replacing brake lines - BMW Luxury Touring Community
 3Likes
  • 2 Post By Ricky Chuck
  • 1 Post By bmwcoolk1200
post #1 of 4 Old Nov 3rd, 2018, 4:38 pm Thread Starter
Hi preference on stainless brake lines to be used for BMW 1200 lt Thanks Norm
walkabout9255 is offline
post #2 of 4 Old Nov 3rd, 2018, 5:31 pm
Ricky Chuck's Avatar
Re: replacing brake lines
I am in post-processing after doing the replacement. Spieglers are probably the only option. I couldn't find a Galfer fitting. That was the easy part. I am trying to get my system bled after replacing, lol, and it is not cooperating. My BMW shop was going to charge 300 bucks for the bleed, right now it is looking cheap . If you are experienced at bleeding brakes probably not a biggie for you.
I should clarify I couldn't find a fitting for a 2003 LT from Galfer, not sure what year you have. 245 bucks for the Spieglers, probably easiest, most painless route.
Patric and Voyager like this.
Oklahoma City, OK. 2003 K1200 LT. "Remember men, if the women don't find ya handsome, at least let 'em find ya handy." Red Green
Ricky Chuck is offline
post #3 of 4 Old Nov 3rd, 2018, 9:06 pm
Yes go with the Spieglers, great kit for the money and has just about everything you need for the job. Allow about a day for all the fiddly stuff.
When doing the front brake line make sure you remove the air intake tube on the right hand side, It will make getting to the connections up around the steering head all that much easier.
Also get yourself one of those special funnels to bleed the ABS unit. You can get them from Beemer Boneyard for about $35 and you almost can't do the job without one.
Not a hard job, just take your time and if you can get someone to help you it will make the job quicker.
Oh and also stock up on beer.
Wazza is offline
post #4 of 4 Old Nov 3rd, 2018, 9:34 pm
bmwcoolk1200's Avatar
Based on your previous posts, I take it you have a 2000 LT so the funnel is not usable on those earlier non servo brake systems. You either have to keep filling the reservoirs as you pump or push the fluid up from the calipers back through the system. I would go with the Spiegler SS braided as already mentioned. They cost less and flex less than the OEM rubber lines.
Ricky Chuck likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
Tech specs - Brake Lines - 2007 DRONE K1200LT 9 May 9th, 2018 8:48 pm
air in brake lines? tonvanunen K1200LT 8 Dec 15th, 2014 3:37 pm
BMW Bulletin on Installation of Steel Brake Lines rdwalker Bike Talk 5 Feb 12th, 2011 11:25 pm
Spiegler brake lines: angle of the rear banjo fitting? rdwalker K1200LT 8 Mar 13th, 2010 6:32 pm
After market brake lines, Melvin? BecketMa K1200LT 6 Sep 5th, 2008 7:32 pm
