Right rear Speaker going out - BMW Luxury Touring Community
post #1 of 9 Old Dec 3rd, 2006, 9:54 pm Thread Starter
Just some recommendations from you guys on how to approach this with the dealer. I have had the bike for about 6 weeks and approx 3k in miles in that time. The right rear speaker is not working properly. I bought the bike used with 15k on it. Any thoughts?
Racer222 is offline
post #2 of 9 Old Dec 4th, 2006, 6:44 pm
RVB1019's Avatar
Before dealing with you dealer, try resetting the radio's memory. If you diconnect the terminals from the battery, it may reset itself. If that doesn't work, you may have a loose connection somewhere. I would think it would be covered by warranty but you never know.
To get to the radio, you have to remove the left side stingray to get to the radio itself. Depending on who you listen to on the board, this is not a big job - 2 hours sounds like a good estimate.
You can also search the forums to check the right side speaker. The wires there may have simply slid off.
Try disconnecting the battery first. That's the easiest.
Then the rear speaker.
Good Luck,
Rob V.B.
2015 Triumph Explorer 1200
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #3 of 9 Old Dec 4th, 2006, 7:07 pm
JPSpen's Avatar
Clean the connections
This most likely is a connection problem. It's fairly common. You'll need to clean and lube the connections with dielectric grease. Start with the connections at the rear trunk under the passenger seat. This is the easiest to get to and in your case seemingly the most likely...If that doesn't fix it then pull the left side tupperware and do the connections at the stingray. I don't think I've ever heard of the speakers themselves failing ( I could be wrong there ) . I guess if you abused the volume long enough you could blow a speaker but they're fairly robust little units.....
Good Luck
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #4 of 9 Old Dec 4th, 2006, 9:48 pm Thread Starter
Thanks guys. I will try my luck at the dealer. I race a kawasaki that I could take apart blind folded but I am a little nervous about messing with this machine.
Marc
Racer222 is offline
post #5 of 9 Old Dec 4th, 2006, 10:24 pm
JPSpen's Avatar
Fear not
Don't be afraid to wrench on the LT.. It's just a motorcycle underneath all the covers....
Stand them on their heads and they're all sisters....
IT's probably just dirty connectors....
JPSpen is offline
post #6 of 9 Old Dec 7th, 2006, 2:08 pm Thread Starter
Bike is still under warranty. Have an appointment on Saturday. Thanks for all the help. I will let you guys know how it turns out.
Marc
Racer222 is offline
post #7 of 9 Old Dec 8th, 2006, 11:29 am
BecketMa's Avatar
Ask the dealer to to not only get the speakers working correctly, but also to solve the problem as to why it/they wen't out.
BecketMa is offline
post #8 of 9 Old Dec 8th, 2006, 10:32 pm Thread Starter
Will do!!
Racer222 is offline
post #9 of 9 Old Dec 17th, 2006, 8:38 am Thread Starter
Update
Seems like the speaker wasn't the problem. I haven't been told exactly what the problem is but they are ordering me a new radio to fix it. I will keep you all posted.
Marc
Racer222 is offline
Cheap Rear Speaker Replacement MolenaarD K1200LT 5 Jul 10th, 2006 2:17 am
Left Rear Speaker out turbogunner Intercom, CB, & 2-Way Radios 5 May 31st, 2006 6:35 pm
Rear END????? kip K1200LT 13 May 24th, 2006 8:32 am
