2003 LT won't turn over - BMW Luxury Touring Community
 4Likes
  • 1 Post By bmwcoolk1200
  • 1 Post By meese
  • 1 Post By meese
post #1 of 10 Old Dec 21st, 2019, 11:27 pm Thread Starter
Paging Mr Zeiler...
So, my '03 LT has decided not to start.
Key turns on, dash lights up, neutral light on, kickstand up, reverse off, kill switch OK, push start button and...nothing.
I was gonna start by checking the sidestand switch first, but thought I'd gather some advice for what else to look for before I start tearing her open.
post #2 of 10 Old Dec 21st, 2019, 11:36 pm
Re: 2003 LT won't turn over
First thing is actually measure the battery terminal voltage with the key off, then with the key on. If it is below 11.5 with key on, the interlock relay will not attempt a start. Next if the voltage is above 12.4 then try a large piece of wire between the battery + and the starter tie point behind the battery (it has a plastic cover). This will turn over the starter if the starter is OK.
Name:	Tie Points.JPG
post #3 of 10 Old Dec 22nd, 2019, 3:02 am Thread Starter
Thats right, the starter interlock, to avoid welding the starter relay on when battery voltage is low...
It's been a while, but this LT stuff does come back eventually.
Thanks. <img src="http://www.bmwlt.com/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
post #4 of 10 Old Dec 22nd, 2019, 8:10 am
bmwcoolk1200's Avatar
Ken, a quick check on the interlocks is that the temp light is lit on the dash( engine not running). If it isn't lit, then one of the interlocks isn't satisfied and you can go looking. If it is lit, then it should be ready to crank with the exception of the low voltage cut out on the 02 and newer starter relays that John mentioned or other electrical or mechanical issue.
saddleman likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #5 of 10 Old Dec 22nd, 2019, 5:19 pm
Gordon,
This is not Ken's first rodeo with an LT but it has been awhile since he has had one.
post #6 of 10 Old Dec 22nd, 2019, 5:28 pm
Originally Posted by jzeiler View Post
Gordon,
I can tell that by his signature but unless you pay close attention to ones like Sailor, you wouldn't know about the temp light and the interlocks. It never hurts to jog someones memory. It may save them some time they can spend riding rather than pulling the side stand switch. Besides, he already knew who to " GO TO" for his question.
Gordon
Sugar Hill, GA
post #7 of 10 Old Dec 22nd, 2019, 6:22 pm Thread Starter
I'd forgotten about the low voltage interlock, so that was a good reminder.
Using the temp light as an interlock indicator is new to me, and great info.
So thanks all, that's exactly why I posted here.
I did hook up the battery tender to charge overnight.
Now I just need to head out into the cold garage and see if it worked.
bmwcoolk1200 likes this.
post #8 of 10 Old Feb 2nd, 2020, 9:49 pm Thread Starter
Update: It was the low-voltage interlock, due to a bad Odyssey PC680 battery.
I borrowed a GS-911 and saw 10.5 volts at the ECU and ABS units, jumped the LT with my wife's car, and she fired right up.
Charging the PC680 for a few days didn't help, so I ordered a Westco 12V20P AGM battery for $80 shipped.
Turns out, the Westco terminals are vertical, and the PC680 terminal are horizontal, and the LT's battery cables really don't like to be twisted and stretched.
Dug through some old bike parts boxes and found the factory battery terminal adapter brackets, probably from when I switched my old LT to an Odyssey battery so many years ago...
Now I just need to see if I can find the original LT battery hold-down bracket hidden in some other old box...
post #9 of 10 Old Feb 3rd, 2020, 3:30 pm
Sounds like you are getting close to riding the old girl again - enjoy!
post #10 of 10 Old Feb 3rd, 2020, 6:06 pm Thread Starter
Took her out for a brief spin yesterday afternoon, just to make sure everything was up to par.
Was 29F and slightly icy this morning, so left her at home today...
Gotta ride to a customer site tomorrow, so I'll get a few miles in then.
