2000 LT Grub screw size? - BMW Luxury Touring Community
post #1 of 8 Old Dec 6th, 2006, 6:29 pm Thread Starter
Smile 2000 LT Grub screw size?
I need to replace the grub screws on the front with bleeder screws. I don't know what size to get that will screw into the brake housing??? Does anybody know?
Doug
Doug_Gentry is offline
post #2 of 8 Old Dec 6th, 2006, 6:52 pm
kevincook's Avatar
M10x1mm
They are available at most auto supply stores. I replaced mine with ones that I got at Pepboys.
Good Luck,
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #3 of 8 Old Dec 6th, 2006, 8:42 pm
Hmmm
Doug
IIRC, seems that they are m10 x 1.0 pitch.
If that isn't correct I'm sure someone will let us know............and I'll plead CRS.
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #4 of 8 Old Dec 7th, 2006, 12:32 am
sheldan2's Avatar
Smile
got mine at napa, 2 in a box, $11 , need total of 5 if you want to replace front 2, rear 2 and clutch 1
sheldan2 is offline
post #5 of 8 Old Dec 8th, 2006, 12:14 pm
BecketMa's Avatar
You can verify it at this site:
http://www.speedbleeder.com/Motorcycle%20Sizes.htm#BMW
BecketMa is offline
post #6 of 8 Old Dec 8th, 2006, 1:08 pm
The size listed on the Speedbleeders web site for the front (SB7100S) did not fit my '03 LT. I ordered a set before flushing the brake fluid only to find that they were the wrong size once I started the job. I haven't followed up on the correct size yet.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #7 of 8 Old Dec 8th, 2006, 5:57 pm
kevincook's Avatar
Austin,
I don't see that size listed on the speedbleeder chart. The correct size is the SB1010S.
Good Luck,
Kevin
post #8 of 8 Old Dec 9th, 2006, 12:25 pm Thread Starter
Do I NEED to remove
Do I NEED to replace the grubscrews with Speedbleeders or bleeder screws to flush my brake system?
The BMW guys say I don't need to put in speed bleeders and actually came up with some good reasons why not to use them.
Ok??? I got the video from Paul Sayegh about bleeding the brakes. In there he says that the grub screws are for the BMW factory and Dealers.. we should replace them.
HE just doesn't say what to replace them with and since I keep hearing the word "Speed-Bleeders"
I just assumed....
So now the question is, Do I really need to replace those grub screws up front with at least bleeder screws?
Or can I use my mity-vac with the grub screws?
If I can use the mity-vac with the grub screws.... how do I use it?
Acck, I should have just taken it to the dealer. Bt now I'm on a mission to do it myself. LOL
Fuel mileage on 2003 vs. 2000 LT JohnR K1200LT 33 May 9th, 2011 9:23 am
Rookie...Calling on Current and Former 2000 LT Owners... darkey K1200LT 26 Jul 3rd, 2009 7:56 pm
2000 LT Brake fluid flush / change Doug_Gentry K1200LT 6 Nov 19th, 2006 5:02 pm
Windscreen Screw Size TandemCyclist K1200LT 7 Feb 1st, 2006 10:48 am
