bike will not start - 2000 LT - BMW Luxury Touring Community
post #1 of 9 Old May 18th, 2007, 6:59 pm Thread Starter
darryldaggs's Avatar
Well I got my XM Roady XT hooked up and everything ready to go , put my helmet ,on threw my leg over the big girl ,turned the key on all my lights are check but then I hit the ignition and click click click.....
I checked the battery it was showing around 11v. I put my charger on it no luck. I even disconnected my roady, still click click click...... As i was messing around I turned the key off and the radio came on , good. I tried starting the bike and the radio (LT) went blank I am confused hurt and disappointed. anyone have any ideas at all? Oh yea when I turned the key on my computer temp gauge read - 22 F
So should I disconnect the battery for a long time , or is it time to remove the side panels and go a hunting? Or maybe could it be a fuse? HELP?
darryldaggs is offline
post #2 of 9 Old May 18th, 2007, 7:32 pm
The newer style starter relay is designed not to allow a start attempt with a low battery. 11 volts is close to the no go point. Charge your battery and try again.
mjordans2000 is offline
post #3 of 9 Old May 18th, 2007, 8:43 pm
tbarstow's Avatar
Darryl,
If your battery reads less than 14V after coming off of the charger, its time for a new battery.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #4 of 9 Old May 18th, 2007, 10:01 pm Thread Starter
will my battery charger work on my battery? I think I have a gel battery? The charger said it would charge gel batteries but I had some issues today. I had to plug the charger into a three prong extension cord then to a outlet, hmmm.... Well its charging now hopefully Jenny will start tomorrow. I have a BRP ride planned for Sunday I hope I can still make it. The battery has a date of 09/05 is that ready to go?
post #5 of 9 Old May 18th, 2007, 10:02 pm Thread Starter
Thanks for the help guys......cross your fingers
post #6 of 9 Old May 18th, 2007, 11:16 pm
Dean_BMW's Avatar
If it has been properly maintained, I wouldn't think so, but anything is possible.
Dean_BMW is offline
post #7 of 9 Old May 19th, 2007, 6:00 am
Newf's Avatar
A battery can go in one season. A battery does not like very hot or very cold temperatures. Just let it charge up and see if it holds the charge. If a battery is property maintained it can last 5-6 seasons. If you get more that that you have a very good battery.
Manny
Where is the nearest Tims?
Need to stay awake
Newf is offline
post #8 of 9 Old May 19th, 2007, 1:18 pm
Daman858's Avatar
Battery should show 12.8 volts or better after being off the chager for a while to get the big gal fire up!
Anything less and ya need a new one.
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #9 of 9 Old May 21st, 2007, 6:16 am Thread Starter
I got my problem worked out. The battery had a charge of 12.6 problem was , as I was told by Advance Auto man , that when I try to start the bike the volts should only drop 1.5-2.0 volts. My battery was dropping all the way down to 7.5-8.4 volts when trying to start. So he charged the battery for me on their charger since my charger will not work on a gel battery. Took the battery and "Jenn" fired up ready to roll. Also note the battery tested as a "Good" battery even though I was on the low power side of when starting the bike.
Bike Dropping - I Can Relate LarryRose K1200LT 48 Sep 22nd, 2018 11:19 am
HELP! Alarm went off now bike won't start! blavenia K1200LT 12 Jul 22nd, 2009 10:33 am
Lemon law bike for sale. Would you buy? edonthenet K1200LT 45 Aug 3rd, 2006 10:07 pm
