2004 Rehab project - What am I missing? - BMW Luxury Touring Community
 8Likes
  • 1 Post By beech
  • 1 Post By jzeiler
  • 1 Post By Voyager
  • 1 Post By jzeiler
  • 1 Post By krazzz
  • 2 Post By bruincounselor
  • 1 Post By bruincounselor
post #1 of 21 Old Apr 2nd, 2019, 6:23 pm Thread Starter
Acquired a 2004 K1200LT a month ago and have begun to go through it to set a solid baseline for things. This is my third K bike: K100LT and K1200RS in my past. Bike appears to have been neglected a bit recently, but only has 57,000 miles on it. What I've done:
Oil change and filter
Transmission fluid
Final drive fluid
Metal QD fuel lines - plastic connecters are no go for me.
In tank fuel filter and hoses (with stainless U-bend mod)
Air filter
Spark Plugs
H7 LED headlight
The battery seems to have enough juice so far
New braided brake line set arrives tomorrow and is the weekend project - I do have the funnel to bleed it when the time comes
Clutch inspection and spline lube are on the list for later (fall?) - I did this on my R1150GS so I know roughly what it entails.
Tires are old and I'll need to do some looking to see what works.
What else am I missing to get her back on the road in good nick?
bruincounselor is offline
post #2 of 21 Old Apr 2nd, 2019, 9:46 pm
beech's Avatar
Re: 2004 Rehab project - What am I missing?
Load test your battery. Hook up your volt meter and read it as you try to start the bike. If voltage drops to 9.5 or less, no good. Nice job with your list. Summer is coming enjoy the bike.
Check the dates on the tires. 5 years old getting slick.
bruincounselor likes this.
Beech
beech is offline
post #3 of 21 Old Apr 2nd, 2019, 10:05 pm
Best way to "inspect" the clutch on an LT is the rolling slip test (rolling at 4,000 rpm in 5th and cob the throttle). If it doesn't slip then its OK. The clutch is not exactly easy to get at and no one lubes the clutch splines on an LT. You go in that far you may as well just replace everything.
post #4 of 21 Old Apr 3rd, 2019, 12:58 am
I just bought a 2002 with 58k and no service records so I am going through it just like you. I have done everything on your list but also did the H3 LED bulb and rear LED. I also added a fuse block to power some future accessories. I have a USB port and a voltmeter combo and Photon Blaster lights for the front that I will be installing. I plan on doing the canister delete as well.
What is the stainless U-bend mod? I just did the Beemer Boneyard hose kit but I am concerned about the durability.
2002 BMW K1200LT 57k (new to me 1-20-19)
1971 BMW R60/5 27k (father-in-law was original owner)
1972 & 1973 Honda Trail 70s
1971 Honda XL175 (grandfather was original owner)
1997 Ducati 748 Sold
2000 Ducati 996 7k
2001 Ducati Monster 800 Sold
2008 Ducati Monster 696 Sold
1997 Honda CBR600 Sold
1973 Suzuki GT550 (2 stroke!) Sold
1973 Honda CB500 Sold
krazzz is offline
post #5 of 21 Old Apr 3rd, 2019, 7:00 am
Transmission fluid
Final drive fluid
Air filter
Spark Plugs
H7 LED headlight
Coolant flush and change
post #6 of 21 Old Apr 3rd, 2019, 8:41 am Thread Starter
https://www.bmwlt.com/forums/k1200lt...ernatives.html
Instead of a tight bend in a rubber hose replace that part with a stainless u-bend. That way you don't have any hoses with bends in them and little stress on the submerged hose. Mouthfullofflake on advrider.com is putting together a kit for reasonable $ (Be sure to tell him you don't need the sender unit o-ring). Most K and R bikes of our vintage use this in tank system in various forms. I'll post up a few photos this weekend (The one thing on the list not done as I ran out of time last night)
He also sells nylatron paralever bushings on his website=> Nushings.com (No financial interest, just a satisfied customer on my 1150GS and K12RS).
post #7 of 21 Old Apr 3rd, 2019, 8:45 am Thread Starter
Thanks for the suggestions. Coolant flush added to the wish list - I assume that it requires fairing removal so now is the time....?
post #8 of 21 Old Apr 3rd, 2019, 6:03 pm
Yes since you will have the tank off and can easily get to the radiator cap. Very slow pour will fill it with no burping of a crossover hose required. 2.5 liters with additional 0.6 L for the overflow tank. But I guess it is the same for the K1200RS as well.
post #9 of 21 Old Apr 3rd, 2019, 9:22 pm
Yes, easy job. I forgot to mention that I did that as well. Only took about 10 min.
