SplitFire Spark Plugs - BMW Luxury Touring Community
post #1 of 13 Old Jun 21st, 2007, 3:12 pm Thread Starter
Jerrym's Avatar
I am tired of changing sparks plugs every 12,000 miles, which is about twice a year. I see where some of you are using SplitFire Triple Platinum plugs (TP416D). They say they are good for 50,000 miles. I sure do not want to screw my engine up is there any problem in using these plugs? I did order 4 of them today.
Jerry Mathison
Woodbine, Iowa
2008 Gold Wing
2005 Ocean Blue (Sold)
BMWMOA #25294
Jerrym is offline
post #2 of 13 Old Jun 21st, 2007, 5:02 pm
Ranger6's Avatar
I've been using them since I read a thread about them here about three years ago, and they're excellent. I think you'll like them. Take one or two out after 12k, take a look and you'll see what I mean.
Al Hennigan
'03 Anthracite LTE
'09 GS Adventure
Middle Tennessee
Ranger6 is offline
post #3 of 13 Old Jun 21st, 2007, 5:12 pm
Your results may vary, but these guys didnt see much.
http://www.ecotekplc.com/fast_bikes.htm
"RESULTS
We fitted them to the GSX-R - which was previously running standard NGK CR9Es -and it delivered a consistent 1bhp less in the upper rev-range.
MANUFACTURER COMMENTS
Splitfire Platinum plugs are extra sensitive to gap settings, and may need adjusting for the best results. These plugs are used by many top race teams, and have been tested extensively and successfully.'
VERDICT
Don't expect to drop them in and get instant gains. Gapping needs expertise and specialist tools.
NO GAIN"
Sofitel505 is offline
post #4 of 13 Old Jun 21st, 2007, 7:50 pm
Daveh's Avatar
I picked up a set of NGK Iridium plugs p/n DCPR7EIX that are spec'd for the LT and giving them a try. I got them at Advanced Auto Parts $6.95 each. Hopefully they will be the last set of plugs I'll purchase for the LT. They can also be ordered online at ngk.com or sparkplugs.com.
2003 K1200LTC Titan Silver
BMWBMW, BMWMOA, AMA, IBA
Daveh is offline
post #5 of 13 Old Jun 22nd, 2007, 1:57 am
If you'r tired changing every 12,000 miles, stop doing it. Any plug will go 50,000 or more. I changed my original plugs at 30,000 & they didn't look any differant than the new ones. 12,000 is old school, leaded gas days.
Big_E is offline
post #6 of 13 Old Jun 22nd, 2007, 9:46 am
I didn't change mine at the 24000 mile service. They pretty much looked new. However I do plan on changing then at the next interval (30000) and I plan on using split fire plugs. If they are good enough for Dave Shealey, they are good enough for me.
jrlakin is offline
post #7 of 13 Old Jun 22nd, 2007, 9:59 am
I tried these also. About 1,000 later I took them out and put the OEM back in. Bike did not seem to have the pep it had with the standard plugs. Just my opinion.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #8 of 13 Old Jun 22nd, 2007, 10:26 am
bluebeam's Avatar
I use them on my 91 Suz. GSX1100G, only because #1 cyl. has fouled out in the past after sitting for a day or two, complained to the dealer for months, finally bought some split fires and have not had a problem since,(years now) even this spring after sitting all winter, cranked maybe 5 seconds and popped right off, it runs VERY cold blooded but after a few minutes it was ready for a speed run!!
only have 2500 on my 06 LT sorry Im not much help on that.
Tom & Berta
THE EARLY BIRD MAY GET THE WORM
BUT ITS THE SECOND MOUSE THAT
GETS THE CHEEZE FROM THE TRAP!!
bluebeam is offline
post #9 of 13 Old Jun 22nd, 2007, 6:51 pm
Zotter's Avatar
When I did my 12K I changed out for new plugs - but the old ones looked great.
So, I kept 'em. I did some *very* light cleaning on 'em, checked the gap and when I do my 24K, they'll go back in.
I'll likely rotate the 8 of 'em that way until I see a reason not to.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #10 of 13 Old Jun 22nd, 2007, 7:07 pm Thread Starter
Jerrym's Avatar
I want to thank all you guys for coming back to me on the plugs. I have felt the same on the original plugs. At 12,000 they looked good but I did change them. The next time I went 19,300 and they looked good. I now have 14,000 miles on the third set. I do have a set of SplitFire on order, which I will change but I may wait for a while. It is like checking the values. I checked the valves at 12,000 miles and again at 31,000 miles. They were right on at 12,000 miles and had not changed at 31,000 miles. Is it necessary to check them now at 45,000 miles? The bike runs perfect. It seems to run better all the time.
Jerry Mathison
Woodbine, Iowa
2008 Gold Wing
BMWMOA #25294
Jerrym is offline
post #11 of 13 Old Jun 22nd, 2007, 10:05 pm
------------------------Is it necessary to check them now at 45,000 miles? The bike runs perfect. It seems to run better all the time.
I would not skip the checks, especially as the miles start getting higher. They WILL eventually start to need adjusting, and you cannot guess when this will start. By about 80,000, all my valves had been adjusted. If I remember correctly, the first needed adjustment was at the 45K check.
post #12 of 13 Old Jun 22nd, 2007, 10:14 pm
Sunshine's Avatar
So how can the splitfire spark plugs help anything? I just don't get it.....
Sunshine is offline
post #13 of 13 Old Jun 23rd, 2007, 7:55 am
Very long life, as any Platinum or Iridium tipped plug will do. Platinum on BOTH electrodes has the potential for longer life than just platinum on the center electrode, as many are. The SplitFire triple platinum has one platinum tip on the center electrode, two on the "split" ground electrode. A good many platinum or iridium plugs only have the wear prevention precious metal tips on the center electrode. As the sharp edges of the standard ground electrode wear rounded, it takes higher voltage to initate the spark. Voltage will initate a spark between two relatively sharp edges or points at a lower level than between rounded edges. One having a relatively sharp edge, as in platinum or iridium tips, is still much better than both being rounded, thus standard steel plugs do not last as long.
Just do not pay any attention at all to the advertised "performance" enhancement of any spark plug. Spark plugs either work good, or not, but there is little that can be done to make them work "better" than other good plugs, just longer.
Pulse spark plugs bflemingor K1200LT 13 Jun 21st, 2007 11:27 am
New tires, valve adjust, spark plugs, retiredjj K1200LT 3 Jun 7th, 2006 11:29 am
What About My Used Spark Plugs camtr K1200LT 6 Mar 29th, 2006 6:45 am
Spark plugs NOGILLS2 K1200LT 7 Dec 20th, 2005 3:22 am
Spark plugs SteveHebert K1200LT 6 Dec 10th, 2005 1:34 pm
