HID issue, maybe solved? - BMW Luxury Touring Community
post #1 of 3 Old May 26th, 2007, 8:09 am Thread Starter
emsweeney's Avatar
A while back I posted that my CQ-HID would not light everytime, without turning the ignition on and off a couple of time. I took everything apart to check tightness and all was ok.
I sent an email to the folks we arranged the group buy with and received back the following:
Thank you for your e-mail.
Some motorcycles are designed different. Thus, we will send you 1 x H7
special wire harness which to stable the electric current and it will solve
your problem.
The wire harness will be shipped out by May 25, 2007.
I will keep you all posted as to how this works.
Gene Sweeney
emsweeney is offline
post #2 of 3 Old May 26th, 2007, 10:42 am
petevandyke's Avatar
yeah, keep us posted, after about ten hours of installing, un-installing, installing, un-installing, cutting knuckles, cussing enough that my neighborhood homeowner's association fined me, I've put my HID kit in a box in my garage and gone back to my original bulb set-up, AFTER they said the problem "will be solved with an updated ballast that we will send you" which it didn't...
petevandyke is offline
post #3 of 3 Old May 26th, 2007, 10:22 pm
Check the relay
I had the same issue and changed the relay. Working great since!
SeaMarshal is offline
Just for you LT'ers installing the CQLight.ca HID kit! messenger13 Lighting 46 Sep 27th, 2010 11:10 pm
Happy with HID, just installed Motolights Crestwood330 Lighting 5 Jan 4th, 2008 5:41 am
HID Adjustment jwd98056 Lighting 5 Jan 13th, 2006 4:47 pm
MapSource lnowell GPS 8 Nov 9th, 2005 3:32 pm
