How does the radio talk to the speedometer cluster? - BMW Luxury Touring Community
post #1 of 13 Old Jan 30th, 2020, 4:08 pm Thread Starter
08 LT.
When I bought the bike, the radio was good but by the time I got home (1000 mile ride) it was dead. No lights on the radio at all. The dash said NO RADIO and it wouldn’t turn on or off.
I bought another radio from the junker, just the radio, not the control buttons. I took apart the control buttons and cleaned them. There was no sign of water inside.
I had a good week with it then NO RADIO came back. This time, the radio would turn off and on and otherwise function.
I had some cross country rides to do and didn’t mess with it. I use the AUX input and plug in to the headphone jack. As long as I leave it on the correct input, the controls and radio work fine for this but I can't turn off and on the speakers when it's in this state. The control buttons all work, regardless of the NO RADIO message.
After storing the bike for the winter with the battery removed, I now find the radio display now turns on saying BMW, and then finally AUX, but none of the 8 center buttons do anything. Volume control does not show volume changes. I can't turn off and on the radio any more. I'm not sure where to start.
Also, I've got a problem with the EHCS where it won't activate after riding. If you turn the ignition off and back on, however, it works just fine. I've sort of gotten used to this small problem but I'm not sure if it's related.
08ltcolorado is offline
post #2 of 13 Old Jan 30th, 2020, 9:19 pm
Re: How does the radio talk to the speedometer cluster?
Sounds like some gremlins are loose in your bike. The radio really needs to match the controller (part wit the buttons) so I hope your used radio was from an 05 and up bike. The communication path is on the I-K Bus from the controller to the dash.
The EHCS controller only checks if you are in neutral, side stand up, stopped and bike level (alarm sensor) but it does communicate with the dash on the I-K Bus to display one of three warning symbols on the LCD so there could be a connection. I have never seen this issue with the EHCS, so your may be a first.
post #3 of 13 Old Jan 31st, 2020, 6:36 am
Scimitar's Avatar
The I-Bus is the answer you are looking for. On startup, the I-Bus controller known as "MID" (inside the display) polls the bus asking to know who is listening. Devices respond with their type and in the case of the radio and the CD changer, keeps reporting in every few seconds. If the messages stop for any reason, then the controller thinks that there is no radio and reports as such. Your issue could be in the stingray unit, you need to test by substitution if you can find a matching one. First I would look at the circuit diagam though and check that all the I-Bus connections are sound. It is a single wire which goes to the diagnostic connector and the radio / cd changer and display on the diagram. Maybe purple / white, can't recall.
If you know a bit about it, you can use some software called Navcoder with a simple interface to monitor what is going on to diagnose it.
Previous username - ajlelectronics
Scimitar is online now
post #4 of 13 Old Feb 5th, 2020, 9:00 pm Thread Starter
Luckily the radio was from a 2009 and is visually identical to the (hopefully) original one. It came with the entire stingray.
I think there may be a problem with the i-bus as the lightning bolt symbol is permanently displayed on my dash from the EHCS. The EHCS works after startup, and so does the radio. I think the i-bus could be the common point of failure if it is part of the EHCS controller's interlock.
I took a quick look and found a white wire in the harness that has pulled out of its connector. I'm going to reconnect it and see what happens. I'll report back in a week or two. You may have solved it.
post #5 of 13 Old Feb 6th, 2020, 12:50 pm
I show the I Bus wire as white with a violet stripe.
post #6 of 13 Old Apr 3rd, 2020, 11:05 pm Thread Starter
So I found a few problems with my wiring. There is a 2pin connector that goes from the radio to the front of the bike. It has a green and black wire. It runs back to the part of the radio with the dial. I'm not sure what that's called. The comms unit?
Anyway it looks like it's for load relief relay. One of the wires was broken completely off, so I repaired that connection. Didn't help the radio at all. This is the wire I was thinking of earlier.
Next, I found the connection from the radio harness going back to the rear passenger intercom had cracks in the insulation near the connector. I repaired that connector and wires. I've never used the intercom but I'm sure it sounds better now.
Then, I started looking at the ibus wire. The wire is white/purple and runs along with the rest of the power and ground wires for the radio unit. I call it the radio power connector. It's all on one plug. There's also a purple/red wire that runs to the instrument cluster too, and I'm pretty sure it's not related to the ibus since it stops at the cluster but is used for some sort of data.