2000 Ducati 996 7k
krazzz is offline
post #10 of 21 Old Apr 6th, 2019, 6:03 pm Thread Starter
A couple of shots of the U-bend mod. => nushings.com is my source.
ID:	150829   Click image for larger version
bruce60 and kbob12 like this.
post #11 of 21 Old Apr 6th, 2019, 6:27 pm
You didnít do a flush in 10 minutes. You can change the coolant in about that much time, but you canít flush the system in that much time as it takes that long to warm the engine each cycle.
post #12 of 21 Old Apr 6th, 2019, 7:42 pm
kbob12's Avatar
What a great idea for a future project the next time I have the tank off! Thanks for the photos and source info!
Covina, CA
2000 K1200LTI Champagne
kbob12 is offline
post #13 of 21 Old Apr 7th, 2019, 1:22 am
True, not a full flush, the bike isn't running right now so I couldn't do a full flush. The old coolant was good but I don't know the age of it so I wanted to replace it anyway. I just drained it, filled with distilled, drained again, and then filled with coolant. I realize that it didn't circulate in the block but I'm not worried about it.
2000 Ducati 996 7k
krazzz is offline
post #14 of 21 Old Apr 7th, 2019, 8:31 pm
GoldRush's Avatar
Check the preload adjuster for the rear shock. GoldRush
GoldRush
'06 K1200LT - As of March 2017!
'05 K1200LT - RIP - (totaled 7/8/08)
Former Yankee Beemer Member
Former BMWMOA Member
GoldRush is offline
post #15 of 21 Old May 4th, 2019, 11:37 am Thread Starter
Update:
I got it back together and have a few local trips on it. Runs great! It seemed to wallow a bit in turns so I checked the preload and added some fork oil. Did a coolant change too.
Temp gauge didn't work on maiden voyage - fans came on though. Yup, I forgot the attach the wire to the sender after the coolant change. Easy fix.
The set function on the cruise is intermittent (I'm open to suggestions; contact cleaner at the switch didn't fix it). Otherwise I'm very happy with the ride.
post #16 of 21 Old May 4th, 2019, 12:28 pm
Update:
Not sure what you mean by ďwallowĒ but if you mean side to side weaving feeling, then neither preload nor fork oil will affect that. That usually comes from flex in the chassis, suspension or tires. Canít do much about flex in the first two, but the latter can be due to under-inflated tires or improper tires (radials on a bike designed for bias, improper load rating, lack of reinforced rear in the case of the LT, etc.).
post #17 of 21 Old May 4th, 2019, 12:30 pm
Update:
You may want to add a signature that lists your bike year as that will help with many things such as brake and tire discussions as those changed a time or two during the course of LT production.
post #18 of 21 Old May 4th, 2019, 2:04 pm
It is in the subject line.
post #19 of 21 Old May 4th, 2019, 3:16 pm
In this thread, but it helps to have it in case one posts in response to another thread but the question is about their bike.
post #20 of 21 Old May 4th, 2019, 5:08 pm Thread Starter
99% sure I fixed the cruise issue using this post/video: https://www.bmwlt.com/forums/k1200lt...ml#post1879603
Clutch lever is sluggish in returning to full forward and not opening the microswitch. Adjusted and sounds better - A ride later will confirm my suspicions as everything else checked out OK.
Voyager likes this.
post #21 of 21 Old May 10th, 2019, 3:42 pm Thread Starter
Cruise fixed. First longish ride on Sunday - it's finally warming up and not raining. Still feeling a bit cramped so it will be interesting to se how it goes.
missing only at speeds above 75 mph ? tociano K1200LT 6 Jun 26th, 2012 11:19 pm
starting 2004 1200gt? cw1200lt Other K-Bikes Discussion 1 Sep 16th, 2009 3:59 am
Project Report - Homelink Transmitter kartcon K1200LT 16 Feb 20th, 2008 12:43 pm
Project Report - BMR CoPilot kartcon K1200LT 3 Jan 13th, 2008 11:12 pm
1974 vs 2004 NOGILLS2 Humor 2 Jan 23rd, 2006 3:53 pm
