have just completed pulling my bike down to remove the ignition from the steering head however the bolts 2 that hold the ignition to the steering head are a bolt head i have never seen before looks like a daisy (smaal circular hole inthe centre with small inverted triangles radiating around this central small circle ,dont know what to remove the bolts with
regards richard
"with a 4mm drill, drill the heads of the non-removable screws to a depth of 5mm. Then with an 8 mm drill drill off the heads. Remove the ignition switch/lock and unscrew the pins with a stud remover."
Not what you wanted to hear. Now you have to get some new non-removable screws as well as a key.
thanks john for the information re drilling out the bolt heads from the ignition by the way i do not have a manual but i was beginning to suspect that drilling out these bolts was the only option
regards richard
Here at my job we run into bolts of that nature as well. Securing ECM's and steering locks and the like. More than likely your bolts will have locktight on them as well. What we do is use a cut-off wheel or grinder to make a slot in the bolt head. Then use a large flat blade screw driver to remove the bolt. It helps to do it right away because the friction from the grinder heats up the locktight and aids in removal.
If you have access to make the cut I would do that. We have broken more than a few bits trying to remove bolts the way the manual says. Then it turns into a hugh fiasco...
Related Threads
BMW Luxury Touring Community
894.3K posts
44.9K members
Since 2005
