Breather tube replacement video! - BMW Luxury Touring Community
 15Likes
  • 8 Post By 14wntr
  • 1 Post By Wazza
  • 1 Post By Wazza
  • 1 Post By james216
  • 2 Post By Wazza
  • 1 Post By brassman96
  • 1 Post By alabrew
post #1 of 9 Old Mar 22nd, 2020, 1:29 pm Thread Starter
14wntr's Avatar
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #2 of 9 Old Mar 22nd, 2020, 3:08 pm
Re: Breather tube replacement video!
Thanks for the video Kirk. I remember sending you a request for just such a video. I did mine a few months ago and it wasn't really too bad a job.
The bike runs so much better now and I think I saved a couple of thousand dollars doing it myself.
14wntr likes this.
Wazza is offline
post #3 of 9 Old Mar 23rd, 2020, 12:00 am
james216's Avatar
That looks to be a major PITA!!!
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #4 of 9 Old Mar 23rd, 2020, 3:21 am
It really wasn't that bad. The old saying goes, How do you eat an elephant. One bite at a time. And that's the way to look at a job like this.
If you look at it as a series of smaller tasks that you have to accomplish on the way to your final goal it doesn't seem so daunting.
Just peal away the layers of the onion.
Patric likes this.
Wazza is offline
post #5 of 9 Old Mar 23rd, 2020, 1:11 pm
james216's Avatar
Peeling an onion. Yea. That's exactly what working on a LT is.
mondrage likes this.
I'm a 4 percenter.
james216 is offline
post #6 of 9 Old Mar 23rd, 2020, 5:57 pm
And the analogy goes further. In both cases it can make you cry.
Voyager and kbob12 like this.
Wazza is offline
post #7 of 9 Old Mar 24th, 2020, 11:19 am
james216's Avatar
Yes. It will make you cry.
I'm a 4 percenter.
james216 is offline
post #8 of 9 Old Apr 18th, 2020, 4:10 pm
brassman96's Avatar
Re: Breather tube replacement tip!
I just replaced the breather tube and now I am finishing up the throttle cable replacement. I'm combining the jobs since they involve removing roughly the same parts.
I attached the new breather tube to the back of the throttle body, re-using the little Oetiker clamps, by opening them up on a smooth tapered steel shaft and then I closed them down onto their tubes with a end nipper, gently squeezing. I imagine that small conventional hose clamps would work just fine too.
Here's the important tip: To install the 1/2" hose that runs across the top of the engine onto the nipple (that you can barely reach through the very small opening on the right side of the engine, just above the fuel dis-connects) cut a 1"x 2" piece of wood to fifteen inches in length. Then cut a "V" notch into the end of it, just the size to accommodate the hose. Next, working from the front of the engine, between the radiators, with your right arm, insert the stick until you can see it through that opening. With your left hand use a long screwdriver, align the end of the hose with the nipple and then push it on with the stick. Be sure to position the hose clamp correctly onto the hose ahead time. Tighten the clamp. Voila!
PS My breather hose was cracked and ready to start breathing oil all over my engine. Thanks for the video Kirk!
sailor likes this.
Bruce Haag
Cincinnati, OH
1999 BMW K1200 LTC Basalt Grey Metallic
2008 Vespa GTS 250ie Black
"Loved that bike.....sold it"
2007 Yamaha 400 Majesty
2002 BMW K1200LTE Mauve Pearl
1998 Honda ST1100 red
1996 Honda PC800 Pacific Coast red
1990 Suzuki GSF400 Bandit
1980's Vespas P200E, P125X, 100 Sport (had a Vespa dealership)
1975 Yamaha DT2B Enduro
1970 Suzuki 125 Stinger
1962 Honda CA50
brassman96 is offline
post #9 of 9 Old Apr 19th, 2020, 4:57 pm
Very good suggestions brassman96 on the install and on making the tool.
I used two long screwdrivers and a "salty" vocabulary.
brassman96 likes this.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
01 E320 4matic
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
