High Performance Clutch for the old LT...!?!? - BMW Luxury Touring Community
 5Likes
  • 1 Post By ebiss9
  • 1 Post By jzeiler
  • 3 Post By ErnieA
post #1 of 13 Old Sep 22nd, 2019, 3:37 am Thread Starter
First of all I had a horrible experience with a Touratch ceramic clutch so I'm a little hesitant to try anything different that OEM Sachs
But reading around I stumble into this RB Racing
Any feedback on their products...??
I'm looking for Ultimate performance in this case but not for "Racing" simply because from time to time the best maneuver is to "Get out of the way" and you can not do that if your clutch is kind of slippery (mine is)
I don't mind doing the work, I want to replace the seals anyway as a preventive measure so may as well install a new clutch, even better if it works better than the stock one
Ricardo Kuhn is offline
post #2 of 13 Old Sep 22nd, 2019, 6:10 am
ebiss9's Avatar
Re: High Performance Clutch for the old LT...!?!?
I’m not sure what’s up with that vendor! When I tried to contact them twice about questions for some of their products I never received a reply. So I ended up getting a Siebenrock clutch disk for my 2006 LT.
Ricardo Kuhn likes this.
Rob Sprague
Vineland, NJ
2009 BMW R1200RT Metallic Black
2006 BMW K1200LT/2012 Hannigan Trike Magnesium Black
2004 BMW K1200GT Orient Blue
"Money talks...but all mine ever says is good-bye."
"We, the people are the rightful masters of both Congress and the courts
not to overthrow the Constitution, but to overthrow men who pervert
the Constitution." Abraham Lincoln
ebiss9 is offline
post #3 of 13 Old Sep 22nd, 2019, 7:32 am
bmwcoolk1200's Avatar
Never used the Tourach or heard of anyone I know using it. Most are using the Siebenrock better than stock or OEM disk and OEM plate/spring parts. The LT clutch is not a very " strong" clutch as in if you are sliping it, it will not grab under heavy throttle if you let it all the way out but if you get it all the way out to where it stops slipping before trying to get full throttle, you can roll on all the throttle you need and it will not break loose. Being a dry clutch and a heavy bike, you can wear it out pretty quickly treating it like a wet clutch and slipping it a lot. Yeah, there are times you may have to but it will eventually take its toll if doing it excessively.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #4 of 13 Old Sep 22nd, 2019, 8:21 am
RB Racing is vaporware. Been following them for 10 years and NO Product yet.
But if your clutch is slipping when you roll on the throttle it is shot and needs to be replaced. I have had very good performance from the Siebenrock "better than stock" unit in several LT clutch jobs. The best way to preserve the LT clutch is never exceed 1,800 RPM when launching until the clutch is fully engaged. An occasional 2,400 RPM launch will not kill it but it could heat it up to the point where it will continue to slip until it cools down.
sailor likes this.
jzeiler is online now
post #5 of 13 Old Sep 22nd, 2019, 8:25 am Thread Starter
I have tons of miles on Boxer with the same clutch lay out..
I got the bike with 75.000 miles and yes the clutch is slipping when on 5th and try a "drastic" throttle maneuver..
I just think is time for a update..
post #6 of 13 Old Sep 22nd, 2019, 8:42 am
I agree if it is slipping under a full roll on. Not sure if any one is better than another in the aspect of performance. Stronger springs means more stress on the slave cylinder and embedded bearing which is a known area of concern if it leaks and subsequent clutch contamination and it needs to all be of the correct overall thickness for the pushrod to be in the right position. I am using the Siebenrock oil proof and it seems very good to me. No idea how it will wear but I try and take care of it with under 1800rpm starts making sure it is all the way out before I slam on the gas. If yours is already slipping, then you have worn it out or you have one of the areas of contamination affecting it.
Gordon
Sugar Hill, GA
post #7 of 13 Old Sep 22nd, 2019, 9:28 am Thread Starter
Thank you, great compendium..
I plan to tear down the whole bike (In time, winter will be here soon in minnesota) and blue print the whole thing, including all the seals and drilling the drain hole and implement all the tricks you guys know..
and if I need to drop the tranny down (I don't think I have too) in a year to fix the slave cylinder again I be okay with that too
post #8 of 13 Old Sep 22nd, 2019, 3:15 pm
ErnieA's Avatar
You're right on all accounts John. The owner of RB is into HD drag racing and salt flat racing development. They also still supply turbo (mostly for V-twin) kit parts, but they never came through on the clutch for the LT. I've only burned 1 clutch myself, and that was by doing just as you said. It was my first dry clutch bike and learned the hard way how to take care of it. The stock clutch, when operated/installed correctly works just fine.
sailor, saddleman and bmwcoolk1200 like this.
Ernie A
Milwaukie, OR
2013 R1200GSW
> 28k miles!
ErnieA is offline
post #9 of 13 Old Sep 22nd, 2019, 5:47 pm
fatbob307's Avatar
Replace the slave cylinder now, that’s probably leaking causing your clutch contamination & slipping.
Bob Lower
Casper, WY
'01 K1200LT
'03 R1150 RT
'13 R1200GS
'79 R100T w/Hack
'10 Triumph Thunderbird
'09 Triumph Bonneville
'07 Guzzi Norge
'88 HD FLHS
fatbob307 is offline
post #10 of 13 Old Sep 22nd, 2019, 8:37 pm
Possibly but you won't know the cause till you get in and look. Some people actually do wear them out
Replacing the slave with the clutch is never a bad idea though.
Gordon
Sugar Hill, GA
post #11 of 13 Old Sep 22nd, 2019, 8:40 pm Thread Starter
Smart tip..
but then how do i cleanse the clutch of any contaminants...!?!?
just drilling the bottom is not going to help
Ps:I did about 200 miles today and for sure is getting slippery, 110 mph max and will not go a mile higher..
post #12 of 13 Old Sep 22nd, 2019, 9:05 pm
Smart tip..
Some have claimed to drill side holes as well and spray the crap out of the clutch area with brake clean then put the front wheel up against the wall and burn the hell out of it. I don't recommend it but it has worked for a few. You still need figure out where the contamination is coming from or it will just keep happening.
The LT reaches its power to air resistance limit at around 120 mph so don't feel bad.
post #13 of 13 Old Sep 22nd, 2019, 9:16 pm Thread Starter
I guess I'm one of those that prefer to do the work from the Inside out..
I deal with enough bicycle disc brake pads that get contaminated just by touching them with your fingers..
Beside the bike has sufficient mileage to justified the work, plus I got it so cheap, is not even the money factor but the amount of time it takes..
on my old GS it took me like four hours to replace the first clutch (No ABS, so much easier) after replacing seven on the same bike (5th and 6th, i was a dummy and did not check the flywheel so they wore out really fast, stupid Ricky..
My record 42 something minutes, i didn't even take the rear wheel the last few times, much easier to move around too.
Tell me about it, that poor engine is pushing something as big as a ping pong table..