I took apart the radio harness and did a resistance check on the white/purple and purple/red wires. It looked good. I understand this test doesn't really replicate a wiring problem that happens under load. But I did check the wiring for signs of cracks or damage and it all looks good inside the radio harness.
Looking further down the schematic, there is a common point of failure for the EHCS and radio ibus wiring. The ibus wire for the EHCS splices with the radio's ibus wire after the radio power connector but before reaching the instrument cluster. They are also all jumpered to the diagnostic connector. Luckily, these two systems I am having trouble with appear to be the only two systems that utilize an ibus connection to the instrument panel and diagnostic connector.
I will probably start by disconnecting the EHCS module completely to see if that resolves the radio problem. I suppose it could be faulty. Once it's been disconnected I will check resistance on the ibus wires running back to the cluster, and also to the diagnostic connector.
I don't have a clue where the EHCS controller is, I assume it's under the seat somewhere. So that's what I'm working on next. Once I find it, I'll post another update.
Thanks for all your advice so far, it's very helpful!
post #7 of 13 Old Apr 3rd, 2020, 11:25 pm
The EHCS controller is mounted just under the rear seat on the right side , you should see a thing with two plugs on it, one bigger than the other.
One thing I found after I reinstated the EHCS on my bike is that the stand wont deploy if you hold the brake on at the same time. I made that mistake a couple of times and thought the circuit had failed.
Wazza is offline
post #8 of 13 Old Apr 4th, 2020, 9:54 am
That line from the EHCS is to generate error symbols in the LCD dash area like the lightening bolt. The EHCS controller checks five things prior to deploying, center stand is not down, side stand is up, bike is in neutral, bike is NOT moving and brakes are not on.
post #9 of 13 Old Apr 4th, 2020, 12:23 pm
And can be in reverse...
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
01 E320 4matic
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #10 of 13 Old Apr 5th, 2020, 7:34 pm Thread Starter
Found the ECHS module. Thanks to Wazza!
I did some checks with the multimeter last night.
ibus wire, white/purple
Radio plug -> ground = 700ohms
Radio plug -> diag plug = 0-1ohm
Radio plug -> ehcs = nothing
Diag plug -> ground = 600ohms
Diag plug -> radio = 0-1ohm
Diag plug -> ehcs = nothing
ehcs plug -> ground = 2.5 million ohms
ehcs plug -> radio = nothing
ehcs plug -> diag = nothing
Leaving the EHCS controller unplugged, I see the same lightning bolt icon on the dash as before. It looks to me like the lightning bolt on the dash may be caused by the lack of ehcs ibus signal to the cluster in addition to its normal error message which indicates low battery voltage.
With EHCS unplugged, the radio has the same problem, that is it works for about 5 seconds on powerup and then all the buttons on the handlebars and main control unit stop working. Power cycling the bike brings it back online for another 5 seconds. The radio continues to play whatever you were playing while the handlebar controls do nothing.
So I ran a jumper wire from the EHCS plug in to the radio plug and reconnected the EHCS controller. I got much the same symptoms except, after about 1 minute of power on time the radio controls started working again! EHCS Lightning bolt still there.
Next, I pulled the speedometer cover and checked resistance between the ibus white/purple wire and the radio ibus connector. Also checked it to the diagnostic connector. No continuity on either. So I jumpered from the radio connector, with the EHCS ibus included. Hopefully this brings both ibus signals directly to the cluster. Powering on now, the lightning bolt is gone! The radio has the works for 5 seconds and then after a minute has gone the buttons start working normally.
I noticed the ibus wire has battery voltage even when the bike is off. I've been having an issue with the battery draining on its own so hopefully this helps. It looks like the center stand problem is resolved completely. I can use the center stand after riding, without having to cycle the ignition.
As far as the radio being unresponsive for the first 5-60 seconds of power up, I'm really not sure what could be causing that. Any ideas?
post #11 of 13 Old Apr 7th, 2020, 11:57 pm Thread Starter
I was able to fix the radio not responding for 5-60 seconds. Turns out one of the outside control buttons "MEM" was stuck pressed. I removed the PCB and buttons, finding the switch was physically damaged inside. I ended up 3d printing a new plastic piece and now it's all working.
Thanks everyone for your help!
post #12 of 13 Old Apr 8th, 2020, 4:29 pm
It is nice when you finally find the culprit!!
post #13 of 13 Old Apr 8th, 2020, 4:36 pm Thread Starter
I've gone across the country twice with the LT and never had all this stuff working. Who knows if I will ever truly use it, but you know it makes me feel good to know that "everything works!"
