Metzeller Cruisetech suitability for K1200LT - BMW Luxury Touring Community
 1Likes
  • 1 Post By YiannisK1200LT
post #1 of 15 Old Apr 5th, 2020, 1:20 pm Thread Starter
YiannisK1200LT's Avatar
Hello from Greece. Following the forum for the last 6 years I would like with reference to the so many times discussed topic of tires. Does anybody installed the metzeller's Cruisetech Rear tyre on his bike? I am currently using the ME888 but I am not happy at all with the grip of the rear tyre at the snake roads and especially when weather cold or wet. Just for your info I keep cold pressure: 38PS on the front (so to eliminate the vibration between 50 to 80 km, as nicely advised from you in this forum) and 44PSI on the rear.
YiannisK1200LT is offline
post #2 of 15 Old Apr 5th, 2020, 2:03 pm
Re: Metzeller Cruisetech suitability for K1200LT
I don't know if anyone has tried this tire on the LT yet, but they do make a reinforced rear tire with the correct ratings: 160/70 B 17 M/C 79V REINFTL.
They do not make a front tire in the correct 120/70-17 size.
post #3 of 15 Old Apr 5th, 2020, 3:23 pm Thread Starter
Yes, exactly. Thanks a lot for joining my post. I have done a lot of research the last few days and came across with this new type of tyres by Metzeller, which although they do not produce the front tyre which suitable for K1200LT, in the contrary they are producing the size of rear tyre which also have the marking "REINF" which makes the difference in our case and most seems not to take into account during conversations for tyres. This model of tyres introduced by METZ beggining of 2019. Reading the reviews for the rear tyre specifically I have the feeling that we might have find a rear tyre of new technology fulfilling the requirements of BMW for K1200LT, which might give us a solution on the issue of poor grip in the wet and turns. I have already sent a message to METZ asking them if they rear tyre can be used on K1200LT since on their site they still gives you as a result the 888.
post #4 of 15 Old Apr 5th, 2020, 3:48 pm Thread Starter
As soon as I get reply from METZ, in case they confirm that Cruisetech rear can be used (which I do not see any reason not to e suitable for K1200LT) then the next question will be if it can be used in combination with front 888 since as far as I noticed on the infos from all makers the arrangement of front tyre is affecting the performance of rear. I know that most of the owners running with 888 front and BT-020 rear getting very good results but BT-020 is very difficult to be purchased here in Greece (if found will be maybe 3-4 years old without knowing the storage conditions followed by the local supplier).
Voyager likes this.
post #5 of 15 Old Apr 5th, 2020, 6:39 pm
The Metzeler ME880/888 tires are made from a hard compound. That gives long life but sacrifices grip, especially in the wet.
I've never been happy running 880/888 tires on any of my bikes.
Based on the specs, I wouldn't have any problem trying the Cruisetec rear on my LT.
Please do let us know how it works out for you.
post #6 of 15 Old Apr 5th, 2020, 7:48 pm Thread Starter
I intent to proceed as soon as life comes back to normal since we have a lock down here in Greece since 13th of March and most probably we will stay as we are till end of April. But for sure I will go with the rear Cruisetech. From my point of view I do not have anything to lose. It cant be worse than the 888 rear. My only concern is what tyre I will use at the front. I am also not happy with the front 888 which I had to change when I first installed 2.5 years ago because I had a terrible vibration which concluded that it was coming from the distorted tyre (brand new!!!!). Ofcourse they changed it without second discussion. Except the BT-020 do you have in mind any other front tyre suitable for the K1200LT? Most of the available ones I have searched are ZR or R and not Bias, but I believe this would be a problem. Your opinion on this would be highly appreciated.
post #7 of 15 Old Apr 5th, 2020, 8:11 pm
guitarjim's Avatar
I found the Avon 3d tires to be great on wet roads. I just got Avon with a slightly different tread pattern than the 3d for the front tire- I haven't ridden them in the rain and just have a little over 100 miles on it.
Current Ride: '02 LT - The Mistress
guitarjim is offline
post #8 of 15 Old Apr 5th, 2020, 8:53 pm
You can get an Avon Roadrider AM26 front tire in a 120/70-17 58V Bias ply.
post #9 of 15 Old Apr 6th, 2020, 11:46 am
bmwcoolk1200's Avatar
I couldn't get that tire off my bike fast enough. It is sitting dismounted in my garage with less than 1K miles on it. It was like riding on pencils over tar snakes wet or dry. Wet was down right scary even on level straight road.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #10 of 15 Old Apr 6th, 2020, 1:53 pm Thread Starter
Hello again. Could you please advise me if you can read all my posts on the subject? I just received a strange message from the site advising me that several messages of mine could be delivered
post #11 of 15 Old Apr 6th, 2020, 5:29 pm
Axle's Avatar
dunno suppose? I got you at 5 posts in this thread so far.... I cant read the ones you didn't send .........
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #12 of 15 Old Apr 6th, 2020, 6:00 pm Thread Starter
Ok. Thanks. I will then repeat my previous posts which you cannot see
post #13 of 15 Old Apr 6th, 2020, 6:02 pm Thread Starter
post #14 of 15 Old Apr 6th, 2020, 6:04 pm Thread Starter
post #15 of 15 Old Apr 6th, 2020, 7:41 pm Thread Starter
Has anyone here used the front tyre of Michelin Pilot Active?
