2009 Lt charging problem - BMW Luxury Touring Community
post #1 of 2 Old Mar 21st, 2019, 11:14 pm Thread Starter
Thumbs down 2009 Lt charging problem
'With bike running not getting any change in voltage at the battery. From your typical around 12 volts motor off to 13 to 14 engine running. Voltage continues to drop with motor running. You would expect bad alternator, right ? Battery load tested good. With no other way to test the alternator I can think of short of taking it out. I started the motor, dis-connected the negative battery cable, bike kept running which tells me the alternator is producing voltage ? What am I missing here ? Bad battery ? Even though it tested good. Dead short in it maybe ? Is there some residual voltage in the system somewhere that would allow the motor to run with no battery or current from the alternator ?? (stupid question) I'm baffled. Would really appreciate some help here to avoid the hours of labor to get the alternator out. To find maybe, Its not the problem ? Thanks guys
sloula is offline
post #2 of 2 Old Mar 22nd, 2019, 10:40 am
Re: 2009 Lt charging problem
Is the red battery light on in the dash? Even if it is not it may be the connector on the thin blue wire going to the alternator. Mine was showing wild voltage swings on my voltmeter I have in the dash. I pulled the blue wire off and cleaned the connector and tightened it a bit. When I pushed it back on all was well again.
Also did this just start out of the blue or has there been some maintenance done recently?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Round two with Garmin customer service, Zumo 665 BecketMa GPS 4 Oct 12th, 2012 5:05 pm
'03LT Brake system problem (long, sorry) K100Dennis K1200LT 4 Jun 17th, 2012 4:11 am
Charging System Problem jwd98056 GS Series 0 Apr 23rd, 2008 10:29 am
Computer Problem Response Form Lonewuff Humor 3 Mar 14th, 2008 4:53 pm
Intaride RP-1 and cell phone problem bowlesj Intercom, CB, & 2-Way Radios 0 Nov 7th, 2007 9:15 pm
