First gear - BMW Luxury Touring Community
post #1 of 10 Old Dec 14th, 2006, 2:22 pm Thread Starter
First gear
I have hard time putting the bike on fisrt gear. This is my first BMW. Am I doing something wrong or do you think I should ask the dealer to adjust it? I have a K 1200 LT 2005. Thank you
Provencale is offline
post #2 of 10 Old Dec 14th, 2006, 2:32 pm
I had a hard time when I first got on the bike too. I'm not sure of the physics, but if it won't pop into 1st, SLOWLY release the clutch A LITTLE at a time and keep trying - it'll pop in. Obviously, don't let it out too much unless you want to see it stall (and you'll probably end up in a heap on the ground after it tips over).
I rode a Honda for 2 years before the LT and have never heard of this. I guess it's just a little touchy. You'll get the hang of it.
Reverse is the same way. If it doesn't want to click into reverse, roll it forward or backward SLOWLY until the lever kicks into R.
rjhammetter is offline
post #3 of 10 Old Dec 14th, 2006, 3:05 pm
vernvernvern's Avatar
Thumbs up You have to get used to it.
provencale,
I had trouble too as I waited to hear the THUD of it going into first like my roadglide harley did.
On my 03 LT I find that if I engage QUICK after squeezing the clutch lever it'll go right in. All works better if there is some movement of the gears when engaging into first.
You'll get the hang of it in short order.
Vern
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #4 of 10 Old Dec 14th, 2006, 3:12 pm
Same with me on my old 99. I just looked at the gear shift indicator which was accurate 90% of the time.
rkortes is offline
post #5 of 10 Old Dec 14th, 2006, 3:59 pm
BLBantz's Avatar
This is normal. As per my dealer, put a small amount of pressure down on the shifter and let the clutch out very slowly. You will feel it pop into gear easily. Whatever you do...don't jam down on the shifter to make it go into gear. You will find many, many threads here about broken shift linkage. Welcome to the site!
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #6 of 10 Old Dec 14th, 2006, 4:42 pm
Ted
Ted's Avatar
While seated on the bike, double clutch and roll the bike slightly forwards and back (just on the balls of your feet) and she'll drop right into 1st!
Do not try to force it or you run the risk of breaking the shift linkage.
Be gentle!!
Ted
Camarillo, CA
2012 Ducati Multistrada 1200S - Red
2007 R1200S - Black - Sold
2003 K1200LTC - Silver - Sold
IBA# 16554
Ted is offline
post #7 of 10 Old Dec 14th, 2006, 6:33 pm
Be gentle!!
In addition to Tads post, I often have to (while in N) just let the clutch out, pull it in and she goes right in to first!
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #8 of 10 Old Dec 14th, 2006, 6:52 pm
I read somewhere on this sight that if you only slightly pull in on the clutch lever (approx. 1/4") that you will feel it engage 1st, then you can give the lever a good squeeze if you need to whilst you prepare for departure. Works for me every time. The "slight" clutch pull also helped in the dreaded full throttle neutral between 1st and 2nd (DOH!)
mattison is offline
post #9 of 10 Old Dec 15th, 2006, 2:48 am
omurphy's Avatar
sometime you have to rock it foward and backward just a little to get them to go into gear. omurphy
omurphy is offline
post #10 of 10 Old Dec 15th, 2006, 8:34 am
Same with any vehicle with dry clutch, car, truck, bike. If it don't go in, pull in the clutch, let it back out & shift. With a wet clutch, the circulating fluid keeps the parts moving a little with the clutch in, that why you get a little jump when you put the Honda in gear. With the dry clutch nothing is moving with the clutch in, that's why you need to shift as soon as you pull in the clutch.
Big_E is offline
new textiles will make great riding gear tmgs Bike Talk 9 Nov 24th, 2007 9:57 am
Gear shifting points revisited bmwrubbercow K1200LT 20 Jul 10th, 2007 12:34 am
Rider's Gear Suitable for the Office? hschisler Rider's Gear & Luggage 14 May 31st, 2006 4:21 pm
Sticky Gear Selector markbreen K1200LT 4 May 30th, 2006 12:12 am
Pick a gear - any gear.... cpaine K1200LT 9 Nov 17th, 2005 7:13 am
