Loss of brake- Front handlebar - BMW Luxury Touring Community
 3Likes
  • 1 Post By jzeiler
  • 1 Post By cws
  • 1 Post By fatbob307
post #1 of 25 Old May 23rd, 2020, 1:42 pm Thread Starter
Angry Loss of brake- Front handlebar
As I was backing out my K1200LT '03 onto my driveway (and slopes down to the street), engine off, I went to pull on the front handle brake, and there was no braking. I tried to push the back brake and it wasn't enough to stop the bike and it fell over on its side. I've never had this problem before with the front brake handle before. I know I have to have a forward rotation on the front tire to activate the ABS.
The dealer recommends a brake flush maybe thinking there is contaminate in the fluid. Any hints? Is this the route I need to take?
When I started the bike to leave, the braking system acted normal.
Gdrdocbmw is offline
post #2 of 25 Old May 23rd, 2020, 1:50 pm
Patric's Avatar
Re: Loss of brake- Front handlebar
hi , what model motorcycle do you have ? Does it have the power brakes?
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #3 of 25 Old May 23rd, 2020, 2:13 pm Thread Starter
K1200LT '03
post #4 of 25 Old May 23rd, 2020, 2:44 pm
I've never had that happen on my 06 and I'm always moving it around without it running. Is your brake fluid low at the handle bar? Do you have original brake lines?
Troy F is offline
post #5 of 25 Old May 23rd, 2020, 3:11 pm
The servo brakes are very hard to use with the key OFF, it only offers residual braking. Next time just turn the key and move the bike.
beech likes this.
post #6 of 25 Old May 23rd, 2020, 4:43 pm Thread Starter
Thanks for the reply, Troy. The fluid was low and a bit dirty so I'm gonna get the bleed. Yes, the brake lines are original.
post #7 of 25 Old May 23rd, 2020, 4:44 pm Thread Starter
JZ: Thanks for the reply. Until I can get this bike in for a brake bleed, I'm gonna start the bike up and active the ABS, then back it out with the clutch.
post #8 of 25 Old May 23rd, 2020, 6:53 pm
You really need to consider changing the brake lines over to Spieglers... before you have real big problems. 🤔
Voyager likes this.
post #9 of 25 Old May 23rd, 2020, 9:01 pm
Originally Posted by Gdrdocbmw View Post
K1200LT '03
You are asking for trouble running on 17 year-old rubber hoses. I’d replace them with Spieglers before doing the fluid change.
post #10 of 25 Old May 23rd, 2020, 10:42 pm
Daza's Avatar
I too am running 17 year old rubber brake lines. Any info on the Spieglers? Is there a "kit" for the LT on line?
I'll have to search Australia as the Australian Post Office is not accepting any parcels from the US at the moment. I have three parcels stuck in the Chicago Distribution Centre that aren't moving for this reason. The Australian parcel system is way overloaded from everyone shopping on-line during lockdown.
Daz
Never take life too seriously, nobody gets out alive anyway…..
Black (03) LT
Matching Uni-Go
Ulysses Member 30740
Growing Old Disgracefully.....
Daza is offline
post #11 of 25 Old May 24th, 2020, 12:28 am
fatbob307's Avatar
Speigler sells their kit directly or thru Beemer Boneyard. It’s a must for bikes as old as ours.
Voyager likes this.
Bob Lower
Casper, WY
'01 K1200LT
'03 R1150 RT
'13 R1200GS
'79 R100T w/Hack
'10 Triumph Thunderbird
'09 Triumph Bonneville
'07 Guzzi Norge
'88 HD FLHS
fatbob307 is offline
post #12 of 25 Old May 24th, 2020, 6:03 am
I have no idea as to availability down under, but I bought mine here. The main reason I used STG is that their price was comparable to other vendors, but they have the added advantage of including new banjo bolts color matched to the fitting color you select. They did send me two of the wrong size bolts and that took a couple of weeks to get sorted, but I was pretty happy with their kit overall.
https://www.sportbiketrackgear.com/s...-abs-integral/
post #13 of 25 Old May 25th, 2020, 5:21 am
I replaced mine a coupe of years ago and from memory I got them off ebay. The kit was well made and everything was labelled so you couldn't mess up which line went where.
Gives you piece of mind and it's money well spent.
Wazza is online now
post #14 of 25 Old May 25th, 2020, 5:23 am
Oh and I never shift my bike unless the engine is running and I'm on it. I want maximum control over this beast.
Wazza is online now
post #15 of 25 Old May 25th, 2020, 7:07 am
Daza's Avatar
Ordered the Spiegler set today from the US. The company I ordered through told me USPS will not accept parcels to Australia, but the company will courier them to Aus. for US$35.
Happy days.
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #16 of 25 Old May 25th, 2020, 7:57 am Thread Starter
Daza: Do yo have the part number for the kit your ordered?
post #17 of 25 Old May 25th, 2020, 7:58 am Thread Starter
Wazza: How far do you have the move forward to activate the ABS?
post #18 of 25 Old May 25th, 2020, 8:03 am Thread Starter
Voyager: My only hesitancy is the cost of the kit, and then the bleeding of the system through the ABS module. Not trying to be complacent and not dismissing your suggestion, but so far, I don't have any leaks on these lines and haven't had any problems on this system, yet.
post #19 of 25 Old May 25th, 2020, 9:49 am
The servo brakes will operate fully after the first self test where it goes from fast flash to slow flash. The lights go out after the rolling test of the wheel sensors and only take a few feet of movement. ABS is only activated when you are hard braking and a wheel begins to lock up.
post #20 of 25 Old May 25th, 2020, 6:27 pm
Daza's Avatar
I ordered from Revzilla - Item: P358892 SKU: 1179435
US$245.95
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #21 of 25 Old May 27th, 2020, 7:01 am Thread Starter
JZ: OK.. Thank you for the reply. MY unsolved thought still remains is why the brake handle went full travel and loss of braking when I backed out. This never happened before and still wondering why. I'm now going for replacing the liners and have the dealer do the bleed.
post #22 of 25 Old May 27th, 2020, 10:47 am
Just so we are no the same plane here, when you backed out was the key on and the engine running? Was it key off? It make a big difference.
post #23 of 25 Old May 27th, 2020, 5:47 pm
Axle's Avatar
probably not what happened to you but a thought, I replaced the front pads and forgot to activate the brakes before backing out of the shed key off, same as you million miles an hour backwards no brakes engine off fell arse over tit backwards.... Laying the bike down going backwards is no fun. I never move it now unless the ignition is on.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #24 of 25 Old May 29th, 2020, 2:40 pm Thread Starter
JZ: No.. the key was off. But, now after you previous comment, I do now have the key on
post #25 of 25 Old May 29th, 2020, 2:41 pm Thread Starter
Axle: Yea, I now have the key on as a minimum. I'm now starting the engine and using the clutch as well to slow the bike on my driveway on the downward slope.
