Steering damper seals source - BMW Luxury Touring Community
 5Likes
  • 4 Post By kend52
  • 1 Post By kend52
post #1 of 4 Old Feb 4th, 2019, 7:06 pm Thread Starter
Metric Seals, Inc. carries an exact replacement for the steering damper seals. I had a hard time finding a seal with the exact dimensions needed and also for use in a reciprocating environment. Found several for rotating environments, but was uneasy those seals could handle the pressure generated if the handlebars started towards a tank slapper. Anyway, the part number is QHWA10-20-7/8.5. Itís not cheap. I have no connection with Metric Seals other than as a satisfied customer.
Patric, sailor, beech and 1 others like this.
Ken Davis
Mobile, AL
2002 LT
kend52 is offline
post #2 of 4 Old Feb 4th, 2019, 9:21 pm
Ricky Chuck's Avatar
Re: Steering damper seals source
Wow, great timing, thanks! Discovered mine is seeping a little although it still passes the handlebar test. Getting replacement bushings for the end connected to the motor, too.
"Satisfied customer"...did you install them yet? I found some instructions from off-site how to do it, maybe from one of your posts, even.
Assume there are two in the damper, so 55 plus tax? I haven't priced a new damper but imagine it would make Warren Buffett blink, lol...
Oklahoma City, OK. 2003 K1200 LT. "Remember men, if the women don't find ya handsome, at least let 'em find ya handy." Red Green
Ricky Chuck is offline
post #3 of 4 Old Feb 5th, 2019, 5:11 pm Thread Starter
Itís been over a year and several thousand miles with no leaks. Yes, there are two seals. I searched this forum for instructions using the search function. Seems like one of the posts gave some advice about the quantity of oil. I canít remember the weight of oil I used. The whole rebuild process was pretty easy.
Ricky Chuck likes this.
kend52 is offline
post #4 of 4 Old Feb 5th, 2019, 5:30 pm
Thanks. If I find it is leaking I will order them. See you are in Mobile, lived up in the northern part when I was young, went to Spanish Fort a lot to see an Uncle, nice fishing down that way!
Which Hyperpro steering damper for my 2000 K1200LT geoffb K1200LT 1 Feb 19th, 2018 7:01 pm
Steering damper seals capnpawkee K1200LT 21 Feb 16th, 2015 10:39 am
Steering Damper Seals rmcline K1200LT 10 Feb 13th, 2015 10:10 am
steering damper dust boot ksbaltz K1200LT 5 Jul 8th, 2014 12:20 am
Steering Damper, Cause of Slow speed instability Jabrown K1200LT 22 Oct 18th, 2007 12:55 pm
