External fuel lines - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 4 Old Jan 31st, 2019, 5:41 pm Thread Starter
External fuel lines
Iíve been educating myself on fuel line specs this afternoon to see if I can find a local source that will meet our psi needs so I can replace my lines in a week or two with the correct line. Found that the SAE working pressure specs in our 51 psi range are J30R7 (working pressure up to 50 psi) and J30R9 (working pressure up to 100 psi). So, it looks like I need to find some that has the J30R9 stamp on the line, correct? I know I need to be aware of the bends at the fuel rail, too.
Ken Davis
Mobile, AL
2002 LT
kend52 is offline
post #2 of 4 Old Jan 31st, 2019, 6:33 pm
Re: External fuel lines
This is what I bought. I havenít installed it yet, but I believe it is the right stuff and right size. I would confirm size before you buy though.
Gates 27348 Barricade MPI Fuel Line Hose https://www.amazon.com/dp/B0058XDL0K..._un5uCbG3V0GSH
Voyager is online now
post #3 of 4 Old Jan 31st, 2019, 8:12 pm
While the factory lines have rather sharp bends in them there is ample room for you to route longer hoses to prevent kinks. You can transfer the anti-chafe material from the old lines. You will just have to mange the extra length so it doesn't get pinched anywhere.
Name:	New fuel lines.JPG
ID:	149611   Click image for larger version
kbob12 likes this.
post #4 of 4 Old Feb 1st, 2019, 4:48 am
Scimitar's Avatar
Where you are, then the Gates R9 will do the job. Over here, there is lots of counterfeit Gates hose. I estimate 90% of it is fake and the price is a good indication of that. People are still buying it though "Because it's cheap"! I have found the hose that the Germans use as OEM and I can trace it all the way back to the factory. I now sell it and in the last five years, I have had zero complaints.
Hoses
Fuel hoses - Classic Microcars and AJL Electronics Ltd Gloucester
Previous username - ajlelectronics
Scimitar is offline
Fuel gauge gone bonkers! Iscadean RT Series 8 Apr 11th, 2018 11:34 am
BBY external fuel hose Voyager K1200LT 5 May 30th, 2016 11:23 am
Diameter of the rubber fuel lines? rdwalker K1200LT 3 Oct 5th, 2009 7:53 am
