abs and locking up the front - BMW Luxury Touring Community
post #1 of 14 Old Dec 11th, 2006, 9:43 am Thread Starter
alanforn's Avatar
This is my first ABS equipped bike, on a few occasions I have applied the front brakes to the point of wheel lockup,(tire howling). I generally freak out at this point and let up pressure or add rear brake. Road conditions seem normal with no obvious signs of fluid or debris. Should I be patient and see what happens next? I'm fearful the next step could be crashing! BTW- No odd noises or trouble lights appearing. Thankfully, I have yet to require a full on emergency stop but would like to know if this is normal behaviour before an actual one confronts me.
alanforn is offline
post #2 of 14 Old Dec 11th, 2006, 9:47 am
Woolly's Avatar
Try it out at VERY low speed on grass or gravel, and gradually increase your speed as your confidence grows. It is quite a weird feeling stopping quickly on slick surfaces.
  • MB SLK 350 MT
  • 1974 Triumph Bonneville 750
Woolly is offline
post #3 of 14 Old Dec 11th, 2006, 9:59 am
Good question
Practicing emergency stops is essential. On gravel, on wet pavement, and on dry pavement. From a variety of speeds as well. Obviously, start slow and go from there. I think every rider should know what it feels like to apply full brakes (front and rear) on their bike at 55 mph, whether it's a BMW w/ ABS or a scooter w/o ABS. The more you practice the less of a surprise it will be the day you really need to do it.
post #4 of 14 Old Dec 11th, 2006, 12:14 pm Thread Starter
alanforn's Avatar
I feel as though I have a pretty decent understanding of braking, having roadraced for 12 years. I also believe that practice on a new bike is essential to learning it's behaviors. What I'm not as sure of, is the manner in which the BMW system operates. If the system allows full lockup, I would presume at a point a rapid cycling of brake pressure is employed. I know on a non ABS bike maximum braking effectness has been exceeded at the point of loss of traction,(skidding). It just seemed to me that the front tire locked up for a few feet on two occasions,(not wet, no debris, good asphalt), with no hint of any ABS related function coming into play. Does this sound normal?
What I would like to avoid is ending up in a wad, explaining that I was experimenting with the dynamics of LT brakes, "I'll skid a bit more dear, I'm sure the ABS will kick in any moment............."
alanforn is offline
post #5 of 14 Old Dec 11th, 2006, 12:38 pm
If in doubt have dealer check function.....then go practice like Joe suggests.
J.M.J...
Dcn Channing
post #6 of 14 Old Dec 11th, 2006, 1:08 pm Thread Starter
alanforn's Avatar
O.K.- practice and dealership checkup, I'll rephrase the question counselor: What has been YOUR experience with the LT ABS at the braking threshold, specifically the front brake?
alanforn is offline
post #7 of 14 Old Dec 11th, 2006, 1:41 pm
Zotter's Avatar
Properly operating ABS system should "never" lock up and slide the wheel. That's the whole point of the thing. At least in the direction of rotation, and ignoring lateral forces.... (etc, etc, disclaimer for not being an engineer, etc)
Now, is the 'howl' slide or hard brake noise?
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #8 of 14 Old Dec 11th, 2006, 1:53 pm
You should feel the ABS grab and release on a repetitive basis. It kind of feels like you're actually speeding up slightly during the release, but that's just in relation to the hard stopping power when the brakes kick in again. It's a bit disconcerting, but less so than sliding down the road on your side. Low traction or wet pavement will cause this, as will hard braking on bumpy or rippled roads.
The ABS is designed to deactivate at real low speeds (something like 3 mph or less). Otherwise you could never come to a complete stop.
post #9 of 14 Old Dec 11th, 2006, 2:04 pm Thread Starter
alanforn's Avatar
The howl is rubber singin,(lockup).
alanforn is offline
post #10 of 14 Old Dec 11th, 2006, 5:57 pm
bowlesj's Avatar
This is what I can tell you about my '04. The harder, and less progressive the front brake application is, and the tire will skid before the ABS kicks in. We're talking milliseconds.
Gravel - few inch slide and then released by the ABS
70-80 mph - near panic application and I get a front tire chirp and then a release by the ABS.
Bumps and rough pavement - same as above
ABS systems sense wheel speed. If the ABS kicks in before zero wheel speed you've lost brake effectiveness. So IMO, there will be a nanosecond of lockup before release and that is what I experience on the LT.
I have never done a high speed - grab the brake full hard - and leave it there to see how many pulses I get.
2004 - LT - Anthracite
bowlesj is offline
post #11 of 14 Old Dec 11th, 2006, 6:26 pm
grifscoots's Avatar
You ought to try it, more fun than goosing a bull in a squeeze chute. Just remember to keep your head up and eye's to the horizon.
-=grif=-
Grok
grifscoots is offline
post #12 of 14 Old Dec 11th, 2006, 7:58 pm
Neither my ex-LT or my current GT would lockup the front tire for more than a few inches...even in gravel. If you're getting full lock, I don't think your ABS is working properly. Perhaps the sensor is out of spec. That's a simple check.
post #13 of 14 Old Dec 12th, 2006, 7:39 pm Thread Starter
alanforn's Avatar
Thanks to all for the feedback, will check it out
alanforn is offline
post #14 of 14 Old Dec 12th, 2006, 7:56 pm
rkirker's Avatar
Lockup
I have done some panic stops for practice anywhere from 45 to 55 and not had a lock up.
Only time I did was when I hit gravel on the berm doing a quick emergency stop when someone ran out of gas in front of me going 55 and swerved to miss them then stopped, but it skidded for maybe for a second or two before it corrected.
Have yours checked out by the dealer with the computer to make sure your ABS is working correctly and once it is do some more panic stops for practice
and have fun
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well Itís not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldnít of happened."
rkirker is offline
ABS Failed me HarvRead K1200LT 18 Oct 12th, 2006 11:51 am
Wow!! New Concours D.Kinsey Bike Talk 39 Sep 27th, 2006 10:36 pm
Is it OK just to use front brake only? JoyfulSoul K1200LT 62 Mar 5th, 2006 8:03 pm
