08 LT Overhaul Project - BMW Luxury Touring Community
 19Likes
  • 6 Post By saddleman
  • 3 Post By saddleman
  • 4 Post By saddleman
  • 1 Post By DanDiver
  • 1 Post By saddleman
  • 1 Post By james216
post #1 of 23 Old Apr 5th, 2020, 4:17 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Back in Sept. 2018 I bought a 2008 LT with 112,543 miles on it that the owner had started to part out. A hurricane was coming & it would have been completely flooded with salt water.
Since then I have been collecting the parts needed to repair and replace the needed parts to put it back together. I started working on it yesterday. After removing the body panels I washed & degreased everything.
I hope to finish it by the end of July. I have a buyer for it if it is ready the first of August. Because it will take awhile I hung the body panels up on the wall in my shop.
I'll try to document with pictures as I go along. First up check the engine. Today I checked valve lash, cranking compression & cylinder leak down.
There are four intake valves under the lash spec. & I'll try & set the lash on the loose side on all of the valves. The compression & leak down were great.
Name:	08 LT Project 003.JPG
ID:	156345   Click image for larger version
Name:	08 LT Project 002.JPG
ID:	156347   Click image for larger version
Name:	08 LT Project 011.JPG
ID:	156349   Click image for larger version
Name:	08 LT Project 005.JPG
ID:	156351   Click image for larger version
Name:	08 LT Project 006.JPG
Name:	08 LT Project 008.JPG
ID:	156355   Click image for larger version
Name:	08 LT Project 009.JPG
ID:	156357   Click image for larger version
Name:	08 LT Project 010.JPG
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #2 of 23 Old Apr 5th, 2020, 4:26 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Re: 08 LT Overhaul Project
This bike was on a home on the Intercoastal water way in North Carolina. It had the wrong spark plugs in it and the spark plug wires did not grip the plugs tight. The corrosion from the salt air is evident in these pictures because the contact wasn't like it would have been with the proper spark plugs.
Name:	08 LT Project 004.JPG
ID:	156361   Click image for larger version
Name:	08 LT Project 007.JPG
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #3 of 23 Old Apr 6th, 2020, 11:44 am
james216's Avatar
Oh yea. I see the plug tips. Well. Nice project though.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #4 of 23 Old Apr 8th, 2020, 9:06 am Thread Starter
Enjoy The Ride
saddleman's Avatar
It has a failed ABS unit the rear servo does not work. Yesterday I installed new Speigler brake lines. I flushed the whole system with over a quart of new brake fluid. I wanted to get all of the old fluid & the small rubber brake line particles out before I install the next ABS unit.
I used a syringe to refill the brake system. I was able to power bleed the front brakes but I had to vacuum bleed the rear brake. I have a full size battery hooked up while I'm working on the bike.
It also needs a clutch & maybe a transmission I'll remove the trans. today.
Name:	08 LT Project 021.JPG
ID:	156421   Click image for larger version
Name:	08 LT Project 020.JPG
ID:	156423   Click image for larger version
Name:	08 LT Project 015.JPG
ID:	156425   Click image for larger version
Name:	08 LT Project 016.JPG
ID:	156427   Click image for larger version
Name:	08 LT Project 022.JPG
Name:	08 LT Project 026.JPG
ID:	156431   Click image for larger version
Name:	08 LT Project 025.JPG
ID:	156433   Click image for larger version
Name:	08 LT Project 028.JPG
meese, Patric and bmwcoolk1200 like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #5 of 23 Old Apr 10th, 2020, 7:37 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I didn't get to work on it again until this afternoon. I found a squirrel nest under my deck between the deck & the sealed off surface underneath the deck. I got the throttle body & transmission removed today.
Because I'll be removing the camshafts while the clutch is removed I made a crankshaft lock so nothing can turn over while the camshafts are removed. I welded a 1/4 x 20 nut to two cut off spark plugs so I can keep the crankshaft locked up. I have the pistons locked up close to the half way down point so I can rotate the camshafts and the valves will not contact the pistons.
Name:	08 LT Project 049.JPG
ID:	156495   Click image for larger version
Name:	08 LT Project 038.JPG
ID:	156497   Click image for larger version
Name:	08 LT Project 039.JPG
ID:	156499   Click image for larger version
Name:	08 LT Project 041.JPG
Patric, sailor, RockyRoad and 1 others like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #6 of 23 Old Apr 10th, 2020, 7:49 pm
That's very innovative of you. I love hard work , I could watch it all day.
Wazza is offline
post #7 of 23 Old Apr 11th, 2020, 7:41 am
Thanks for sharing the pictures.... To anyone who has never seen you travel, all of the tools in the pictures are part of every trip except for the lift :-). Someone will be getting a great bike..
Patric likes this.
post #8 of 23 Old Apr 12th, 2020, 6:20 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Yesterday I remove the transmission, clutch assembly & camshafts. I'll need 8 new shim buckets. I ordered the clutch parts & shim buckets from MotoBins. The clutch disc shows 50% wear. Today I cleaned parts all day.
The throttle body was first because of the split vent tube it was messy. Next was the clutch housing.
