6-CD Changer not found - BMW Luxury Touring Community
post #1 of 9 Old Mar 26th, 2019, 9:52 pm Thread Starter
I have my 6-CD changer that is not fond by the radio. (2003 LT) Any ideas on troubleshooting check the connections on the unit? It's a replacement unit about two yrs ago.
Gdrdocbmw is offline
post #2 of 9 Old Mar 27th, 2019, 6:15 am
Re: 6-CD Changer not found
If you open your right hand panier you will find it hiding in there.
Seriously though have you checked the plug connections to the unit. One of those may have come loose.
Wazza is offline
post #3 of 9 Old Mar 27th, 2019, 7:38 am
When I got my 2004 last year and opened everything up, I found mice had been gnawing away at the connector to the CD changer. Luckily I found it in time to save it. I would check all the connectors and wiring to the unit.
George
2004 K1200LT - Gray Ghost
longride is offline
post #4 of 9 Old Mar 27th, 2019, 10:20 am
Bob.K1200LT's Avatar
Gotta be either the connector or something wrong in the changer electronics. These changers are the same as used in BMW cars of that era. The head unit will only show the changer in the menu selection if attached. Not attached, no show in the selection menu.
Bob Johnson
Knoxville TN
2004 K1200LT
1973 R75/5
Bob.K1200LT is offline
post #5 of 9 Old Mar 31st, 2019, 1:28 am
On my 03 K12LT I disconnected the positive battery cable at the battery and left it disconnected overnight, then reconnected it. Be prepared for the alarm to go off. This trick worked several times. Never figured out why it quit.
polishvet is offline
post #6 of 9 Old Apr 4th, 2019, 11:06 pm Thread Starter
OK.. Thank you
post #7 of 9 Old Apr 4th, 2019, 11:06 pm Thread Starter
OK.. Thank you . I'll look that
post #8 of 9 Old Apr 5th, 2019, 4:37 pm
Munmi's Avatar
Originally Posted by polishvet View Post
On my 03 K12LT I disconnected the positive battery cable at the battery and left it disconnected overnight, then reconnected it. This trick worked several times. Never figured out why it quit.
This radio system works similar to your average computer. It has three phases in its startup and if there is a glitch, crazy fails can happen. To reduce your chances of a fail, get in the habit of shutting your radio down before turning off your bike when you park it, then start radio after full engine startup at your next ride.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #9 of 9 Old Apr 5th, 2019, 7:11 pm
Also there are two connectors back at the changer, make sure they are both fully seated.
Manual tyre changer - comments on this rig please! cws K1200LT 15 May 17th, 2013 7:53 am
CD stuck in changer lstinthot K1200LT 3 Jun 26th, 2010 4:22 pm
cd changer question hphammer K1200LT 8 Aug 7th, 2009 7:59 am
Can't install CD changer ?!? Frenchy K1200LT 7 Nov 15th, 2008 9:15 pm
CD Changer Problem tferguss K1200LT 5 Oct 23rd, 2005 10:21 am
