaired with some jb weld and fly gauze from underneath rather then where it is painted.
Dezrae is offline
post #17 of 19 Old Nov 26th, 2005, 7:46 am
FredR's Avatar
This was a known problem on the RT, so now I have to watch for it on the LT as well. Guess I am going to have to make a pre-ride checklist. Thanks for the headsup.
Fred Rosenbaum
NF1U
2006 K1200LT Totaled
2005 R1200GS
FredR is offline
post #18 of 19 Old Nov 26th, 2005, 8:41 am Thread Starter
docwagner's Avatar
Wells, it looks like it had been laying down on the tire for awhile so it wore away alot of plastic, then when it finally let loose it got dented. For me the easy solution is to just replace it, but thanks for the idea.
BMW MOA #: 115771
post #19 of 19 Old Nov 27th, 2005, 5:22 pm
LJSMITH1's Avatar
You can use Loctite #242 for the bolts and that should hold them good...
2005 BMW K1200LT Blue
BMWMOA #124788
Predecessor:
1999 K1200LT (entered the BMW "organ donation program" on 6/2/11) 38,256 Miles
LJSMITH1 is offline
K1200LT Bridgestone BT020R 160/70R-17 tire failure survey mudman Tires 42 Aug 11th, 2013 12:55 pm
Rear or Final Drive Failure fitzy79 Australia, New Zealand, and AsiaPac 33 Jan 3rd, 2012 8:25 pm
Dreaded front end shake RMW K1200LT 100 Aug 31st, 2007 11:13 pm
Bridgestone BT020R 160/70R-17 tire failure. mudman Tires 23 Aug 28th, 2006 3:36 am
2nd Rear Drive Failure jpalamaro K1200LT 9 Oct 24th, 2005 12:58 pm
