Just bought a 1999 K1200lt-need advice - BMW Luxury Touring Community
post #1 of 5 Old Nov 23rd, 2005, 8:20 am Thread Starter
I have owned a few Bmws but the K1200Lt is new to me. It is a 1999 with 11,000 miles on it. I bought it from a dealer(its still there) and I wanted advice on what service I should ask the dealer for? I still can work out a few details with the purchase. Is there a 10,000 mile service? When I leave what service should I be looking for. I have asked for the service records and should see them soon. thanks Jim
jbuffalo is offline
post #2 of 5 Old Nov 23rd, 2005, 12:22 pm
BecketMa's Avatar
Make sure the skid plate has been installed.
99s came with a defective starter relay, they fuse closed when the battery voltage drops. BMW came out with a replacement relay.
99s came with a defective designed computer chip. When temps hit mid 80s, the engine hesitates. BMW came out with reprogrammed chips to correct this.
Note: the speedo, by design, reads higher than actual speed. .9 times reading is close to your actual speed. Speedo can be moded to be accurate.
If the 99 wasnít ordered with heated seats, the wiring harness doesnít come with a plug for a heated seat.
Many people replace the low beam with a HID. My low beam was good for about 30mph.
Have FUN with your new ride.
bob
BecketMa is offline
post #3 of 5 Old Nov 23rd, 2005, 12:28 pm
Super Moderator
DavidTaylor's Avatar
12,000 service and an annual could be negotiated.
Also check to make sure the brake & cooling systems have been flushed.
Make sure the clutch fluuid gets flushed, too.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #4 of 5 Old Nov 23rd, 2005, 1:17 pm
Thumbs up
You will also notice that informal tech sessions are held regularly in several areas of the US. If you fill in you member info, we might be able to point you toward one of these tech sessions. They are usually posted on the regional boards.
Welcome aboard!
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
post #5 of 5 Old Nov 23rd, 2005, 1:25 pm
Since it is a '99, have the dealer insure that the radio was updated with the later firmware. Early '99's had an issue with the radio running the battery down even if turned off. A firmware change was made to correct it, radios had to be swapped out with ones that had been upgraded.
Baehr intercom users for K1200LT model advice. edonthenet Intercom, CB, & 2-Way Radios 5 Mar 6th, 2011 3:03 am
Bought an R1200RT Yesterday any advice? Brucev RT Series 24 May 24th, 2006 3:34 am
1999 K1200LT input requested yamalude K1200LT 13 Nov 4th, 2005 6:26 pm
