2000 Front brake bleeder valve - BMW Luxury Touring Community
 2Likes
  • 2 Post By Garesnare
post #1 of 5 Old Mar 22nd, 2018, 1:45 am Thread Starter
trussell's Avatar
So it's time for Spieglers
Which means I have to bleed the new lines and the front right bleeder valve on the bike which has a wonky ball bearing bleeder valve.
I'll need to switch it out to a regular bleeder so that I can bleed the brakes.
Do I have to get it from the Dealer or will a standard one from an auto parts do?
Also is there anyone who sells Spieglers at a discount??? Just hoping
trussell is offline
post #2 of 5 Old Mar 22nd, 2018, 7:59 am
bmwcoolk1200's Avatar
Re: 2000 Front brake bleeder valve
I think Spieglers are a price protected thing like Apple I-pads so I haven't heard of anyone discounting them however, buying the set from a dealer rather than direct can get you a set that includes new banjo bolts as well where the direct set from Siegler does not. You would have to find a dealer and check what is included.
As for the brake bleeder screw, Here is a suggestion. Leave the check ball vent screw attachment alone and do things in this order.
Front first and use the bleed screw from the rear wheel caliper to bleed at the check ball. Next, move to the clutch and bleed that as it also has a vent screw attachment on it and finally, move to the rear wheel and replace the screw there. I bought an assortment of screws from an auto store but none of them fit so I bought one from the dealer and keep it in my tool box for future bleeds.
Be cautious in removing the vent screw as it is in there with loctite and needs heat to be removed but don't melt your calipers seals in the process.
Gordon
Sugar Hill, GA
[SIGPIC][/SIGPIC]
bmwcoolk1200 is offline
post #3 of 5 Old Mar 22nd, 2018, 9:17 am
Sportbiketrackgear.com seems to have the best prices and you get an in store reward credit every time you buy something. My last set from them was about $250
post #4 of 5 Old Mar 23rd, 2018, 7:48 pm Thread Starter
trussell's Avatar
Great work around. Thanks
trussell is offline
post #5 of 5 Old Mar 23rd, 2018, 8:46 pm
Try the Speed Bleeders. They’re fantastic!
http://www.speedbleeder.com/
They have all sizes.
Patric and JNW003 like this.
Garesnare is offline
Front brake reservoir help Alaskan RT Series 13 Jun 5th, 2012 1:24 pm
Replacing front brake pads 2000 LT Lee510 K1200LT 11 Aug 10th, 2010 7:01 pm
Front Brake - is this right? myk_edwards K1200LT 16 May 27th, 2009 10:03 am
Is it OK just to use front brake only? JoyfulSoul K1200LT 62 Mar 5th, 2006 9:03 pm
Front Brake Lever Issue Jerrod Maguire K1200LT 2 Jan 21st, 2006 12:49 am
