'09 K1200LT ABS noise is gone after brake lines replaced. - BMW Luxury Touring Community
 2Likes
  • 2 Post By Zeek
post #1 of 5 Old Oct 11th, 2018, 10:22 pm Thread Starter
Zeek's Avatar
Greetings experienced members! I just completed replacing all the brake lines with Spieglers per Kirk's video on my '09 LT, including bleeding the master cylinders to the ABS, but when I turned on the key no ABS noise. I used the funnel and a hand vacuum gizmo to pull the fluid to the calipers, and now the front lever and rear pedal feel good (not spongy) but the boost isn't happening (all is quiet except for the Tic Tic Tic of the ABS lamp flasher). The bike is stripped down, not even a gas tank let alone lamps, so the general failure lamp is on steady and the ABS lamp is flashing 4x per second. Do I need a GS-911 to make it go again? Are the level sensor floats stuck in the down position? What should I try? Suggestions are welcome. I never had any problems with my brakes before this service, except the rear sensor wire problem (getting broke at the flex point, which I fixed).
2009 K1200LT (since new) 80K+ Miles.
Doing my own service since 2018.
Mods: Spieglers
Zeek is offline
post #2 of 5 Old Oct 12th, 2018, 2:54 pm
mr1150gs's Avatar
Re: '09 K1200LT ABS noise is gone after brake lines replaced.
Stupid question, but it sounds like you are not getting power to the unit, did you remember to secure the electrical connection to the ABS?
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is online now
post #3 of 5 Old Oct 12th, 2018, 6:00 pm
I would remove the connector and then reinstall it you should get the self test cycle, but that will not complete if the brakes are applied so check you brake switches. One of them is likely engaged. You will know when you have it as it will fast flash then shift to slow flash and you will hear the servos.
post #4 of 5 Old Oct 13th, 2018, 12:46 am
Axle's Avatar
bet its the foot brake, that hose is a prick to install and you can catch and the wire if your not careful.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 5 Old Oct 13th, 2018, 8:55 am Thread Starter
Zeek's Avatar
Well Som-a-gun! Plugged in the footbrake connector (two wires) and its back in action! Thanks a million. I don't think I ever would have thought that an open switch is different than an unplugged one. Guess it's normally closed. Anyhow you guys saved me a weekend of halted progress! Back to assembly...(so many parts and screws and so little memory of where they go...).
Patric and DRONE like this.
Zeek is offline
Shopping for Brake lines rmasci K1200LT 26 Aug 29th, 2015 4:53 pm
K1200LT Abs woes again! jimbobillybob K1200LT 8 Jun 29th, 2015 8:13 pm
Why Not SS Brake Lines ? Hilton K1200LT 36 Jul 30th, 2010 9:45 am
voice separation on the LT's loudspeaker jusufbw K1200LT 6 Oct 8th, 2007 11:03 pm
