Clutch Slave Weep Hole - BMW Luxury Touring Community
post #1 of 5 Old Jul 22nd, 2007, 12:02 pm Thread Starter
donsobeck's Avatar
I just lost my clutch disc by fluid contamination so.
1. I want to drill the the weep hole and would like a picture so I can locate the hole.
2. The slave cylinder hole was loaded with oil as was the disc, it seemed like it was clutch oil but I am not sure. The trans seal at the slave cylinder could be bad?
3. Has anybody who drill the weep hole ever had oil leak out of it?
4. Any thought on the subject would help.
Thanks to all.
DON
donsobeck is offline
post #2 of 5 Old Jul 22nd, 2007, 2:24 pm
kevincook's Avatar
Don,
Sorry to hear about your trouble. All the information you need should be in the procedure found here: http://www.bmwlt.com/forums/showthre...nder+procedure
Good Luck,
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #3 of 5 Old Jul 22nd, 2007, 3:59 pm Thread Starter
donsobeck's Avatar
Kevin thanks much for the reply, just want I needed.
DON
post #4 of 5 Old Jul 22nd, 2007, 4:56 pm
cccpastorjack's Avatar
DON
Don,
When the clutch is replaced, I would replace ALL transmission seals at the same time. MANY clutches have been ruined by a leaking tranny input shaft seal (just in front of the Slave Cylinder).
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #5 of 5 Old Jul 22nd, 2007, 7:17 pm Thread Starter
donsobeck's Avatar
Jack: Thanks for the heads up, I am looking very close at that seal.
DON
Clutch Housing Weep Hole Photo Dean_BMW K1200LT 30 Jul 24th, 2011 5:14 pm
Is it time to start drilling TWO weep holes? Dean_BMW K1200LT 10 Dec 5th, 2007 6:29 pm
Clutch Slave Weep hole rd_gonz K1200LT 12 May 29th, 2007 12:07 pm
Clutch slave weep hole- how deep? FlyOrBike K1200LT 25 Mar 16th, 2007 3:30 pm
