Another clutch question - BMW Luxury Touring Community
post #1 of 3 Old Dec 11th, 2006, 7:59 pm Thread Starter
Unhappy Another clutch question
My 05 lt lost all of the clutch fluid in the resevior at the clutch handle. Can i just pour new break fluid 04 type into the resevior and expect to haveclutch
activation ,or is there a right way to proceed.And i'm using Castor break fluid
which states that it exceedes speck 3 and 4 dot,can i use it?Thank you.
boxer259 is offline
post #2 of 3 Old Dec 11th, 2006, 8:42 pm
kevincook's Avatar
How did you lose the fluid? Did it just disappear?
If so, I would suspect that your clutch slave cylinder has failed. With that much fluid it has likely contaminated the clutch also. There have been quite a few 05's with this problem.
In any case, you'll need to bleed the clutch system. You can't just add more fluid to the resevoir.
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #3 of 3 Old Dec 11th, 2006, 8:42 pm
If you lost the fluid, you most likely have a failed slave cylinder, and any further riding will only contaminate the clutch, if it is not already ruined.
There is a chance that you have a broken hose or something else less drastic, but the odds are against you and heavily in favor of the slave being trashed, unfortunately. Hope you are still in warranty! Get it to the dealer ASAP.
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
A Clutch Question pwmac2005 K1200LT 4 Jul 28th, 2006 10:17 am
Clutch Repair Question 02lt K1200LT 2 Jun 6th, 2006 11:24 am
lost my clutch parishollow K1200LT 11 Jun 6th, 2006 7:45 am
