Can't get to Battery! - BMW Luxury Touring Community
post #1 of 15 Old Nov 19th, 2005, 1:07 pm Thread Starter
I let my battery run down , and know can't access the + side there is this sleeve with a rod in the way rightover the top of the battery, I just ends at the rear fender, no idea what it is, there is nothing in the manuals, I'm go to try and post a pic. please help its 75 degrees and I cant ride.
Thanks for any help in advance.
Tony
ID:	797   Click image for larger version
Tony_ag is offline
post #2 of 15 Old Nov 19th, 2005, 1:15 pm
Chipper's Avatar
Does not look like anything I have seen before. Looks like it was placed there maybe by a previous owner. Maybe it is some sort of breaker bar?????
Just grab it and pull it out from the pictures it looks like its just wedged in...
Good luck, when you get it out tell us what it turned out being......
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
2004 RTP Work Bike(Retired)
2002 LTE Totaled Aug/2011)
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #3 of 15 Old Nov 19th, 2005, 1:42 pm
Looks like a night stick or something. Weird. You can't just pull it outta there?
post #4 of 15 Old Nov 19th, 2005, 1:52 pm Thread Starter
Mystery Bar
I't sort of unscrews but it hits the rear inner fender, It looks stock, there is some kind of lever at the end towards the tank. This is nuts!
Tony
Tony_ag is offline
post #5 of 15 Old Nov 19th, 2005, 1:56 pm
mwnahas's Avatar
What the heck?? I don't have one of those. Whatever it is. Jeeze let us know what is is once you figure it out.
Just Go
Cleveland Ohio
mwnahas is offline
post #6 of 15 Old Nov 19th, 2005, 2:02 pm
That is a strange one! I have seen under the seat on a LOT of LTs, but never anything like that. It surely is nothing factory installed.
post #7 of 15 Old Nov 19th, 2005, 2:44 pm
Lynn_Keen's Avatar
Looks like may be a fancy bicycle tire type pump for inflating your tires or maybe a foot long maglite flashlight. This surely is not an OEM part. If you know who owned the bike before you I'd give them a call. Good luck and let us know once you solve the mystery.
Lynn Keen
North East Florida
MSF #28271 Retired
'01 R1150 GS- totaled
'02 R1150 GS sold
'85 K100/EML sidecar sold
Lynn_Keen is offline
post #8 of 15 Old Nov 19th, 2005, 3:15 pm
gunny's Avatar
Drive shaft for front wheel drive? Tail rotor drive? Torque compensator? Light saber?
gunny is offline
post #9 of 15 Old Nov 19th, 2005, 3:27 pm Thread Starter
Got it!
Darn thing turned out to be some sort colapsable walkinf stick? our Baton, it had these locking tabs on it that probably everytime the brakes were engaged it would expand.. That was wierd?
Let me know if you all need a picture of the, "under the seat beast"
Thanks for the input, some very funny.
Tony
Tony_ag is offline
post #10 of 15 Old Nov 19th, 2005, 3:51 pm
BecketMa's Avatar
Now that you've got it out, time to have it chromed.
Ooops. Wrong bike forum.
BecketMa is offline
post #11 of 15 Old Nov 19th, 2005, 4:50 pm
mneblett's Avatar
Tony
My guess is that it's part of a subframe for a sidecar frame -- any other signs of a side car in the body wok? Lower mounting point holes in the fairing?
Mark Neblett
Fairfax, VA
mneblett is offline
post #12 of 15 Old Nov 19th, 2005, 5:28 pm Thread Starter
Now What
Geez! I guess that I'm used to my Honda XR650L, It doesn't work , smack it and runs like crazy. Since I removed the Baton? Charged the battery, it wont start, I hit the starter button (with all nec functions done) and all that happens is a slight click, How can anything break by just sitting in a garage? I did check to see if the Baton? pulled anything loose, nothing I can see.
This is making me crazy.
I checked all the stuff in the owners manual under troubleshooting ,,,Nothing
In the Service manual in CD I cant find any trouble shooting.
Just venting ..Sorry
Tony
Tony_ag is offline
post #13 of 15 Old Nov 19th, 2005, 5:48 pm
Dead Battery
Just a guess but if that baton is metallic, looks by the pix like it shorted across the positive and negative battery posts when it was on the bike. Check out the positive battery protector to see if the baton penetrated the covering and shorted things out due to chaffing.
Hope this helps.
Chuck J
02 K1200LT (Black Beauty)
New friends make it all worthwhile!!! Smile, its catching.
ksailor is offline
post #14 of 15 Old Nov 19th, 2005, 5:51 pm
Remember the checklist:
  • Check kill switch
  • In neutral
  • Kickstand UP
  • NOT in reverse
  • Ignition ON
  • Clutch IN
No start...charge battery. HTH
post #15 of 15 Old Nov 19th, 2005, 10:48 pm
2Wheelroadtrip's Avatar
So that's where I was supposed to install the rear facing rocket tube? Or is it a frame brace to help keep the welds from cracking? Nope, that was the wing. Well I would just use one of them fancy cords and hook the charger up to the accessory outlet and let it charge. When the bad weather comes it would be time to tear that bar outa there and figure out if it's important or not. I hope you get to ride.
2Wheelroadtrip (Barney)
03 LTC
82 Aspencade
Time Out camper
It's not where we go. It's that we go.
The information from this site and its members has proven to be invaluable again.
2Wheelroadtrip is offline
Battery Concern please advise Hulkster Batteries, Chargers, & Electrical 8 Feb 6th, 2006 1:41 am
Battery Charger bugged Batteries, Chargers, & Electrical 4 Dec 11th, 2005 10:55 am
How NOT to treat your battery.... Zotter Batteries, Chargers, & Electrical 8 Nov 22nd, 2005 2:51 pm
Battery Cable - I got lucky! ytk K1200LT 1 Nov 18th, 2005 5:02 pm
