after I experienced a front brake line failure last month I purchased the Spiegler SS lines. So far I have installed the front only. I noticed quite a difference in the brake lever feel. You might also want to check your brake line just above the right caliper "T" where it makes a sharp bend, that's the spot where my hose blew out.
If any of you out there are noticing you are finding yourself grabbing the brake several times to get good pressure you might want to consider upgrading to the ss lines. I think they're coming standard on the new bikes now (my friend's 06 RT came with ss)
I purchased through chris at eurotechmotorsports.com, part number S-BM0140