Name:	08 LT Project 059.JPG
ID:	156539   Click image for larger version
Name:	08 LT Project 050.JPG
ID:	156541   Click image for larger version
Name:	08 LT Project 053.JPG
ID:	156543   Click image for larger version
Name:	08 LT Project 054.JPG
ID:	156545   Click image for larger version
Name:	08 LT Project 055.JPG
Name:	08 LT Project 056.JPG
ID:	156549   Click image for larger version
Name:	08 LT Project 061.JPG
ID:	156551   Click image for larger version
Name:	08 LT Project 060.JPG
Patric likes this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #9 of 23 Old Apr 12th, 2020, 6:27 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
The transmission appears to be fine. I think his shifting problem was in the dry shift linkage. I cleaned it today installed new seals & pressure checked it at 5 psi before & after I installed the seals. Next I ground a drain slot in the slave cylinder housing. The fuel injectors go out tomorrow for rebuild.
Name:	08 LT Project 063.JPG
ID:	156555   Click image for larger version
Name:	08 LT Project 064.JPG
ID:	156557   Click image for larger version
Name:	08 LT Project 065.JPG
ID:	156559   Click image for larger version
Name:	08 LT Project 067.JPG
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #10 of 23 Old Apr 12th, 2020, 7:37 pm
I love to see these great bikes being kept on the road. My Wife would not be happy if I used her muffin trays to work on my bike however.
Wazza is offline
post #11 of 23 Old Apr 12th, 2020, 9:07 pm
Dave do you over fill the transmission for the pressure test? I have found that Ferrero Rocher 48 piece box perfect for valve jobs on the LT as it hold the buckets, valve springs and keepers in a dust free way.
Name:	Nice dust proof holder.png
post #12 of 23 Old Apr 12th, 2020, 9:07 pm
bmwcoolk1200's Avatar
Interesting variation on the slave weep hole. How long have you been doing the grinding versus drilling?
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #13 of 23 Old Apr 13th, 2020, 3:12 am Thread Starter
Enjoy The Ride
saddleman's Avatar
The transmission is drained & I spray soapy water on it looking for air bubbles.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #14 of 23 Old Apr 13th, 2020, 3:14 am Thread Starter
Enjoy The Ride
saddleman's Avatar
This is the second one I have done. I had a slave seal leak & the drain hole did not keep the gear oil from entering the clutch area.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #15 of 23 Old Apr 13th, 2020, 9:42 am
I never expected the weep hole to protect the clutch but hopefully give some advanced notice of a leak in that area with a drip to investigate. Maybe it just isn't large enough to allow that to happen.
Gordon
Sugar Hill, GA
post #16 of 23 Old Apr 13th, 2020, 9:42 am
Dave. Do you think you could put some sizes on your picture of ‘customized’ wrenches. I am a newbie and I am doing a fairly extensive overhaul of a 2005 and I like to be ready.
David Yerema is offline
post #17 of 23 Old Apr 13th, 2020, 3:55 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Most of my bent wrenches are 7 mm for bleeding & flushing the brakes on the ABS pumps. My 8 mm wrenches are for checking & tightening the ball studs on the shift linkage. My 10 mm wrench is to hold the nut on the shifter jack shaft.
My suggestion would be to purchase inexpensive wrenches in different lengths & heat them to bend them as needed.
I also have 10 mm & 11 mm wrenches that have been narrowed & bent to give clearance on the brake calipers for the hose that goes over the bleeder valve when bleeding or flushing.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #18 of 23 Old Apr 13th, 2020, 4:20 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I'm back to work tomorrow. Today most of it was cleaning up from last nights storm. I did manage to clearance the swing arm for the Metzler 888 that was on the bike that had one extra shim. I removed the casting line where the tire could rub. After grinding I cleaned & painted the area.
Name:	08 LT Project 068.JPG
ID:	156565   Click image for larger version
Name:	08 LT Project 070.JPG
ID:	156567   Click image for larger version
Name:	08 LT Project 071.JPG
ID:	156569   Click image for larger version
Name:	08 LT Project 072.JPG
ID:	156571   Click image for larger version
Name:	08 LT Project 073.JPG
Name:	08 LT Project 076.JPG
Patric, bmwcoolk1200 and kbob12 like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #19 of 23 Old Apr 14th, 2020, 12:40 am
Cool Re: 08 LT Overhaul Project
Plus, you have to eat the chocolate first, before you can use the tray!
djmellor is offline
post #20 of 23 Old Apr 14th, 2020, 12:51 pm
james216's Avatar
That's a lot of work Dave. Someone's getting a great bike.. Where did you get a new ABS pump?
I'm a 4 percenter.
james216 is offline
post #21 of 23 Old Apr 14th, 2020, 6:11 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
The replacement ABS pump is off of a 2005 LT with about 85,000 miles on it.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #22 of 23 Old Apr 15th, 2020, 7:14 pm
james216's Avatar
Too bad the servo assist can't be rebuilt. Well at least not reasonably anyways.The cost outweighs the bikes value.
Patric likes this.
I'm a 4 percenter.
james216 is offline
post #23 of 23 Old Apr 16th, 2020, 11:16 am Thread Starter
Enjoy The Ride
saddleman's Avatar
If I hadn't found a good used ABS unit I would have parted the bike out.
Dave Selvig
2004 Black LT
2000 Canon Red LT
