Rear Brake Disk "loose" - BMW Luxury Touring Community
post #1 of 6 Old May 14th, 2020, 7:56 am Thread Starter
drmajor's Avatar
03 LT- 55,000 miles.
Rear brake disk is"loose". Has been for a while. I can move it a small amount and it rattles/rings when I hit a bump or etc.
It appears to be riveted in. The "bolts/Rivits" do not have any torx or allan heads. I see no way to tighten.
Any thoughts on how to tighten???
Name:	BMW LT rear brake diskIMG_0665.jpg
ID:	156905   Click image for larger version
Name:	BMW LT rear brake diskIMG_0667.jpg
ID:	156907   Click image for larger version
Name:	BMW LT rear brake diskIMG_0674.jpg
ID:	156909   Click image for larger version
Name:	BMW LT rear brake diskIMG_0669.jpg
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
post #2 of 6 Old May 14th, 2020, 8:07 am
Re: Rear Brake Disk "loose"
Normal... search back through old posts for "cow bell". Best fix is to replace with an EBC rotor... there'll be many references on it.
post #3 of 6 Old May 14th, 2020, 8:11 am Thread Starter
drmajor's Avatar
How does the disk come off? Don't see how to remove it....
Is the EBC thicker?
I am trying to sell the bike, so $$ are really not a big option..
Is there a way to shim it?
David Major
Charleston, SC
-2003 LT
drmajor is offline
post #4 of 6 Old May 14th, 2020, 2:14 pm
That is normal it's a floating Rotor. All of your questions will be answered here. It's IllinoisBMWriders. He's pretty funny.
The Rear rotor is a lot cheaper than both front rotors when they start to ring on every bump.
150,000miles is offline
post #5 of 6 Old May 14th, 2020, 3:24 pm Thread Starter
drmajor's Avatar
Thank you...!
drmajor is offline
post #6 of 6 Old May 16th, 2020, 10:34 am
dukey33's Avatar
I stopped the ringing by covering the rivets with blue brake goo, aka disk brake pad anti-squeal. It thickens up to dampen the ring and is made to be used on brakes so it can take the heat. Works so far as I can tell. Cheap solution but takes as much labor as replacing it since I removed the rear rotor to apply the goop.
-2000 K1200LT
dukey33 is offline
