Reverse light stays on, bike wont start. - BMW Luxury Touring Community
 8Likes
  • 6 Post By RABlvmy88
  • 1 Post By RABlvmy88
  • 1 Post By davebullock
post #1 of 6 Old Apr 5th, 2020, 9:25 am Thread Starter
Finally got all the maintenance done, got the bike back together. Everything works, except, the bike wont start. The Reverse light on the dash is on, and wont shut off when I put the bike in the forward position. I had the bike running and tested it prior to final assembly, but then had to replace the front master cylinder, so I had to disconnect all the wiring to remove the radio console etc. Any ideas what might be wrong? Did I forget to plug something back in? Wondering which of the connections controls the reverse switch. Everything else electrical works just fine.
RABlvmy88 is offline
post #2 of 6 Old Apr 5th, 2020, 12:39 pm Thread Starter
Re: Reverse light stays on, bike wont start.
I have checked all the connectors to and from the center console, three connectors going in and three going to the front/dash. All seem tight. I have checked the connection from the battery to the reverse controller, seems good. Also checked connectors under the rear seat that connect reverse. Still having a problem. Any thoughts on whats next?
post #3 of 6 Old Apr 5th, 2020, 2:34 pm Thread Starter
Well, I found the problem. I had changed the spark plug wires, and inadvertently when putting the sheet metal cover back over the wires on the coil side, I managed to pinch the wire that runs from the Reverse switch on the transmission to the front dash (it runs right above that spot)I managed to mangle the wires enough that they must have shorted out. Found the pinch and cut back the insulation enough to see the 4 fine wires in that bundle and the damaged spot. I separated them and retested and the reverse light went out and the bike started. Now I just need to fix those wires and put it back together. A beginners error. On the positive side? I am getting plenty of practice taking off, putting on, taking off and putting on all the Tupperware and side panels.
post #4 of 6 Old Apr 5th, 2020, 4:22 pm
You are getting better, just keep it up. The bike is fantastic to ride.
post #5 of 6 Old Apr 7th, 2020, 8:10 am Thread Starter
Yes, Took it out yesterday, nice here in MA. Bike is running great and feels like a new bike. I will post a separate post summarizing all the work I did. Wondering what others would say I missed. But very glad that I took the time to get the bike back in shape. It is a great machine!
davebullock likes this.
post #6 of 6 Old Apr 7th, 2020, 8:42 am
davebullock's Avatar
So many of us have learned the hard way on DIY on these bikes. I was so proud of myself for changing the fuel pump and getting the bike back together, and it ran! Took it out for a ride, and was doing fine until it just stopped in the middle of an intersection. The fuel hoses inside the tank were not on tight enough, and I had to do the job all over again. Not thrilled, but it was so much easier the second time! Thanks for sharing your journey.
I had the LT out for the first time yesterday after a long winter, (and what is becoming a longer spring)and it ran great after all the service that I did. And today looks like another day to ride in WI.
Voyager likes this.
2000 LT 213K miles
2010 RT 35K miles
2007 RT P 42,000 miles SOLD
1982 vision 550 Yamaha SOLD
Four corner SCMA ride 2013
All Yooper SS1000K, 6/17/17, 6/19
48 state/12 day ride 2016
Great Lakes Challenge, 2011
davebullock is offline
