06 LT ABS and Warning Lights On - BMW Luxury Touring Community
post #1 of 30 Old Jul 15th, 2019, 9:48 pm Thread Starter
mr1150gs's Avatar
This bike has 80k miles and owner has never changed brake fluid since he purchased it 2 years ago. ABS light is flashing fast and the triangle light is on constant. Is the ABS pump caput?
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is offline
post #2 of 30 Old Jul 16th, 2019, 7:10 am Thread Starter
mr1150gs's Avatar
Re: 06 LT ABS and Warning Lights On
Well there has been numerous posts on this so a little research has avoided a repeat of what has already been discussed.
I purchased the bike thinking it would be a good project to work on and learn from so I will keep you posted.
BMWMOA - #47511
mr1150gs is offline
post #3 of 30 Old Jul 16th, 2019, 1:54 pm
Yes, a little research as to what others have done with the same problem, once you have done those checks yourself w/o fixing your problem, then post, telling us all you have done.
First, find the chart that shows what the flashing lights mean.
Do you hear the servo motor run when you apply the handbrake?
Do you hear the servo motor run when you apply the footbrake?
How worn are the pads? Worn pads will cause a drop in fluid in the reservoir and cause a wig-wag.
Got to get to the unit to top it off anyway, might as well do a flush while you are there.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #4 of 30 Old Jul 17th, 2019, 3:10 am Thread Starter
mr1150gs's Avatar
Thanks Kim. Iím in possession of the bike now and yes, the servo motor runs when either the front or the rear brake is applied BUT I also here it, although not as loud, constantly indicating to me that a release valve is stuck.
I also have been informed that the dealer recently flushed the system in hopes of alleviating the fault but to no avail.
I connected a GS911 but it is not recognizing the ABS saying there is no signal from the controller.
I will report back as I dig deeper...
BMWMOA - #47511
mr1150gs is offline
post #5 of 30 Old Jul 17th, 2019, 9:38 am
Make sure than when you turn on the bike the brakes are not pressed or a brake switch is not stuck on.
That keeps the abs module from completing self diagnostics.
And that all brake lights are functional.
BMW K1200LT 2007
BMW K1200R: "Drophammer" 2006
BMW R1200GS 2008
BMW K1200S 2007
Suzuki DR-Z400E 2000
Sachs MadAss FY125-20
mondrage is offline
post #6 of 30 Old Jul 17th, 2019, 6:45 pm Thread Starter
mr1150gs's Avatar
Will do, thanks.
BMWMOA - #47511
mr1150gs is offline
post #7 of 30 Old Jul 18th, 2019, 2:58 pm Thread Starter
mr1150gs's Avatar
So an update is warranted... the bike does smoke although PO says it never used oil, and there is a lot of carbon buildup at the exhaust pipe. GS911 says TBPS are not in sync so Iím wondering if all this means it needs an oxygen sensor.
With regard to the ABS module, has anyone ever removed the pressure relief valve without removing the module? If so, how do you get an open end wrench on that??
BMWMOA - #47511
mr1150gs is offline
post #8 of 30 Old Jul 18th, 2019, 4:57 pm
I have removed them but you almost have to use a socket and you need to rotate the nearby exit port to get clearance. I want to say it is 22 mm. But I may be wrong.
Name:	Relief Valve 2.jpg
post #9 of 30 Old Jul 18th, 2019, 6:47 pm Thread Starter
mr1150gs's Avatar
Thanks John, i will try the socket but it looks like I need to remove the battery to get access with an open ended (donít have big enough socket). In bleeding the brakes, the fluid was very dark so not sure when they were done last, however, I cannot get the pump to push fluid to the rear Caliper. Is this a clear sign of that pressure relief valve being stuck?
BMWMOA - #47511
mr1150gs is offline
post #10 of 30 Old Jul 18th, 2019, 7:09 pm Thread Starter
mr1150gs's Avatar
The closest I have to fit is 1-1/16Ē so it must be a 26 or 27 mm deep socket as the wrench just does not grab enough meat to turn it.
I guess itís worth a shot to see if the rest pressure relief valve is indeed the issue as I would like to avoid having to remove the module all together unless I decide to extricate and eliminate. The fact that I hear the module working, even if I do not apply brakes, and since it cannot push fluid on that circuit makes me believe that the rear release valve is the issue.
