2005 LT Brake Lines & R. Rotor Changes Necessary? - BMW Luxury Touring Community
 2Likes
  • 1 Post By Voyager
  • 1 Post By Scouter-50
post #1 of 5 Old Oct 22nd, 2018, 10:03 am Thread Starter
Red face 2005 LT Brake Lines & R. Rotor Changes Necessary?
Greetings,
I'm considering purchasing a well maintained 2005 LT with 50 K miles.
The brake lines have never been changed, nor has the rear floating rotor.
While the lines appear not to be dry-rotted nor cracked, is a change of all of them prudent?
While I can do the work myself, what is the approximate cost of all the necessary recommended replacement parts?
Also, is it also prudent to change the rear rotor to the solid, cross-drilled version? If so, what is the cost of this?
Thank you for your thoughts!
YD
Yamahadrummer is offline
post #2 of 5 Old Oct 22nd, 2018, 12:39 pm
bmwcoolk1200's Avatar
Re: 2005 LT Brake Lines & R. Rotor Changes Necessary?
Originally Posted by Yamahadrummer View Post
Greetings,
YD
Welcome to the forum and yes, changing all of them is prudent. They can look like new on the outside and still be deteriorating from the inside out and go at any time.
As for the rotor, you would only need to change that if you had the cow bell and couldn't take the ringing any longer or if it was worn beyond the wear limits. The EBC predrilled rotor is a nice upgrade though but stay away from the fully sintered pads as stated by the MFG for that rotor.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 5 Old Oct 22nd, 2018, 1:29 pm
And stay away from sintered pads for the OEM rotor. One set of pads from BeemerBoneyard took my OEM rotor to minimum thickness in about 27,000 miles.
bmwcoolk1200 likes this.
post #4 of 5 Old Oct 22nd, 2018, 5:42 pm
Scouter-50's Avatar
As everyone else said, change the brake hoses now! My personal belief is that the rubber hoses deteriorate and damage the ABS pump. You will be very happy with the stainless/Teflon brake lines. Don't worry about the cost, changing them and regular flushes will save the ABS unit.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #5 of 5 Old Oct 22nd, 2018, 10:14 pm
guitarjim's Avatar
about $315 for lines and fluid and special funnel. not including any tools
Don't change the disc unless it is too thin.
Current Ride: '02 LT - The Mistress
guitarjim is offline
2005 K12LT Brake Fault Code 17181 LeRoi K1200LT 3 Jun 9th, 2016 9:55 pm
Brake Line Kit for 2005 R1200RT 2Miniacs RT Series 12 Aug 14th, 2014 5:15 pm
Used BMW Brake Lines Free saddleman K1200LT 0 Jul 4th, 2014 4:57 pm
Brake flush intervals Voyager K1200LT 8 May 25th, 2014 9:45 pm
Why Not SS Brake Lines ? Hilton K1200LT 36 Jul 30th, 2010 9:45 am
