Crankcase Breather Hose - BMW Luxury Touring Community
 3Likes
  • 1 Post By bmwcoolk1200
  • 2 Post By jzeiler
post #1 of 7 Old Jan 23rd, 2019, 8:02 am Thread Starter
Question.... I see that there are 2 different clamps from the air box to throttle bodies. Non-reusable and screwed. However BMW Max parts show that they are all screwed clamps. Has anybody used all screwed clamps? What position/orientation is best if using screwed in non-usable positions? K1200LT 2001.
I am replacing all the rubber hoses when doing this work so any and all advise is welcome.
jndunne is offline
post #2 of 7 Old Jan 23rd, 2019, 10:01 am
Re: Crankcase Breather Hose
I use all screw clamps and here is the best setting for non-interference with the throttle linkage. The two center ones are easier to tighten if you remove the bracket that has the cruise cutout switch on it.
Name:	Clamp locations.jpg
ID:	149489   Click image for larger version
ID:	149491   Click image for larger version
ID:	149493   Click image for larger version
post #3 of 7 Old Jan 23rd, 2019, 10:35 am Thread Starter
That's great.....I was hoping for that answer!!
jndunne is offline
post #4 of 7 Old Jan 23rd, 2019, 12:31 pm
beech's Avatar
The non reusable ones actually are reusable and intended to be. "click it" type and require the special pliers or some strong long nose pliers to grab the two matching and protruding folds of metal. You have to preposition them with the parts over lapping and squeeze until it clicks (and locks) closed. In tight spots like this I use long nose, long reach pliers. A better option would be long reach duck bill pliers. Same problem on the intake manifold of S bikes.
Beech
beech is offline
post #5 of 7 Old Jan 23rd, 2019, 12:52 pm
bmwcoolk1200's Avatar
There are three types of clamps used among the intake bushings and the air box. The first two below are reusable but getting it back in place and squeezing it back to the locking position is often cumbersome. It can be done and I use a pair of needle nose vise grips over a large set of regular needle nose pliers. These were used on the front two positions with bikes that have cruse control to eliminate the possibility of binding on moving parts. As John said, you can use screw clamps in place but you have to be very careful on placement so they don't impact any moving part and jam your throttle in the open position. The last one is not reusable as it is a typical Otiker type clamp that is crimped to tighten. You pretty much have to destroy them to get them off.
ID:	149497   Click image for larger version
ID:	149499   Click image for larger version
beech likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #6 of 7 Old Jan 23rd, 2019, 4:19 pm Thread Starter
Its the first type that I have so I will try to refit them with a long-nosed vice grips.........with a couple of screwed clamps in reserve!!
Waiting for rubber parts to arrive and then the real work will start.
Thanks for your help
jndunne is offline
post #7 of 7 Old Jan 23rd, 2019, 6:30 pm
I have found that if you bent them at all taking them off you will never get them to hold again. That was an exercise in frustration so I just went with the screw type.
Patric and bmwcoolk1200 like this.
R1150RT disconnected breather hose Spuggy54 RT Series 2 Aug 20th, 2018 8:32 am
Attaching Crankcase Breather Hose andyfb K1200LT 63 May 9th, 2016 3:05 pm
Crankcase breather hose problem? carsonw42 K1200LT 4 Jan 26th, 2011 9:10 pm
Crankcase breather hose. Mechanical Geniuses Please RockyRaccon K1200LT 5 Jun 27th, 2010 8:52 pm
Crankcase Breather leakage mostlyirish K1200LT 16 Jun 24th, 2009 5:16 pm
