Valve clearance checks - BMW Luxury Touring Community
post #1 of 16 Old Dec 6th, 2006, 1:58 pm Thread Starter
ajs
ajs's Avatar
Have just checked the valve clearances on my '05 LT. They are as follows;
Cyl. #1.. In (a) .005 In (b) .006 Exh (a) .009 Exh (b) .009
Cyl. #2.. In (a) .007 In (b) .006 Exh (a) .010 Exh (b) .010
Cyl. #3.. In (a) .007 In (b) .007 Exh (a) .010 Exh (b) .010
Cyl. #4.. In (a) .005 In (b) .004 Exh (a) .011 Exh (b) .011
The bike has 23,750 miles on it.
I have not disassembled anything yet to check shim thickness but at this point intake (a) and exhaust (a) and (b) on cylinder #1 are in need of replacement along with intake (a) and (b) on cylinder #4
Any comments, helpful hints, or other insight on this would be appreciated from any and all you experienced in such matters.
Regards,
Austin S
ajs is offline
post #2 of 16 Old Dec 6th, 2006, 2:00 pm
How were they at 12K? Mine tightened up slightly on a couple but were still well into spec at 24K. Guess I got lucky.
post #3 of 16 Old Dec 6th, 2006, 2:03 pm Thread Starter
ajs
ajs's Avatar
They wern't checked at 12k.
ajs is offline
post #4 of 16 Old Dec 6th, 2006, 2:08 pm
Ok, then as long as you did the check properly (used loose feeler gages) then I guess the next step is to pull the cams and see what size buckets you need. There have been a few recent posts dealing with some of the pit falls of this process. I have yet to perform it, but was prepared this time and got lucky.
post #5 of 16 Old Dec 6th, 2006, 4:36 pm
beemer100's Avatar
Valve clearance
Austin, I would echo John's statement and to make SURE you are checking the clearances properly. I know I checked mine at least 4-5 times before I felt comfortable I was checking them properly and getting the same reading. I have not had a whole lot of experience with using feeler gauges and after removing the feeler gauges from the tool (using a loose gauge), my valve clearance numbers changed (for the better).
I ended up changing 6 intake buckets, and no exhaust.
Another bit of advice would be to make certain that if/when you do change buckets, to make sure you properly relieve the tension in the chain to allow easy placement of the sprockets onto the end of the cams. This was a big learning step for me in this process.
Best of luck to you.
James
James Hart
2002 LTE Titan Silver
1992 Yamaha Virago 750 (given to friend)
River Oaks, TX
beemer100 is offline
post #6 of 16 Old Dec 6th, 2006, 5:04 pm Thread Starter
ajs
ajs's Avatar
On the question of feeler guages. I used two sets of guages none of which were loose. One was the typical 'jack knife' type. The other was a 12" long 'jack knife' type. I checked first with the shorter ones and rechecked my findings with the longer 12" ones. They, for the most part confirmed my findings with the short ones. In a couple of cases they were a better fit between the lobes and the buckets. I agree this is a critical measurement and therefore I will recheck in the am with loose guages just to be absolutely sure. Thanks for the heads-up on this one.
Austin S.
ajs is offline
post #7 of 16 Old Dec 7th, 2006, 8:59 am Thread Starter
ajs
ajs's Avatar
Rechecked the readings this morning with loose gages. For the most part yesterdays readings were verified. Three additional exhaust valves showed up as needing adjustment. Two were down from readings of .010 to .009 and one was down from .011 to .009. I rechecked them a number of times to be absolutely sure and am satisfied with todays readings.
My next move is to contact the local BMW dealer (about 250 miles away) to sort out the logistics for warranty repairs.
ajs is offline
post #8 of 16 Old Dec 7th, 2006, 9:31 am
ustasub's Avatar
Warranty repairs for an adjustment thats part of a service interval? Good luck...more than likely a bill if you want the valves adjusted.
Jeff Davis
San Diego, CA
'00 Pacific Blue AKA BluBlur
'08 WR250F
'07 TTR125L (for the kid)
ustasub is offline
post #9 of 16 Old Dec 7th, 2006, 9:31 am
-----------My next move is to contact the local BMW dealer (about 250 miles away) to sort out the logistics for warranty repairs.
Valve adjustments are not a warranty item, but a standard maintenance procedure. Warranty does not cover standard maintenance adjustments.
post #10 of 16 Old Dec 7th, 2006, 11:08 am Thread Starter
ajs
ajs's Avatar
Yeah, I got the message loud and clear from the dealer. Oh well!! onward and upward.
ajs is offline
post #11 of 16 Old Dec 15th, 2006, 11:00 am Thread Starter
ajs
ajs's Avatar
An update on my valve check and adjustment project. Rec'd 7 new followers from dealer, installed same, reinstalled cams, and all related parts, everything lined up according to info from this site, and Clymer, rechecked for clearances as follows; All intakes are now at .007 and all exhausts at .010. These checks were made 3 separate times and all 3 times the readings were the same.
I am very happy with the results. They are certainly a lot better than the clearances I got initially. I have completed the reassembly of the top end of the engine, and except for final test, (but WILL IT START) I am completely satisfied with the way it turned out. Not bad for a first timer on a K12 engine. Many thanks from all on this site who helped me out in one way or another.
P.S. I haven't started the engine yet because I am in the middle of an oil change and other routine maintenance checks and repairs, but that will come in time.
Thanks again
Austin S.
ajs is offline
post #12 of 16 Old Dec 15th, 2006, 1:19 pm
beemer100's Avatar
Thumbs up Good Job!
Way to go on the valve clearance adjustment Austin. I know it felt good after I did mine. I recently had to change out six buckets (all intake). All were in spec after the change. I have yet to start mine back up due to still working on getting the new throttle cables installed. I will be back to work on it tomorrow though.
Ride safe,
James
James Hart
River Oaks, TX
post #13 of 16 Old Dec 15th, 2006, 2:29 pm
grifscoots's Avatar
Thanks again
Austin S.
Don't let your heart stop if you hear a clatter when you start it. Sometimes they make noise till the cam chain tensioner pumps up.
-=grif=-
Grok
grifscoots is offline
post #14 of 16 Old Dec 15th, 2006, 3:18 pm
Austin,
The best part is this is most likely the last time you will have to do more than just check the clearances. She is bedded in. The valves do get tight as the seats wear and the fact that she didn't have the 12K check contributed to the extra tight valves you found this time. I'll wager the next three checks are all "normal". Enjoy!
post #15 of 16 Old Dec 15th, 2006, 4:34 pm Thread Starter
ajs
ajs's Avatar
Thanks for the heads up. Something like that could take the smile off a persons face real fast.
ajs is offline
post #16 of 16 Old Dec 15th, 2006, 4:38 pm
grifscoots's Avatar
Austin,
If you run the snot out of it in high R's you'll be doing it a few times
More fun than soldering your lip's together!!!
-=grif=-
Grok
More Valve Adjustment Questions dglenn1 K1200LT 13 Nov 13th, 2006 3:26 pm
Valve clearance check, not good bigbear K1200LT 6 Nov 6th, 2006 7:34 pm
Valve Clearance Help donsobeck K1200LT 3 Apr 22nd, 2006 1:13 pm
The Scphincter Valve DaFlake Humor 1 Apr 6th, 2006 12:46 pm
Valve Clearance BkrK12 K1200LT 29 Nov 11th, 2005 11:57 am
