k1200lt oil fill cap same as other models - BMW Luxury Touring Community
 3Likes
  • 3 Post By sailor
post #1 of 2 Old Jan 28th, 2019, 11:53 pm Thread Starter
mslacool's Avatar
I need a new oil filler cap for a 2000 LT do all the models share a similar tread pattern and size? Interchangeable?
Pal
mslacool is offline
post #2 of 2 Old Jan 29th, 2019, 7:02 am
sailor's Avatar
Re: k1200lt oil fill cap same as other models
Pal
The black plastic OIL FILLER CAP is the same for all "brick-engine" of the K-series including older K100 , K75, K1100LT/RS and of course all models of the K1200 series.
BMW part number "11 14 1 460 191" for the CAP and "11 14 1 460 674" for the O-ring that comes separately. O-ring size is 25 x 2.7 mm.
You can use MAX-BMW parts fiche "search option" to confirm all models for a given part number:
https://shop.maxbmw.com/fiche/PartsSearch.aspx
Patric, beech and kbob12 like this.
John (Montreal, CANADA)
sailor is online now
K1200LT Oil Change - Refill Annoyances hschisler K1200LT 63 Jul 12th, 2018 1:40 am
Bosch 72161 oil filter WARNING! kellenbenz K1200LT 29 Feb 20th, 2018 9:00 am
Drilled into the cluch rod oil seal housing, best material to fill it with? JaL3_SD K1200LT 43 Dec 13th, 2016 2:12 pm
oil changes, any difference in 08-2010 models? Brian-NC RT Series 8 Nov 24th, 2010 8:52 am