BMWMOA - #47511
mr1150gs is offline
post #11 of 30 Old Jul 18th, 2019, 8:55 pm
No a stuck pressure relief valve will throw a "pressure too high" fault in the circuit. I don't have it on my diagram but I think the relief valve is between the pressure transducer and the reservoir. So if it was stuck you would still have fluid at the caliper.
If you cannot get fluid to pass out of the rear caliper there is a blockage in there some where or the "ball valve" is not closing the circuit. Might be worth it to pull the output port off and check the filter screen. Remove the clip and pop the line off then you can unscrew it.
Here is a diagram of the system:
post #12 of 30 Old Jul 18th, 2019, 9:20 pm
When left on the side stand oil pools on the cylinders. And it burns when turned on. Even on the center stand smokes a little. On the side stand a lot. But mine does not use oil.
The oil burn lasts about a minute.
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #13 of 30 Old Jul 19th, 2019, 1:59 am Thread Starter
mr1150gs's Avatar
Thanks John,
I did remove the screen at the rear reservoir and surprisingly found less fluid than I expected when I syringed it out. Also saw that the rear master cylinder reservoir was low in fluid.
Not sure what clip you are referring to but I assume you mean the brake line at the rear caliper and master cylinder. Are you suspecting a failure in the rubber brake lines? Could this blockage also cause the pump noise to be on continuously but louder when you apply brakes?
BMWMOA - #47511
mr1150gs is offline
post #14 of 30 Old Jul 19th, 2019, 2:07 am Thread Starter
mr1150gs's Avatar
I forgot to mention that the center stand does not move at all but you can hear the motor running when I try to deploy. Iíll have to get it on the bench to see how much oil is in there.
BMWMOA - #47511
mr1150gs is offline
post #15 of 30 Old Jul 19th, 2019, 2:43 pm
OK on the center stand run it on the bench with the little 4 mm ports facing up. Open the 19 mm spigot and add 10 ml of oil at a time and then run it. Repeat until it goes full stroke.
On the brakes look at my previous picture for the part I said rotate to gain access. That is the input port and the out put port is on the other side of the reservoirs. Short one is for the rear wheel circuit and the tall one is for the front. The clip is in that little slot and once removed you can pop out the hard line and remove the port to inspect the filter screen.
Name:	input and output.jpg
post #16 of 30 Old Jul 20th, 2019, 5:41 am Thread Starter
mr1150gs's Avatar
Thanks John, I will try that today as I thought you were referring to the screen inside the reservoir.
BMWMOA - #47511
mr1150gs is offline
post #17 of 30 Old Jul 20th, 2019, 11:21 am Thread Starter
mr1150gs's Avatar
So I was able to remove the input port and understandably saw clean fluid dripping from the line that you unclip and remove but saw no screen at this port. Was also able to blow through the valve(?) so no blockage there other than I’m not able to swallow anymore from putting brake fluid in my mouth (kidding).
Was able to remove the clip from the output port but cannot un screw that valve(?) and now have no response from the pump when rear brakes are applied but still here the constant sound from the pump.
I am thinking I will need to remove the pump after draining the system to get it on the bench. Only other thought is that the blockage could be at the rear caliper although I was not able to see fluid from the output port line. Definitely not been this far in with the brake system so anything goes.
BMWMOA - #47511
mr1150gs is offline
post #18 of 30 Old Jul 20th, 2019, 12:52 pm Thread Starter
mr1150gs's Avatar
Some pics...
ID:	153523   Click image for larger version
ID:	153525   Click image for larger version
BMWMOA - #47511
mr1150gs is offline
post #19 of 30 Old Jul 21st, 2019, 8:24 am Thread Starter
mr1150gs's Avatar
Hey John,
I did not see a screen at the input port and cannot see access to remove the output port unless i remove the pump. Before doing so, do you think that the caliper itself has failed and creating the blockage? The rear wheel does turn freely and I believe did stop when I applied foot pedal. Now that I do not have rear brakes I believe I’m looking at a complete removal of the pump either to dismantle and get access to that port or send away for refurbishing. Your thoughts and suggestions always welcomed!
