Polishing out windshield scratches? - BMW Luxury Touring Community
post #1 of 5 Old May 18th, 2007, 2:33 pm Thread Starter
Any suggestions re what to use to try and polish out light scratches in the windshield.
Looks like those on my shield have been caused by washing without sufficient water - ie very fine scratches across the whole external screen area.
It a BMW screen.
I've seen the Cee Bailey repair kit advertised - I'm in the UK but I'd imagine I can get one imported or buy over here.
All thoughts welcome.
jeremy
jeremy_gibson is offline
post #2 of 5 Old May 18th, 2007, 2:56 pm
The OEM shield has a thin protective layer on both sides that, once scratched, is unrepairable. I could be wrong . . . but I don't think so. That's the problem with polycarbonate shields. Acrylic shields can be polished.
post #3 of 5 Old May 18th, 2007, 5:59 pm
C. Buckman's Avatar
This is correct!
The only thing you will do with a fine cleaner/polish even with a pre-wax cleaner, is make what you thought was a noticeable problem a much larger one, then you'll try to make that mess better, then it's downhill from there. What your doing is removing the fine film Joe is referring to, that's on the OEM shields. Once that area is opened up wide enough then you'll be polishing the actual w/s. By then, you've got an area that is 1/16" to 1/8" wide and 3/16" to 5/16" longer than your original scratch was to begin with. Trust me leave it alone!
Jerry
2004 K1200LTC Night Black
C. Buckman is offline
post #4 of 5 Old May 19th, 2007, 6:08 am Thread Starter
Both,
Thanks for your good advice, I'll leave well alone.
I acquired this screen recently in a swap, mine had no marks but this one has the slight scratches I referred to.
Regards
j
post #5 of 5 Old May 21st, 2007, 8:59 am
You might try Novus Plastic polish, available in 3 grades I think. May work or may not. As the others said, if it's the BMW shield with the fine film laminate on it, it will only get worse.
Randy
rando is offline
Ztechnik VStream Windshield. 2nd review strsout Ergonomics & Rider Comfort 33 Dec 31st, 2010 9:30 am
Windshield Arms = No Warranty? deputy5211 Bike Talk 25 Mar 26th, 2007 5:12 pm
Windshield peeling BillCav K1200LT 8 Jul 26th, 2006 3:27 pm
Windshield Crack - Overtightening - Caution bman28 K1200LT 1 Mar 27th, 2006 4:36 pm
New Cee Bailey Windshield -- My Report hschisler Ergonomics & Rider Comfort 7 Mar 26th, 2006 3:23 pm
