2003 LT with Warning and Brake Failure lights solid on - BMW Luxury Touring Community
 2Likes
  • 2 Post By Daza
post #1 of 10 Old May 15th, 2020, 12:09 am Thread Starter
Daza's Avatar
Haven’t posted for eons but need some help please. I’ve done some searching of the forum with no joy.
My LT with a build date10/03 has both the Warning Light and the Brake Failure light on solid from start up and while riding with the following –
Speedo not working
Cruise Control not working
Brake lights don’t work, and
Brake assist does not work
The brake servo pump does not run when I apply either brake.
I’ve checked all the fuses under the seat but I am now out of ideas.
Anyone experienced this or similar?
Daz
Never take life too seriously, nobody gets out alive anyway…..
Black (03) LT
Matching Uni-Go
Ulysses Member 30740
Growing Old Disgracefully.....
Daza is offline
post #2 of 10 Old May 15th, 2020, 11:26 am
Re: 2003 LT with Warning and Brake Failure lights solid on
Since that pattern of light does NOT appear in the failure guide and that the speedo, cruise and brake lights are not working (which all run through the ABS) it sounds like your unit is DOA. Could be caused by some corrosion on the big connector to the ABS. You could try "jacking" the connector a few times (remove and install). It is fairly easy to get to on a 2003, just stick a screw driver in the rounded end and lever it out wards and it will lift the connector off the unit. Reverse to install. If that does not produce a change I am afraid you ABS brain is dead.
post #3 of 10 Old May 15th, 2020, 5:53 pm Thread Starter
Daza's Avatar
Hmm... doesn't sound good.
I've read on the forum about the Second Life Kit but couldn't find any other information on it through the search feature.
Has anyone installed one?
My LT is low milage and in very good condition but useless until I find a solution.
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #4 of 10 Old May 15th, 2020, 10:08 pm
Yeah the second life kit is a German product, pretty pricey as well (699.0 euros). Here is a link to the web site: https://shop.rhelectronics.de/shop/p...e-kit/?lang=en
You may be able to get a "Brain" out of a wrecked bike ABS unit.
post #5 of 10 Old May 15th, 2020, 11:19 pm Thread Starter
Daza's Avatar
Thanks, appreciated.
I've sent them an e-mail to see if they'll sent to Australia and shipping costs. Waiting....
Anyone got a ABS brain they'd be happy to part with for some $$$?
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #6 of 10 Old May 23rd, 2020, 6:23 am Thread Starter
Daza's Avatar
After reading some of the older posts on farkles (spurred on by Ari's return), I now realise why my ABS failed - I don't have a gremlin bell.
I just ordered one on eBay, I'm not going to chance it again!
cws and davebullock like this.
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #7 of 10 Old May 23rd, 2020, 6:57 pm
Geez... maybe I should attach mine, instead of sitting on my bedside cupboard!!!
now I’ve jinxed myself, just as I’m about to bleed the brakes and ABS unit!
post #8 of 10 Old Yesterday, 10:41 am
The problem is the pressure sensors the will give the wrong input they are hard to repair I sent my abs module 2 times for repair no result. No I will bypass the system by emulator-abs first picture the pressure sensor second picture the bypass unit with modified electronics
ID:	157197   Click image for larger version
Name:	Screenshot_20200528-142806_Samsung Internet_1591026011734.jpg
hogen920 is offline
post #9 of 10 Old Yesterday, 10:58 pm Thread Starter
Daza's Avatar
Originally Posted by hogen920 View Post
. Now I will bypass the system by emulator-abs.......bypass unit with modified electronics
Is that the Second Life kit by RH Electronics? or another unit?
I'm waiting for the delivery of one from RH Electronics at the moment.... but the mail sucks right now.
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #10 of 10 Old Today, 6:36 am
SHIfTHEAD's Avatar
So they never got it to work? I thought there was a German shop the could rebuild them, even though it was quite pricey.
SHIfTHEAD is online now
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
