Using the Rear Seat wiring for switched relay in Fuzeblocks - BMW Luxury Touring Community
 9Likes
  • 1 Post By bmwcoolk1200
  • 1 Post By Munmi
  • 1 Post By Voyager
  • 1 Post By Ricky Chuck
  • 1 Post By Voyager
  • 1 Post By reikin
  • 2 Post By Voyager
  • 1 Post By cws
post #1 of 14 Old Nov 17th, 2018, 8:53 pm Thread Starter
Ricky Chuck's Avatar
Hi, while I have it stripped down I am doing some other things, one of which is a Fuzeblocks. I saw in several posts about using the rear seat wiring "green wire" as the trigger but the question is which green wire? Looking at the area with the rear seat off I see the power plug on the left of the pic and there is a green/black wire. On the right there are some wires on one of the barrel connectors and one is green but so far I have not read or seen something that zeros in on "the green wire". Or...is it somewhere else completely?
I should add I don't have the battery in and don't want to try to energize it so hoping for a visual instead of a voltage check.
Name:	rear seat power plug.JPG
Oklahoma City, OK. 2003 K1200 LT. "Remember men, if the women don't find ya handsome, at least let 'em find ya handy." Red Green
Ricky Chuck is offline
post #2 of 14 Old Nov 17th, 2018, 10:26 pm
bmwcoolk1200's Avatar
Re: Using the Rear Seat wiring for switched relay in Fuzeblocks
I used the wire with green on the white heated seat power connector not the barrel connector.
Ricky Chuck likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #3 of 14 Old Nov 18th, 2018, 12:09 am Thread Starter
Thanks! Since I don't carry a passenger I think I will just use a square connector and push onto the male part of that wire and leave it unplugged...once I confirm it works, lol.
post #4 of 14 Old Nov 19th, 2018, 12:51 pm
Munmi's Avatar
If you use one of these Posi-Tap connectors,https://www.posi-products.com/posiplug.html , things will go quite easily. I have used the wire for the parking light in the headlight assembly as my trigger power. Has worked well on both LT's I have owned.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #5 of 14 Old Nov 20th, 2018, 5:15 pm
Just dont let them get wet or get any road or sea salt on them. They are far inferior to a proper splice that is soldered, coated with dielectric grease and then sealed with appropriately sized shrink tubing.
post #6 of 14 Old Nov 20th, 2018, 6:49 pm Thread Starter
Originally Posted by Voyager View Post
Just don’t let them get wet or get any road or sea salt on them. They are far inferior to a proper splice that is soldered, coated with dielectric grease and then sealed with appropriately sized shrink tubing.
I had actually intended to just get one of the female prong connectors and plug it into the fixed male connector and solder to the green wire coming off the female plug...no? I ride alone so no need for it to be plugged into the rear seat.
OR...get one of those Deutsch connectors and crimp/solder to it and just push onto the green wire male connector...
bmwcoolk1200 likes this.
post #7 of 14 Old Nov 20th, 2018, 8:15 pm
Getting a connector the same as on the seat and then using that to plug into the bike connector would be the ideal way as long as you dont need the seat heater.
post #8 of 14 Old Nov 24th, 2018, 1:52 am
Hi. I did this a number of years ago so I thought I throw this in. I installed a small fused relay under the rear seat to provide switched power to the fuzeblock. I got switched power by cutting into the loom near the large plug at the rear of the seat and finding a wire that was live when the bike was turned on. I can't remember exactly which one; I think it's power to the top box light but it was a long time ago.
Soldered, shrink-wrapped and re-taped the loom.
The relay is designed to slide on to a mount that came with the relay. I've just pushed it onto a mount that is already on the bike next to the plug for the seat heater. It doesn't fit properly but hasn't moved for at least six years now.
I'll try and post a couple of pictures on this thing
ID:	148721   Click image for larger version
ID:	148723   Click image for larger version
Russell Ikin
1970 R60/5
1984 100RS Cafe Racer
2007 K1200LT
Perth, Western Australia
reikin is offline
post #9 of 14 Old Nov 24th, 2018, 6:41 am
The Fuzeblock does not need a relay on the switched signal. It has been a decade since I installed mine, but I am pretty sure it uses that only as a control signal. It takes all power for both its switched and unstitched outputs directly from the battery, not through the signal line.
cws and Munmi like this.
post #10 of 14 Old Nov 24th, 2018, 11:35 am Thread Starter
Thanks! If I hadn't found the green wire on the rear seat plug I was going to dig into one of the barrel harnesses. I looked at the your location but decided I wanted a bit more protection from dirt and moisture. It made the fuzeblock a little taller but I put a thin wooden cover over the pcb and then added some of the heavy 3M velcro and will have it stuck to the open area by the left saddlebag. The black piece that comes from the rear cover will pull up enough to find a good spot and I have my wires coming around the front and back so I can see the color tags for the wires running to the front. For the back two wires I cut them into short pigtails and will add wire as I think of power needs such as led running lights. Actually I found a little 12v led hub that will dispense power to several led sticks and I can feed it with just one of the FZ-1 fuzes.
post #11 of 14 Old Nov 24th, 2018, 7:57 pm
Ran a wire from the switched rear powerlet plug for mine to trigger the switched power on the Fuzeblock. Easy enough to get to.
post #12 of 14 Old Nov 27th, 2018, 1:16 am
garage monster's Avatar
I think the posi-tap connectors are great and you can put a little dielectric grease i both ends before assembling. Keeps out dirt, water, and corrosion.
Still rolling in Southern Oregon
garage monster is offline
post #13 of 14 Old Nov 28th, 2018, 4:32 am
Yes. More force of habit and it gave me a neat fused circuit close to the rest of the fuses. I'm not a fan of having inline fuses; I tend to forget where I put them.
Russell Ikin
1970 R60/5
2007 K1200LT
reikin is offline
post #14 of 14 Old Nov 28th, 2018, 6:44 am
The Fuzeblock has a relay and fuses built in so you are simply adding a relay to control a relay and a fuse to protect fuses. No harm in that, but completely unnecessary and more parts to fail.
tall seat need a shorter. kmb1970 K1600GT/GTL 15 Aug 15th, 2014 6:01 am
Heater seat wiring twkBMW RT Series 8 May 5th, 2012 1:38 am
rear seat rubbers bikesnumbnuts K1200LT 4 Apr 16th, 2007 6:52 pm
