ABS problems - BMW Luxury Touring Community
post #1 of 8 Old Dec 19th, 2006, 4:41 pm Thread Starter
frankf's Avatar
ABS problems
Hi All,
well I thought it was the blue wire - had the ABS warning light light come on (alternating 1 Hz warning) and since I had this happen before I suspected the blue wire which goes onto the small tab directly on the alternator.
After wiggling the connector around and turning the bike back on the ABS warning did not come on again and I thought all was fine. Until a few days later when it happened again. Wiggling did not help this time so I decided to pull the battery and take a closer look. After cleaning the tab on the alternator with some sand paper close inspection of the female connector on the blue wire revealed that the wire had come loose in the crimped part of the connector I decided to cut it off and put a new connector on (from Radio Shack). Now the connection feels very solid and it has continuity but - the ABS warning is still on. Do I have a bad ABS unit? What else can I look for? The blue wire goes into the wiring harness close to the battery where does the other end go? Any advice will be greatly appreciated.
Fascinating.
frankf is offline
post #2 of 8 Old Dec 19th, 2006, 6:57 pm
Daman858's Avatar
Check your brake fluid resevoir for low fluid level.
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #3 of 8 Old Dec 19th, 2006, 9:21 pm
Exclamation ABS problems
There are 2 locations to top off brake fluid. One behind the other.
Buford is offline
post #4 of 8 Old Dec 19th, 2006, 9:21 pm
Steve_R's Avatar
The fluid level is possible as just one problem. Since you've seen to have had issues with the blue wire, I suspect that you now have a hard ABS fault in the computer caused by a low battery level since the charging system hasn't been working. If that is the case, the faults will have to be cleared by the dealer. By getting them to clear the faults, they will also test the ABS unit in the process to make sure that you don't have a hard ABS failure.
JM2CW
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #5 of 8 Old Dec 21st, 2006, 1:57 pm
Back to the brake fluid, ON the rear brake master cylinder there is two reseviors. Top these off before chasing for other problems. When this has happened on most of the bikes, the cause is the most aft (Rear) resevoir being not even low but a little fluid added here stopped the problem....
Steve
k2steve is offline
post #6 of 8 Old Dec 27th, 2006, 1:53 pm Thread Starter
frankf's Avatar
Steve
Thanks Steve, I'll check that first and see whether the warning goes away.
Fascinating.
frankf is offline
post #7 of 8 Old Dec 30th, 2006, 9:59 pm
Skozar's Avatar
Stopped the Flashing (ABS that is)
Had a short event with the ABS and General Warning light wobble on/off myself this weekend. While it was raining and in-between football games I accessed the rear reservoirs and topped off both with a little DOT 4 fluid and everything is back to normal. Note: My rear-forward reservoir was down by less than 5 cc's, but that was enough to light them up.
Skozar is offline
post #8 of 8 Old Dec 31st, 2006, 9:55 am
bmwrubbercow's Avatar
JM2CW
I agree with everything Steve says. Before you take it to the dealer though. Check your battery output. Low strength can and will cause the ABS lights to flash.
Also, several years ago I had the dreaded blinking red lights on my K75SA. Battery was fine and I used a jumper wire to clear the ABS circuit of any false readings. Still no go.
I then decided to use a clean dollar bill to buff the sensor on each wheel in case it was dirty. (Old airhead riders, including me, remember using a clean dollar bill or business card to clean dirty points: same principle)
That was when I found my problem--and no it was not dirty sensors.
Dealer had recently put new front tire on bike and had installed the wheel backward on the bike! Sensor was on wrong side of bike from its mate. Interesting.....New dealer now!
Tom
Tom
2003 R1150RT, Black Beauty--this is one sexy bike!
1999 R1100GSA, Does everything well, what else can one say?
1992 K75SA, If this engine had been 4-valve instead of 2, it would be the smoothest BMW ever built!
1978 R100S, my first and favorite BMW.
1976 R75/6, A 30 year old gentlemen I still love to take out for a Sunday ride.
bmwrubbercow is offline
ABS unit gone again plonk K1200LT 9 Jun 17th, 2011 4:06 am
Help with ABS lights RonBilbo K1200LT 8 May 9th, 2006 3:08 pm
ABS Failure on 2000LT iowalt K1200LT 5 Jan 10th, 2006 10:20 pm
