Bottom seat bridge bolts - BMW Luxury Touring Community
 7Likes
  • 2 Post By alabrew
  • 4 Post By saddleman
  • 1 Post By james216
post #1 of 10 Old Mar 29th, 2020, 10:55 pm Thread Starter
james216's Avatar
Hello all. Hope everyone is doing their best with this partial national shutdown. When i removed the seat bridge for pulling my gas tank off for maintenance. The bottom right side bolt that goes in the Aluminum frame got a little buggerd up coming out . I'll have to run a tap in. Clean up the threads in the frame And a dye on the bolt. Anyone know thread pitch?? Thanks in advance..
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #2 of 10 Old Mar 30th, 2020, 4:48 pm
Re: Bottom seat bridge bolts
M8 x 1.25 Usually they get buggered going in. I now have a set of heli-coils in M8 .
post #3 of 10 Old Mar 30th, 2020, 10:27 pm Thread Starter
james216's Avatar
Hmm. I noticed the right lower bolt had some difficulty twisting out. Then I looked at the starting threads. Ugg. Some aluminum in the 2nd pass and some aluminum dust below the hole. Not horrible. Chasing it and running a die should work.
I'm a 4 percenter.
james216 is offline
post #4 of 10 Old Mar 31st, 2020, 6:48 am
These are a bugger to get lined up, but you want to push and pull the frame into alignment before inserting the bolts. You donít want to use about to pry the seat frame hole into alignment or have side force on the bolt while tightening. It is a pain when working alone. Much easier if you have someone to insert the bolts while you are wrestle the frame.
post #5 of 10 Old Apr 3rd, 2020, 12:45 pm
Having done this a few time of late, don't ask, I put in the clutch side loose, then the right rear, and finally I use a long screwdriver to lift the rear of the tank to line up the right front.
davebullock and james216 like this.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
01 E320 4matic
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #6 of 10 Old Apr 3rd, 2020, 12:48 pm
Same thing as what I usually do.
post #7 of 10 Old Apr 3rd, 2020, 6:39 pm Thread Starter
james216's Avatar
I did it last time alone. Yea. That's probably when it happened. Putting them back in. I had no idea. Good advice Thanks...
I'm a 4 percenter.
james216 is offline
post #8 of 10 Old Apr 5th, 2020, 12:09 am Thread Starter
james216's Avatar
The right front? Has to mean the 8mm bolt ?
I'm a 4 percenter.
james216 is offline
post #9 of 10 Old Apr 5th, 2020, 4:42 am
Enjoy The Ride
saddleman's Avatar
Every seat frame fits different. Some line up easy and others can be hard to get lined up. I always start the top smaller two bolts by the sting ray first & leave them loose.
Voyager, Axle, james216 and 1 others like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #10 of 10 Old Apr 6th, 2020, 11:36 am Thread Starter
james216's Avatar
I chased the threads on the bolt and frame. All is good. I will follow your advice.. Thanks Dave.
Voyager likes this.
I'm a 4 percenter.
james216 is offline