BMWMOA - #47511
mr1150gs is offline
post #20 of 30 Old Jul 21st, 2019, 3:42 pm
You should be able to get some fluid at the calipers even if the pump is not running so I am not sure what is going on. I agree it would be hard to get the output port off with out removing the unit as it is kind of jammed up there under the frame.
post #21 of 30 Old Jul 22nd, 2019, 7:10 am Thread Starter
mr1150gs's Avatar
Thanks John, more research revealed that Iím looking at a total dismantling of the pump so off it comes once i secure the special toro bits to do the job and hope i do not mess it up even more.
I will probably need some parts from a discarded pump so if anyone has a servo assisted pump they are not using, i would be interested.
M
BMWMOA - #47511
mr1150gs is offline
post #22 of 30 Old Jul 23rd, 2019, 3:51 pm
I have a could of dead units here and one is an 05 +.
post #23 of 30 Old Jul 23rd, 2019, 9:03 pm Thread Starter
mr1150gs's Avatar
Great John,
I havenít dismantled mine yet to see what is causing the fault but let me know what you need for it.
Mauro
BMWMOA - #47511
mr1150gs is offline
post #24 of 30 Old Jul 23rd, 2019, 9:29 pm Thread Starter
mr1150gs's Avatar
I found an aftermarket alarm underneath the trunk and a cur wire at the alternator that I saw when I removed the battery. Iíll have to see how I can remove the alarm without impacting any other circuit. The cut wire is a thin light blue one that may or may not be part of the aftermarket issue.
I will need to deal with the ABS issue first to see how much cost Iím looking at toget this beast back on the road!
BMWMOA - #47511
mr1150gs is offline
post #25 of 30 Old Jul 24th, 2019, 1:04 pm
Thumbs up Re: 06 LT ABS and Warning Lights On
There is a thin blue wire with a black plastic spade connector that is the tickle wire for the alternator, hope that is not what was cut. It plugs into the side of the alternator just behind the main connector.
Are you sure the alarm is aftermarket? Here is the factory unit.
Name:	antenna mount.jpg
ID:	153581   Click image for larger version
Name:	Bolts for starter.jpg
post #26 of 30 Old Jul 25th, 2019, 11:23 am Thread Starter
mr1150gs's Avatar
Yes, the blue wire with plastic spade connector as in the pic. Also, for sure an aftermarket alarm that i would like to remove. Had to disconnected it in order to shut it up and have it stop draining the battery.
ID:	153599   Click image for larger version
BMWMOA - #47511
mr1150gs is offline
post #27 of 30 Old Jul 25th, 2019, 3:54 pm Thread Starter
mr1150gs's Avatar
Finally got the pump out and after drilling out 4 head bolts, discovered oil on the circuit board. I would imagine i will be hunting for o-rings.
BMWMOA - #47511
mr1150gs is offline
post #28 of 30 Old Jul 25th, 2019, 6:41 pm Thread Starter
mr1150gs's Avatar
Hey John,
I have dismantled the ABS Pump to find oil on the keyboard and the motors soaked as well as having a lot of chewed up plastic.
I will need to get o-rings but also wonder if your defective pump could have useable motors.
Let me know what you need for it.
M
BMWMOA - #47511
mr1150gs is offline
post #29 of 30 Old Aug 9th, 2019, 4:26 pm Thread Starter
mr1150gs's Avatar
Just waiting on some o rings to come in but still looking for a used abs pump in hopes of salvaging parts from it.
BMWMOA - #47511
mr1150gs is offline
post #30 of 30 Old Aug 27th, 2019, 3:35 am Thread Starter
mr1150gs's Avatar
I promised to update you on my ABS module rebuild but I’m afraid it is not good news in that the pump is still not responding properly despite Replacing one of the motors, thanks to the generosity of John Z, and various o-rings.
Here is what I have done so far and what I believe is now the issue:
- original issue was hearing the pump constantly rather than just when brakes were applied, I also could not bleed the rear wheel circuit or at least it was not allowing fluid to pass as freely to that Caliper.
- in dismantling the pump I found oil contamination on the circuit board and a faulty motor which was replaced.
- I could not find a replacement circuit board but my hope was that by replacing this motor and a few o-rings, I world have solved the issue.
Where do I go from here:
I will continue my search for a used pump as I do not believe I can simply send this one away for rebuilding now that I have been in it. Failing that, my next option is to cannibalize and sell the parts that others may need from this bike.
Sorry I could not be the bearer of better news but at least I have gained valuable additional experience along the way.
BMWMOA - #47511
mr1150gs is offline
