Buying a 1999 K1200LT What To Look Out For - BMW Luxury Touring Community
post #1 of 12 Old Dec 16th, 2006, 7:54 pm Thread Starter
dpcrxone's Avatar
Dear Members. I am new to this group and have been told if you ask a question you will get a straight answer. I am looking to buy a 1999 LT with only 10K miles on it and with every picture I have seen it looks like new. I am told there have been only 2 owners and he is selling only because his is buying a K1200GS to replace his LT. Here is my question. What problems could I have with this bike? What would you think it is worth in great condition with only 10k miles on it? Thank you in advance for your suggestions.
dpcrxone is offline
post #2 of 12 Old Dec 16th, 2006, 9:11 pm
kevincook's Avatar
That isn't very many miles for a 1999, my biggest concern would probably be that the fluids were changed frequently enough. Particularly the brake fluid since water in the fluid could cause problems with the ABS unit. The coolant would be second on my list since the corrosion inhibitors will wear out over time. Assuming the fluids have been changed on schedule there are only a couple of things that I can think of that you should be aware of.
1. The starter solenoid on the early bikes can stick if you try to start the bike with a low battery voltage. There is an upgraded solenoid that you can install...the cost is about $200.
2. The clutch slave cylinders are prone to leak on many of the early bikes as well as the 2005's. The slave cylinder is only about a $85 part but the leak can contaminate the clutch and result in a $1500 bill at the dealer. Check to make sure the clutch is not slipping. After you get the bike plan to attend a local tech. session to drill a weep hole for the clutch slave cylinder to eliminate the possiblity of ruin a clutch.
3. Some of the early bikes (<10%) have had final drive bearing failures at pretty low mileage. Check for fluid leaking from the rear drive on the rear wheel.
4. Test the ABS function of the bike. The ABS unit is expensive to replace. The ABS lights should flash when you start the bike but should go out when you start moving.
5. Check the bottom of the engine for any oil leakage. A leak between the engine and transmission can also damage the clutch.
I'm sure others will chime in with better advice.
Good Luck,
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #3 of 12 Old Dec 16th, 2006, 10:33 pm
UncleRock's Avatar
Check when was last maint. if more than a year I'd change out all the fluids and give the rubber a real close look..
Price? A week before Christmas, bike is 8 years old. I'd go 5-6K Hey it's a buyers market between Turkey and Santa. I'm not ashamed to take advantage of it . If they wait till the 23rd it goes down to 4K
Rock
UncleRock is offline
post #4 of 12 Old Dec 18th, 2006, 7:08 am
Early models had a few problems with the radio-cd unit and some with intercom wiring. If the bike is a standard 5-6 thousand is probably a fair price. Don't expect the owner will think that. If it is a custom then most likely the owner will expect a higher price especially with the low miles. In this case low miles aren't really a good thing. Good luck.
ATFLT is offline
post #5 of 12 Old Dec 18th, 2006, 10:20 am
BecketMa's Avatar
By design, the speedo reads about 10% to high.
See if a crash pan was installed. My 2000 didn't come with one. BMW offered them for free, via a dealer, for a while. I hit it every once in a while, going over a speed bump.
The local dealership replaced my defective starter relay; they replaced the poorly programmed computer chip, with a newer one, so that the engine does not hesitate during warm wx.
If the bike didn't come with a heated seat, the wiring harness is not set up for a simply replacing the stock seat with a heated seat.
BecketMa is offline
post #6 of 12 Old Dec 18th, 2006, 12:20 pm
I purchased a 2000 LT last November (2005) with 8500 miles on it for $6900. It did not have heated seats, and the mechanism for adjusting the windshield was broken--a fact I was aware of. I bought some heated seats, and was able to get the rider and passenger seats used for $300, and I was able to get the windshield adjuster used for $300 more. The adjuster new is closer to $600. I think the advise given before is good advise. I love my bike, BUT, now the ABS lights flash, and it seems as though my only avenue is to spend $2000 to fix it, or live with it until I can get a new bike. SO, make sure the ABS unit is working. Mine was when I bought it, but quit working after about 7000 miles. In my humble opinion, $7500 or less would be a good buy on it. Best of Luck! I am sure you will love it. jrlakin
jrlakin is offline
post #7 of 12 Old Dec 18th, 2006, 3:30 pm
rkirker's Avatar
Check the Fuild resivoir
jrlakin
Did you check the fluid resivouir for the brakes (Not on the Handle bars) but under the Pillon seat and behind the right Pillon foot peg ?
ABS will flash if fluid is just a tad low on these big girls.
It must be at the full mark.
Did you check the b
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well Itís not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldnít of happened."
rkirker is offline
post #8 of 12 Old Dec 18th, 2006, 3:52 pm
The low brake fluid warning is on the Integral brakes, that is '02 and newer. The '99-'01 bikes don't have this sensor, so it never registers a failure. Possible causes are low battery voltage, or a valve sticking inside the ABS unit.
post #9 of 12 Old Dec 18th, 2006, 4:32 pm
I have checked the fluid levels on the brakes, and they are fine. Actually, the first time my abs lights wouldn't quit flashing after start up, I was at my Dealer, because I had a front fork seal that was replaced. He rechecked my fluid levels, and reset the unit. I rode it for about 2000 miles after that with no problems, and while I was on a trip in Tennessee, the lights started flashing again--or more correctly, just woudn't stop flashing after start up. I took it back to the dealer, and again he rechecked the fluids, and reset abs unit. Rode it for another 1500 miles or so before it started again. I was told if it did it again, he (the dealer) would do a brake flush and reset one more time, and if that didn't cure the problem, a replacement was next---or tape over the flashing lights!! I haven't been back to the dealer since this last occurance. I am over 100 miles away, and just haven't had time to make an appointment. He did tell me the abs unit new was $1600 plus labor. I won't replace it for that on a bike as old as mine is. BTW, my battery is fine. I do appreciate all the advise though. This is a great web site to learn and share with others. The collective knowledge here is superb!!!! Thanks to all. jrlakin
jrlakin is offline
post #10 of 12 Old Dec 19th, 2006, 8:07 pm
rkirker's Avatar
Opps
My Bad forgot about the ABSII on the 99-01
Thanks for the correction Meese
Rich Kirker
BMWMOA #124306
Blue & Pearl
rkirker is offline
post #11 of 12 Old Dec 19th, 2006, 11:24 pm
No problem. We just try and keep the technical details straight, both for the original poster and anyone who may come across the thread later.
post #12 of 12 Old Dec 22nd, 2006, 3:31 pm Thread Starter
dpcrxone's Avatar
Hello everyone. Thank you for your replies and input. I just purchased my 99 K1200LT with only 10K on it. This bike is pristine and has always been stored next to a private jet in a temperature controlled hanger. This bike is sweet and I purchased it for 8k. Very happy with my purchase. I am having the dealer perform the 12K check-up now to make sure everything is good. I am having all fluids changed and the dealer told me that they have serviced this bike since 5K was on it. Thanks again for all your help and looking forward to riding in the spring...
dpcrxone is offline
Into & Qustion on 1999 K1200LT jman_529 K1200LT 8 Jul 23rd, 2006 8:18 am
