ABS lights flashing side by side - BMW Luxury Touring Community
post #1 of 16 Old Aug 2nd, 2007, 11:00 am Thread Starter
jac
jac's Avatar
after a up hill stop sign, the ABS start to flash side by side. turn OFF/ON engine by key, the problem still there.
back home check the break fluid level, front one slightly blow the minimum. top up with DOT4, start engine the problem still there.
restart engine by kill switch and key when moving, the problem still there. test the battery = 12.87V (17 months old BMW battery), eventhough, put a brand new PC680MJ battery, the problem still there.
is this code have to be reset by dealer? any idea? please help.
Jack Z
DeMarest, New Jersey
1999 BMW K1200LTC
1981 Kawasaki GTO125
1979 Suzuki A100
jac is offline
post #2 of 16 Old Aug 2nd, 2007, 11:59 am
mtrevelino's Avatar
It will have to be reset by the dealer. Fluid level should not matter in your year bike.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 16 Old Aug 2nd, 2007, 12:26 pm
ABS reset
I had the same problem with my 2000LT a short time ago. Top off both brake reseviors, unhook the battery for over a half an hour and yes, take it to the dealer to be re-set. I explained the issue to the dealer in my area (A&S powersports in Roseburg) and they reset it for me at no cost. I hope you have the same luck, it is a little un-nerving to have it happen as the replacement cost is over $1800.00. Good Luck
jtlind1999 is offline
post #4 of 16 Old Aug 2nd, 2007, 1:31 pm
grifscoots's Avatar
Your '99 only has one rear reservoir.
Before going to the dealer, clean and check the gap on your ABS Sensors. Mine did what your's is doing and stopped after I check the gap and shimmed to correcto.
-=grif=-
Grok
grifscoots is offline
post #5 of 16 Old Aug 3rd, 2007, 12:33 pm Thread Starter
jac
jac's Avatar
it's possible caused by break lights ? because there are three running lights but only left and right lights ON when breaking. is this OK?
Jack Z
1999 BMW K1200LTC
1979 Suzuki A100
jac is offline
post #6 of 16 Old Aug 3rd, 2007, 2:40 pm
grifscoots's Avatar
The "99's brake lights aren't monitored, so that isn't it.
-=grif=-
Grok
post #7 of 16 Old Aug 3rd, 2007, 10:38 pm
munson's Avatar
My 01 bike was like that, and I added a jumper wire to make it a brake/running light. I think your problem is going to be in the sensors. Check those gaps and let us know if that fixes it.
Blessings!
munson+
The Rev. John Munson
Vicar,
, Burkburnett, Texas
Vicar,
, Wichita Falls, Texas
2007 R1200RT "REV ZM"
IRON BUTT ASSOC. #37813
See my video:
munson is offline
post #8 of 16 Old Aug 3rd, 2007, 10:45 pm
That is normal operation Jack. Usually on the early ABS II the only two things that cause a fault is the sensors (running the rear tire in the air after the drive off check) or the brain itself. If the sensors are OK then often a full flush of fluid and a rest by the dealer will clear the fault.
post #9 of 16 Old Aug 6th, 2007, 9:08 am Thread Starter
jac
jac's Avatar
No luck, the cord shows hydraulic assembly need to be exchanged which raises my major concerns to the quality of BMW bike. Such high end motorcycle run only 25,000 miles then will spend $x,xxx to replace the main parts. Itís very unhappy ending.
Jack Z
1999 BMW K1200LTC
1979 Suzuki A100
jac is offline
post #10 of 16 Old Aug 6th, 2007, 9:16 am
By now a 99 model should have had three full brake fluid flushes performed regardless of mileage. That is (or lack of that ) what usually takes out the unit.
I would have them do a full flush then attempt a reset. many have recovered with this technique.
post #11 of 16 Old Aug 6th, 2007, 9:26 am
ABS reset
I had the same problem with my 2000LT. When I took it to the dealer, it showed a Hydo fault, but when I flushed the system, front and back and then had them reset it again. The fault cleared. Dealer said any small particle can cause the fault. I would try the full flush (if you haven't already) before forking over major $ for the ABS II unit. Beemerboneyard has them used from time to time, but I haven't seen one there in months. Just my .02. Good Luck.
post #12 of 16 Old Aug 8th, 2007, 10:56 am Thread Starter
jac
jac's Avatar
I will flush break fluid (this is my first time). I found there is only one bleeder in front break on the left. But right side there is a big screw in the position for bleeder, what is that for? Do I have to do some thing when flushing the front break fluid?
Please help.
Jack Z
1999 BMW K1200LTC
1979 Suzuki A100
jac is offline
post #13 of 16 Old Aug 8th, 2007, 12:42 pm
mtrevelino's Avatar
I will flush break fluid (this is my first time). I found there is only one bleeder in front break on the left. But right side there is a big screw in the position for bleeder, what is that for? Do I have to do some thing when flushing the front break fluid? Please help.
That is the factory fill fitting. You will need to carefully remove it and replace it with a 10x1 (?) bleeder fitting or a speed bleeder fitting. You will also find one of those big screws at the clutch bleed fitting. **Please note that I said "carefully" remove the fitting. The best thing to do is heat it with a hair blower so that it will easily remove. This will loosen the locktite Since you have a 99LT, you can let gravity to bleed the system, just open the bleed fitting and make sure it does not run out of fluid.
Mike Trevelino
Williamsburg, VA
2008 RT
post #14 of 16 Old Aug 8th, 2007, 12:56 pm
munson's Avatar
Please help.
As Mike said, you can remove that fitting, but some have had a devil of a time doing it. An easier way is to buy a one speed bleeder, SB1010S, I believe, and use the OE bleeder in the big fitting. Remove the little Allen head cap. The fitting has a ball check valve, and the flat tip of the OE bleeder will push it in. You would screw it all the way in, then back it out a quarter turn to bleed. Remove it when finished, and replace the little cap. The same procedure will work on the clutch fitting. Have fun!
Blessings!
munson+
Vicar,
Vicar,
See my video:
munson is offline
post #15 of 16 Old Aug 14th, 2007, 9:59 am Thread Starter
jac
jac's Avatar
I am ready to replace the hydro pump module. I brought a used one for the same year of model with 35K mile. Any tips for installation? Do I have to fill up with DOT4 to the pump before to hook up those pipes from F/R breaks? Thanks
Jack Z
1999 BMW K1200LTC
1979 Suzuki A100
jac is offline
post #16 of 16 Old Aug 14th, 2007, 4:03 pm
I had the same problem with my 2000 LT. Did a brake flush and put in a new battery, had the dealer reset the default and now it is working. So far about 3500 miles since that was done. I am gonna keep my fingers crossed.
jrlakin is offline
ABS lights flashing .. checked everything! GWE K1200LT 30 Mar 26th, 2009 10:16 pm
ABS Lights are flashing alternately nocanpickem K1200LT 12 Jun 13th, 2007 7:51 pm
Flashing ABS lights budzee K1200LT 8 Aug 18th, 2006 10:48 am
Them flashing ABS lights SilverBuffalo Chit Chat 4 May 14th, 2006 6:52 pm
