Radio says "PHONE", nothing happens - BMW Luxury Touring Community
post #1 of 17 Old Dec 6th, 2006, 9:23 am Thread Starter
One of the first things I did during my ride back from Eugene, OR to Houston, TX was sit at a picnic rest area with a box of chicken and read all the manuals cover to cover. One of those manuals was the radio manual, but it fails to address this issue.
The bike runs fine. 1999 LT, with the tape player only, radio replaced under warranty by the previous owner. The bike has an autocom system installed, but I haven't used it, and don't plan on using it too often.
Every now and then, the radio just displays PHONE and stops all music. No button does anything to change the display. If I turn the bike off (to steering lock) then back on, the radio works fine about another 20-30 minutes of ride time, then reverts back to the PHONE display. Any pointers??
Also, while I have your attention, any ideas how hard it would be for me to add a CD changer to the bike?? Are the wires already there, or is it going to be pretty invasive?? Opinions??
Thanks again,
Robert
WildernessJeep is offline
post #2 of 17 Old Dec 6th, 2006, 10:26 am
STARFIGHTER's Avatar
Robert
I have a CD changer I took out of mine if you decide to do it...................
sorry, not a clue about the "phone" thing...
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #3 of 17 Old Dec 6th, 2006, 11:04 am
Texas42's Avatar
check in the right pannier, if they are there then the installation should take less than hour.
--Bo
2013 Magma Red R1200GSA
2012 Candy Apple Red R1200R
2006 Graphite K1200GT (sold)
2002 Titan Silver LT (sold)
Don't Panic!
Achtung! böse Eichhörnchen!
Texas42 is offline
post #4 of 17 Old Dec 6th, 2006, 11:25 am
Schweintechnik's Avatar
Not many folks know about this feature. It is a reminder to call your wife. The repeat interval will actually increase in frequency until you get home.
Be glad you have a '99. The '05 and later models actually play an MP3 of your wife complaining about you being late.
'03 K1200LT-C Dark Graphite
Schweintechnik is offline
post #5 of 17 Old Dec 6th, 2006, 12:33 pm
Many folks have pulled out their CD changers, so they are readily available. But few 1999 bikes came withe the CD changer wiring installed, so that can add a significant expense. You should look in the right saddlebag and see if there are wires there.
But before I'd spend the money on a CD changer and loose lots of valuable trunk space, I'd look at an iPod or Satellite radio first. Much more choices for music, much smaller, and easier to install.
As to the random PHONE message, I'd guess it's a loose connection. The system looses the radio signal, so tries to switch to a different source. Since you don't have a cassette in place or a CD changer, then it defaults to phone.
You'll probably have to remove the radio stingray and clean and reset all connections. Good luck with this project and lev us know how it turns out.
post #6 of 17 Old Dec 6th, 2006, 7:01 pm Thread Starter
Okay, I took it apart, cleaned it out, and seems to have fixed the PHONE issue for now. One of the antenna connections was pretty corroded, and I think that may have been the gremlin.
Now the CD changer. When you say look for the wires. In the right side pannier bag right?? I don't see anything. I don't see any wires behind it either. Where would they be?? Is there a wiring harness available from BMW??
Yes, XM radio is on the list, and will be installed soon. I was thinking about putting it in the little cupboard. How to connect to the radio?? I'm really not too fond of cutting factory wiring looms.
Thanks again for all your help.
Robert
post #7 of 17 Old Dec 6th, 2006, 7:28 pm
grifscoots's Avatar
If the wire aren't there, I'd forget about trying to do it.
You'd run it thru the Autocom.
-=grif=-
Grok
grifscoots is offline
post #8 of 17 Old Dec 7th, 2006, 4:08 am
®win's Avatar
Yes there is. You will have to replace the wiring harness that is attached to the back of the radio unit and ends on top of the tank, left side under the side panel (new harness will have an extra connector). And you will have to add the cable from that connector to the right side case. I have done this job when I had my '99 LT. Both harnesses set me back € 147,- in 2002.
