Bypassing alarm system - BMW Luxury Touring Community
 2Likes
  • 1 Post By jzeiler
  • 1 Post By jzeiler
post #1 of 5 Old Dec 3rd, 2018, 5:57 pm Thread Starter
I have a 2005 k1200lt that won't start it was told to me it was the alarm system and I'd have to bypass it I have a 12 pin hook up I need to know switch wire to jump to make my bike start anybody know how
gpeloubet is offline
post #2 of 5 Old Dec 3rd, 2018, 8:49 pm
Re: Bypassing alarm system
Yes there are two sets of jumpers you need to do.
1. To get the bike running again you need to jumper the following pins on the 12 pin connector. Pin 3 (black/white/yellow) to pin 11 (black/yellow); this is the starter button signal to the starter relay.
2. Then jumper pin 10 (green/violet, switched power) to both pin 2 (Green, flasher module) and pin 6 (blue/violet, engine electronics relay). Now the bike will start and run normally and your flashers will work.
Go ahead and unplug the three pin connector to remove power from the alarm as often the internal battery shorts out and blows the fuse for alarm, horn, and brake lights.
Note these are the colors in the harness on the bike side not the alarm side.
Ricky Chuck likes this.
post #3 of 5 Old Dec 8th, 2018, 4:58 pm
Ricky Chuck's Avatar
Merry Christmas, all, while awaiting the arrival of my coolant hoses I am doing some odds and ends and decided disabling my alarm might be prudent even though I have it defaulting to not being on. Bike lives either in my garage or a shed behind a 12' iron gate system and I have two caliper locks with alarms for traveling so not sure the risk for of it getting stolen is worth the risk of an alarm malfunction. Plus I only have one fob and one drop could put me out of business, lol.
John I note these are for a 2005 on this thread but are they compatible later or earlier? Mine is 2003. Thanks for any advice. I might add I saw nothing under alarm or security in the Clymer.
Oklahoma City, OK. 2003 K1200 LT. "Remember men, if the women don't find ya handsome, at least let 'em find ya handy." Red Green
Ricky Chuck is offline
post #4 of 5 Old Dec 8th, 2018, 10:17 pm
Originally Posted by grainbeltme
Jzeiler:
Find the alarm and undo all the connectors. There are one -3 pin, one- 4 pin and one - 12 pin.
Then jumper pin 10 (green/violet, switched power) to pin 6 (blue/violet, engine electronics relay). Now the bike will start and run normally.
An alternative is to just cut the insulation away on each of the jumpered wires and install a DPDT switch remotely so you "baypass" with the flip of the switch if you want to retain alarm function but bypass when it fails.
John I found corroboration, mostly, of your instructions for the 2005 likely working for my 2003 although the original poster had a 2002, lol.
In one you mention jump pin 10 to pin 6 AND pin 2 and then bike will start normally and "flashers will work".
In the other you just say pin 6 and then the bike will start and run normally. Is the last one for a normally working bike and the first one for flasher issues? Sorry for the confusion I have been trying to eke this out on my own.
post #5 of 5 Old Dec 8th, 2018, 10:45 pm
Don't add pin 2 to the 10/6 jumper. Your flashers will work without that. They made a change in 05 as to how they powered the flasher module. So just jump 10 and 6.
Alarm/ Central Locking/ Immobiliser System K1200lt 1994 New Look lnagel K1200LT 5 Nov 14th, 2011 1:10 am
alarm system gary45 K1200LT 0 Sep 4th, 2011 10:51 am
Factory Alarm System brianocw RT Series 3 Jun 19th, 2011 5:48 pm
2003 LT alarm system question tvolk K1200LT 6 Feb 25th, 2009 7:58 am
2003 Alarm system beemerjohn K1200LT 3 Jul 28th, 2007 12:47 pm
