Baehr system non-connection - BMW Luxury Touring Community
post #1 of 3 Old May 22nd, 2007, 3:42 pm Thread Starter
I have a fairly new baehr system that went dead on the driver helmet only. I have eliminated problems down to the helmet system in my helmet. When I hook up to the bike it does not make contact so as to turn on the beahr and the bike radio off. All connections appear good and reading out the cord with a meter shows the same pin continuity on both good and bad helmets. Anyone else had a problem like this?
goober27 is offline
post #2 of 3 Old May 22nd, 2007, 5:17 pm
Question
Are you sure one of those little pins inside the connector isn't bent?
post #3 of 3 Old May 22nd, 2007, 5:44 pm
motorhead's Avatar
I too have had that issue, traced it back to loose connector/pin contacts.
Two of the pins do nothing more than loop hot lead in on one pin, out on another to turn the comm unit on/off.
To cure my trouble all I did was solder a small trace of solder within all the female ends of one connector. This done with a small PC board type pen tip soldering gun.
Been issue free now for 2 years. When small amount of solder wears away from use and trouble happens again, an easy fix doing the same once more
Scott
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
Still Having Problems w/the New Baehr hschisler Intercom, CB, & 2-Way Radios 7 Apr 25th, 2007 11:43 am
Baehr Com System need feedback hd2bmw Intercom, CB, & 2-Way Radios 14 Mar 7th, 2006 7:04 pm
Connection autocom headsets 2006 BMW com system jflaming Intercom, CB, & 2-Way Radios 1 Oct 31st, 2005 11:05 pm
