Refrofitting a "Motor" center stand to a L12LT with out one - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 8 Old Nov 29th, 2019, 4:00 pm Thread Starter
I spine issues just got more complicated so i can not longer put the bike on the center stand with my own muscles..
I know they are over complicate and finiky but i'm going to need one to do tire changes and other work..
Sincerely I have not look under the bike to see if the mount points are there (Because my very limited range of motion) so i'm asking you guys, before I waste my time and energy find in one and then losing the effort because it will not fit..
I think my bike is a 2001 (Before the servo wive debacle for sure)
Ricardo Kuhn is offline
post #2 of 8 Old Nov 29th, 2019, 5:45 pm
Re: Refrofitting a "Motor" center stand to a L12LT with out one
Yes you just have to buy a 05 and up center stand unit (yes it will bolt right up in place of your old one) and then you need to get the actuator and the cradle that holds it. Then you need a relay and a switch at a minimum to operate it. Many here have done this.
kbob12 likes this.
post #3 of 8 Old Nov 29th, 2019, 7:37 pm Thread Starter
Muchas gracias
The wrenching i can do no problem...
Now to find the best source to get a kit,, this motor is going to be imperative to be able to keep working on the bike..
as a funny aneglote..
more than ones I uses come alongs, small winches, to lift my super heavy loaded GSsw (350-400 pounds of load by fixing the center stand so it those not slide backwards and then the pulling the bike backwards, or a little more riky, connecting the two legs of the center stand and using the front wheel as anchor (Higher risk of the bike falling over you, plus mediocre mechanical advantage but it was fully self contained
every one time I manage to do it by my self with out ever dropping the bike (by pure miracle)
I refuse ot learn how to drive a car until I was 49 and we decide to make kiddos
some fun Pictures of some great adventures.
Question: is that a picture if a set you are selling..!!?
post #4 of 8 Old Nov 29th, 2019, 10:35 pm
garage monster's Avatar
It is actually simple to do. The hardest part was finding one for sale. I am not sure how to refer to my posting but search for this title:
retro fitting the electric center stand
And then you can search for my follow up title:
Electric center stand follow up
Many said it was a dangerous thing to do because there are no interlocks. In theory I could push the button while riding down the freeway. I think it is safe and I am approaching two years with it and I love it. I found no need for a relay. I just used a heavy duty, quality switch. No relay is one less part to fail.
Good luck.
Still rolling in Southern Oregon
garage monster is offline
post #5 of 8 Old Nov 29th, 2019, 11:27 pm Thread Starter
The model has been face out for so long I'm sure I ger lucky on the MOA Market place one of this days..
Good luck.
I spend half my life retrofits helos, planes and some very serous vehicles, far from a expert in electricity or electronics but installing redundant back ups and/or bi passing systems I think I can do and if not ask..
post #6 of 8 Old Nov 30th, 2019, 6:00 pm
Originally Posted by Ricardo Kuhn View Post
Muchas gracias
I though I was wild hauling home 2 sacks of concrete on my old Suzuki GT-750 but you have me beat on the wild loads!
No not my kit but if you can find a cradle and center stand on eBay, I have four rebuilt actuators sitting on the shelf so I have you covered there.
post #7 of 8 Old Dec 5th, 2019, 7:51 pm
Ricardo: I wish you all the best with your physical challenges. In think it's great that you are figuring out solutions that keep you riding.
pedalmike is offline
post #8 of 8 Old Dec 6th, 2019, 1:00 am
bmwcoolk1200's Avatar
Yes, as jzeiler said, it is doable on an 01 as I did it on mine. There is one other part you may want and that is the skid plate that goes on the bottom of the cradle. I made one out of heavy gauge sheet metal to protect the actuator so 4 parts total needed for a retrofit and the wiring and button you are on your own to figure out.
There are some pictures of the one I made at post #38 here. Make sure any wires are above the cradle as they will scrape the ground in turns.
https://www.bmwlt.com/forums/k1200lt...my-%24500.html
Gordon
Sugar Hill, GA
[SIGPIC][/SIGPIC]
bmwcoolk1200 is offline