Erwin
R1200GS Adventure LC 2018, Blackstorm/Schieferdunkel Matt/Achatgrau (Triple Black), in full options, BMW Navigator V
R1200GSA LC '18 <- R1200GSA LC '14 <- K1600GTL '12 <- R1200GS Adventure '09 <- K1200GT '07 <- K1200LT '05 <- K1200LT '99 <- K1100LT '95 <- K75RT '92
®win is offline
post #9 of 17 Old Dec 7th, 2006, 8:30 am
Do you have the part numbers?
Alex H Lindsay
Melbourne, FL
Champagne 2001 LT
Space Coast BMW Riders
alindsay is offline
post #10 of 17 Old Dec 7th, 2006, 8:39 am
®win's Avatar
From http://realoem.com
61.12.7.651.608 wiring harness, radio w/CD-changer
61.12.2.305.968 cable CD changer
I would have to check tonight at home to verify.
Erwin
®win is offline
post #11 of 17 Old Dec 7th, 2006, 9:00 am
Robert
Autocom has a cable that can be soldered into the rear speakers with a switch to turn exterior speakers on or off and connected to your Autocom unit.
I have the connection diagram if you want.
With this cable in place, the XM music or CD can be heard thru helmet speakers.
I did this conversion and like it alot except when I try to sing, the Autocom turns down the volume as if I wanted to speak to passanger...........................
The XM has a much larger selection than you can carry in the CD changer and when placed in the stingray, is waterproofed...........BUT....
here in Oregon, I lose the signal constantly because of buttes/ forests............
IBA #38152
BMW-MOA 97667
post #12 of 17 Old Dec 7th, 2006, 12:09 pm
wcarter's Avatar
"...XM radio is on the list, and will be installed soon. I was thinking about putting it in the little cupboard. How to connect to the radio?? I'm really not too fond of cutting factory wiring looms."
There are a couple of options, including the wireless modulator if your XM radio is so equippled. I installed a hardwired FM modulator that not only gives better reception than the wireless feature, but also powers up the XM radio. The modulator fits between the radio and the antenna. You have to remove the "stingray", to get to the antenna cable. You also have to tap into the bike's power; I connected mine to the map light (there was plenty of wire with the modulator).
I am thinking of installing either a Zumo or a 2730, in part because they include an XM receiver. If so I will remove the modulator and put it up for sale, perhaps with my XM SkiFi car kit and the radio arm for the BMR shelf. Send me a PM if you can use any of this stuff.
wcarter is offline
post #13 of 17 Old Dec 7th, 2006, 12:56 pm Thread Starter
I bought a Garmin 2820, and it gets XM along with the weather stuff on it. Great unit. My wife has kidnapped that one, so I may get another instead of the actual XM unit. I was going to mount it in the little cupboard thingy too, because I like the "clean" look of the stock LT. Any problems with using a little dremel to get it to fit?? What about removal of the tape player?? It's huge, and I don't even own a tape.
The thought of starfighter singing to himself tooling down the road on one badda$$ LT-trike does my spirit good.
post #14 of 17 Old Dec 7th, 2006, 2:34 pm
zaphod's Avatar
The tape player is the stereo.
Malcolm McGee
Little Rock, AR
'00 K1200LTC Canyon Red
'09 Kawasaki KLR 650
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
post #15 of 17 Old Dec 7th, 2006, 2:40 pm
grifscoots's Avatar
But, you can remove the plastic spacer piece right above the tape player to get some more room.
-=grif=-
Grok
post #16 of 17 Old Dec 7th, 2006, 5:12 pm
Autocom also has a cable to connect that 2820 to the autocom system.....
I used it on my 2720..........doesn't turn down the volume of tunes for an announcement though............................................ ...........................
( I do a great version of Born to Be Wild)
IBA #38152
BMW-MOA 97667
post #17 of 17 Old Dec 8th, 2006, 9:20 am Thread Starter
did yours require a special antenna for the XM??
R
Radio just quit atps1234 K1200LT 62 May 29th, 2017 10:43 pm
Weird electrical problem with Radio hd2bmw K1200LT 6 Jul 7th, 2010 7:10 pm
Radio Question...Searched Hall of Wisdom hybridcage K1200LT 7 Dec 4th, 2006 1:32 pm
Radio flickering KMC1 K1200LT 3 Jun 7th, 2006 10:50 pm
